Question about Xante Ilumina Digital Color Press Printer
Xante ilumina paper jam wont clear paper - Xante Ilumina Digital Color Press Printer
SOURCE: Front Paper Jam
I'm not 100% sure that this will work. I have a 3N, when we first got it I had the same problem. After clearing the jam - You have to open the top portion of the printer. Even if the jam is no where around that area... the printer won't reset itself until you lift that top piece. I even tried to turn it off, thinking it would reset...it didn't.
I know the 4g is much newer then mine...but being it's the same company.. this problem might be fixed the same way.
Good Luck.
Posted on Feb 12, 2008
mattozan
  • 555 Answers
SOURCE: xante cl30 color laser printer paper jam
Remove the fuser and examine it closely (Note: the fuser gets extremely hot. Wait until it has cooled completely before touching it!) Paper or a paper fragment might be balled up inside it.
Even just re-seating the fuser might clear the sensor that is reporting this jam.
If the printer continues to stall with this error code, even though there is no jam, it could have a faulty sensor. This would have to be repaired with a service call...
Posted on Mar 06, 2008
rooboy
  • 24 Answers
SOURCE: full bleed printing
update on this, you cannt full bleed on the lead or tail edge, due to the sensors telling the unit when the paper starts to feed, and when the sheet ends as it enters the machine, you can only bleed to edge on the sides, by overstating the page size width.
Posted on Dec 08, 2008
SOURCE: Error code 382 paper jam on a ilumina digital
error 382 but dot paper jamp
Posted on Feb 10, 2010
SOURCE: Paper Jam will not clear
I also have the same problem and have found Xante Tech Support to be unresponsive and NON EXISTENT.
Posted on Mar 30, 2010
Magenta Stained product on a Xante Ilumina
i want to ask few question, are you using correct envelopes for this machine or can you use any type, is the weight of paper like is 20lbs
paper, or is it cheap 99 cents paper.
the port where the color ink is spout or ejector port is issue.
call the manufacture customer care center ask for technical services.
go online to the following sites for more help or informations.
www.ask.com/mfg.name/make/model/
/service/manuals/
/operational/manual/
/troubleshooting/guide/
/FAQ/
/customer/service/telephone#/
Oct 06, 2015 | Xante Ilumina 502 GS Digital Color Press...
Paper jam before coming out the tray
Check the fuser ..there will be maybe some jamed paper
Jun 09, 2015 | Xante Ilumina® 502 Laser Printer
What happens if you pull a paper jam from feeder, the opposite direction that your support to?
There are usually a number of paper guides and sensor arms that will tear into the paper if pulled the wrong way.
This can leave paper fragments in the fuser causing further jams, temperature sensor malfunctions, or odd marks on the print, and small pieces of paper left in the fuser usually require disassembling the unit to clean it out.
At worst case one or more sensor arms could be dislocated or broken which can be difficult or expensive to replace.
Nov 14, 2014 | Xante Ilumina 502 GS Digital Color Press...
What happens if you pull paper jam the wrong way
You may break any of the plastic switches actuators, which could cause a problem and your printer would not work until you replace that part that is broken. Depending on what area of the printer you broke the problem will be shown on your printer pannel.
Nov 12, 2014 | Xante Ilumina 502 GS Digital Color Press...
How do i fix the little black piece that broke off of the fuser exit sensor on my Xante Ilumina?
Amanda,
The problem is related to the paper exit assy. Their is no problem with your fuser assy. Take a look at the exit document related to your problem. Usually that is cause when removing a paper jam, that switch flags break for pulling the paper in the back direction. You would have to replace the paper out exit swicth black actuator.
Oct 03, 2014 | Xante Ilumina® 502 Laser Printer
"xante ilumina fatal error 929"
The 929 fatal error
Waste Toner
Transfer Motor
Lock Error.
The waste toner transfer motor is not operating properly. Does the error still occur? Yes
Check to confirm that the waste toner transfer system is operating properly.
Replace the waste toner motor.
Feb 03, 2013 | Xante Ilumina Digital Color Press Printer
How do you move the side paper loader to clear out side jam from paper tray 1?
2 places
1. there ia a flap that opens direclty on the RHS beside tray 1, this is the most logical.
2. On the Front RH corner on the macine, near the lid, there is a latch witha arrow up on it. just support the side feeder tray with one hand as you pull this latch up, it will release the side tray assembley and give you access to the feed rollers and most likely your jammed paper..
Oct 08, 2010 | Xante Ilumina Digital Color Press Printer
Xante Ilumina paper james on duplexing
Are your settings for media type and media weight are correct. Remember different paper, different settings. Make sure your feed rollers are not worn, if worn replace them. A lot of paper jams are caused by miss-feeding, due to worn feed rollers(try cleaning them with alcohol).
May 21, 2009 | Xante Ilumina Digital Color Press Printer
Glossy Paper descalibrate my Xante Ilumina
We found that the lighter the glossy paper, the worse the problem. I think the Ilumina is so hot that it literally melts the paper. We have great success using 100# gloss offset.The heavier, the better.
Oct 15, 2008 | Office Equipment & Supplies
49 people viewed this question
Top Xante Office Equipment & Supplies Experts
edy copier
edy copier
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
