Question about Motorola Mobility L6 Cellular Phone
Missing owners manual
I need a new owners manual for the L6 silver cell phone.  Specifically, I need to put in speed dial numbers and haven't found the exact steps to do so, and therefore need the owners manual, which the dog ate (we don't have a dog), or it went missing in the tornado (no tornado, either) or was lost in the flood (we live on the 26th floor).  .
The phone is on my AT&T account, main number 312 504 9145. The cell phone 's number is 312 952-4832. My address and the billing address for the AT&T account is 1360 Sandburg Terr., Unit 2601, Chicago IL 60610.
Okease advise.  Thank you.  ronguild56@yahoo.com
  • 88 Answers
PDF file from the Motorola site for the L6 phone - Here!
Lemme know if this helped!
Posted on Jan 12, 2009
How do you put speed dialing in a samsung GT-C3520
To Set speed dial numbers do the following:
1. In Menu mode, select Phonebook.
2. Select a contact to assign.
3. Select More -> Add to speed dial.
4. Select a number (if necessary).
5. Select a speed dial number you want to set.
The contact is saved to the speed dial number.
Note:
• You can call this contact by touching and
holding the assigned speed dial number in
the dialling screen.
• The first 3 speed dial numbers will be
assigned to the top 3 list on the widget toolbar.
May 16, 2014 | Samsung GT-C3520 Unlocked Quad-Band GSM...
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
How to put numbers into speed dial on a Sprint Rumor Reflex
Go to the contacts list. Hit more. Settings. Speed dial. tap a number and select the contct/phone number combo to call.
(Source: I literally just did this on a customers cell phone in best buy mobile)
Apr 07, 2012 | Cell Phones
We have a new wx345 cell phone that we have set up with speed dial numbers but I do not know the procedure used to call or dial any of the speed dial numbers. Can you help us use our speed dial?
If you have set up your numbers with speed dial, make sure the speed dial option is set "ON". When you are ready to make a call, press and HOLD the speed dial number you are calling. I had the same problem and found the solution on another online forum.
May 20, 2011 | Cell Phones
Vu 204..new phone, speed dial does not work, goes to verizon wireless message which says call cannot be completed as dialed. Checked numbers they are OK, also happens which #1 for speed dial of *86 which...
I had the same problem and found that the speed dial feature in "settings" is not turned on by default even though voice mail number is pre-programed into the speed speed list. Go to "Settings & Tools/Call Settings/One Touch Dial" and turn the option on.
Cheers,
Don Devine
Mar 30, 2009 | Motorola Mobility VU204 Cell Phone
Setting up voice dialing on a cell phone/
holding the # 1 key should get you to you speed dial if not try dialing that cell phones number. both of thous usually work. hope this helps :)
Feb 24, 2009 | Motorola Mobility L6 Cellular Phone
Lost my Owners Manual. Need to know how to put numbers into speed dial-900MHz. I had changed phones and what I had bought could not touch my Uniden! I think the manual is stored in my shed-where is the...
Looked farther on your site and found out how to get the info I needed. All done. Thank you for answering. I just did read enough to get the answer I needed, it was there, I just missed it the first time I looked at your site.
Sep 28, 2008 | Lands Phones
Speed dialing
which model ?
generally in all cell phones v will be have speed dialing option in range costing handset also... v can set the 9 speed dialing numbers .... in which 1 speed dialing number is common that is sos(112) in samsung and motorola handsets ... common thing is may be in sony ericson also i m not sure ... in nokia handsets if we make the speed dialing option on then if we just press one number means we can call to the person ...
for ex: you may be having some person whom u will call frequently instead of selecting the number by going to phonebook if you put that number to speed dialing list means you can call them by pressing only one button...( while adding to the speed dialing list it will ask to assign the keys like 1,2,3... 9)
as every handset keypad will be having 0-9 number keys this is very useful ...
in some handsets the speed dialing option is found in phonebook & while in other it will be found in call options...
Feb 07, 2008 | Cell Phones
Motorola L6: how to change the # VM dials
Motorola L6 Keypad Layout
  1. From the stand by screen, press the Menu key.
  2. Scroll to and select Messages.
  3. Scroll to "Voicemail" and press the Menu key.
  4. Scroll to and select Voicemail setup.
  5. Select Voicemail No.
  6. View or edit the Mailbox Retrieval number, then select OK.
    Note: If the Voice Mail Retrieval number is unknown, contact Customer Care for the users local number or to have programming sent to the device.
Dec 13, 2007 | Motorola Mobility L6 Cellular Phone
Resprogram speed dial numbers problem
You can reprogram them using bitpim.
Jun 10, 2007 | Motorola Mobility RAZR V3
Motorola Mobility L6 Cellular Phone Logo
126 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
