Question about Amana NAV8800E Top Load Washer
How to tighten agitator bolt on amana nav8800e
    Top Expert:
  • Amana Master
  • 9,472 Answers
Remove the fabric softener cap on the agitator to access the 7/16 bolt.
Posted on Nov 07, 2012
Hello, I have an Amana top load washing machine and the agitator just came off in the unit while it was loading with water. I can see the gear that the agitator is supposed to sit on and I can hear what I...
there is a plastic hub the agitator sets on , you will have to get the plastic hub out of the agitator , that goes over the shaft then a screw with an o ring holds that down, then just push the agitator back onto the hub, I should go pretty easy if not turn it a little and try again
Jul 01, 2017 | Amana NTW5205TQ Top Load Washer
Simpson Encore 605 agitator bolt comes loose - does it need loctite?
The wear is preventing it from tightening correctly, loctite won't be a long term fix, it will still come loose again due to the forces put on the bolt by the vibrations of the agitator. The only way to fix it is to replace the agitator.
Mar 06, 2012 | Washing Machines
Agitator is coming loose. how do i tighten it
The top of the agitator comes aparts and reviels a bolt. Push the agitator back down and tighten the bolt snug.
Jan 08, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
I have a Kenmore washer that has trouble agitating. I took off the cap on the agitator and tightened the bolt that goes into the agitator. This fixes the problem for a while. Pretty soon the agitator...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
There are two "bolts" for the agitators (assuming that you have the basic split system) The bottom agitator turns back and forth and the top section only turns one way.
The top section (when you remove the cap) usually has a plastic 1/2" square drive bolt.
If you remove the bolt and top section of the agitator, you should see a second 5/16" stud. under the stud is a rubber washer.
The first thing I'd do is pull both parts of the agitator and look at the splines inside of the lower agitator and the splines on the transmission agitator shaft. If either of them is worn / broken, your washer won't agitate. Also make sure that the two pronged "washer" is in place on the transmission agitator shaft and that the clip that holds it in place is fit.
If the splines are OK, I'd carefully put the lower agitator back on. Check the condition of the rubber washer on the stud. Install the stud and do not over-tighten.
Put the top agitator on tighten the 1/2" bolt carefully. Don't over-tighten.
Beyond that, you may be looking at a clutch or transmission problem.
Oct 07, 2009 | Kenmore Washing Machines
How do you remove the agitator?
All depends on the make, some have a bolt in the center under the cap/dispenser and Maytag had a retainer bolt in the side. Once the bolts are out a strap placed under the agitator makes removal easier and saves your fingers.
Eric
Aug 26, 2009 | Amana Washing Machines
How do you remove the agitator on amana washer model lwa30aw
Unplug the Amana washing machine from the wall outlet, and open the lid. Pull the liquid fabric softener dispenser straight off of the top of the agitator. Some Maytag washers require the use of a flat head screwdriver inserted between the dispenser and the top of the agitator. Twist the handle of the screwdriver to pop the dispenser off of the agitator.
Remove the barrier cap inside the agitator using your hands. Pull the barrier cap straight out of the agitator. There is an O-ring that attaches to the outside of the barrier cap. If it did not come out with the cap, pull the O-ring out of the center of the agitator.
Remove the bolt securing the agitator to the drive bell with the socket wrench. The bolt is inside the center of the agitator.
Place your fingers in between the bottom of the agitator and the tub. Lift straight up to remove the agitator from the tub. Keep your head out of the way in case the agitator is stuck and unexpectedly releases. If necessary, use agitator hooks. Insert them under the agitator and push down on the hooks to release the agitator.
Aug 06, 2009 | Amana 3.2 cu. ft. Top-Load Washer
For amana top loading washing machine, how do you get to tub seal
hi potterstreas,any amana a couple years old is an maytay.they have had lots of problems with their thriple lip seal[water ,tub seal]you can order and parts on line by model# use our links if you like or google your brand/modelor sears online.have fun.God bless
Jan 02, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Removing bolt in agitator arm
The bolt unscrews counterclockwise. Hold the agitator by the bottom vanes. If it won',t budge try tightening it first, just a little to break it free.
Dec 10, 2007 | Whirlpool LSN1000LW Top Load Washer
Amana NAV8800E Top Load Washer Logo
27 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Terry Schneider
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
