Question about Epson Stylus NX515 All-In-One InkJet Printer
How to change ink cartridge on epson stylus nx130 printer
cns assoc
  • 677 Answers
SOURCE: EPSON Stylus SX600FW printer. Recently changed
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc. These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. Don’t waste too much ink in cleaning it.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Jan 30, 2010
  • 38 Answers
SOURCE: Epson Stylus DX7400 - Ink cartriges
Lift the scanner up to expose the inside of the printer. Thers a button "stop" top left face of printer, press and release and the print cartridge holder will move, press again and it will stop at the colour that needs replacing, press again (total four times) to show if other cartridges are ok. Press again and the cartridge carrier will return to right of the machine. Lift the lid (grey colour) to show the cartridges, remove and replace the ones that have been shown to be empty. Close the lid, it should click. Close the scanner down again. Press "start" to recharge the cartridge. ANy other problems try the epson support site. Good luck.
Posted on Dec 07, 2008
SOURCE: changed black ink cartridge for epson stylus d120 but not working
Usually when this happens the printer fails to goes through the motions of the printing process, kind of stands still with indicator lights just blinking away. This could be as a result of either of these scenarios.
i.                     Ink cartridge has developed incompatibility or is incompatible
The Solution is to try an older/another cartridge (doesn’t matter if ink is finished. You must replace cartridge one at a time). If lights stop blinking it confirms that your cartridge has become incompatible or developed incompatibility. Also if your printer is the type that can work with only one cartridge, remove one after the other (closing back the lid/cover) to determine which in the set (black or color) has become incompatible. At the instance the incompatible one is removed and you close the lid, the blinking will stop (for printers that can print with one ink cartridge only). Just replace the incompatible one and start printing again. In most cases the issue is always with one cartridge. But if both are affected, you have to replace both. Because of this type of problem, always keep used cartridges somewhere safe; they come in handy for this type of troubleshooting.
ii.                   The Cartridge electronic panel  is dirty
The electronic panel on the cartridge that makes contact with the cartridge carrier inside the printer is dirty and needs cleaning.  This electronic panel is front part of the cartridge with copper “dots”.
The Solution is to try to clean this panel with a piece of folded tissue paper soaked in a bit of methylated spirit. Also try to clean the area in the cartridge carrier/holder that makes contact with the cartridge’s electronic panel (Usually this is more difficult). If you cannot reach it with your fingers, use a stick or something with tissue wrapped around it. Allow to dry well and return the cartridges, close the cover. The blinking should stop if the electronic panel is the issue. Once the blinking stops the printer will print.
Posted on Mar 24, 2010
  • 4 Answers
SOURCE: Epson Stylus SX400 "Ink cartridges cannot be recognized"
Try this: First check which cartridge(s) are not being recognized. In my case where I replaced all three color cartridges, two were recognized right away but one was not. You find out by sending a print request to the printer and looking at the ink cartridge levels diagram in the dialog window. In my case two of three were fine but one had a red X on it. So I removed it and cleaned the contacts with alcohol then rocked it in the slot after pressing it in. It was recognized and the charging process began as normal.
Posted on Oct 25, 2010
  • 121 Answers
SOURCE: My Epson Stylus NX 400 is not printing.
no it cannot. Those multi-colored cartridge system requires that you put in every single color, AND ensure that they are not empty before they will print. Even if all you want is a black and white copy.
Posted on Apr 28, 2009
Why won't my Epson NX130 work after replacing one ink cartridge?
you didnt hold your tongue like this :P
will need a lotta more info on this exactly
errors ,
try this reset prog from epson
Epson Ink Pads Reset Utility
May 04, 2015 | Epson Stylus Multifunction Inkjet Printer/...
Epsom NX130 wont print after replacing new ink cartridge. Have taken all out turned off power. Not working
Does it try to print, but the page is blank, or does it simply sit there?
If it tries to print, but nothing comes out, you may have a clogged print head.
If it doesn't even try, did you use a genuine Epson cart, or an after market? Epson printers won't print if even one cart is empty.
May 02, 2015 | Epson Stylus Nx130 Mfc Inkjet
Epson Stylus NX130
That's the problem with Generic carts. Use either Genuine carts or Resettable Carts.
Mar 04, 2014 | Epson Stylus Multifunction Inkjet Printer/...
How to change the ink for an epson stylus nx130 printer
Replacing procedure only available if one or more ink tank "empty" or not recognized. Follow "how to..." at epson status monitor. but if you wish to replace, just turn on printer, unplug power chord while carriage moving. The carriage released from locking position, move carriage by hand to the appropriate position.
Jan 20, 2013 | Epson Stylus NX515 All-In-One InkJet...
I lost my cd for installation for my epson stylus nx130/tx130 series printer
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 25, 2012 | Office Equipment & Supplies
Need to change ink cartridge on a epson stylus sx 215
remove the ink, then turn on the printer, then hold the power button in 2 seconds, wait for the ink cartridge to go to the center, then change the cartridge
Oct 26, 2010 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus NX515 All-In-One InkJet Printer Logo
2,846 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
