Question about Hunter 52" Ceiling Fan With Light And Remote Control
I have a 1997 52" Hunter Fan with Light kit and remote. The remote is bad and I need a replacement. I have 5 dip switches and it seems like all the new ones have 4. Meanwhile my fan and light is us
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
KMusselmann
  • 247 Answers
SOURCE: Hunter ceiling fan type 3 not responding to remote
Sounds like the black wire from the fan is not properly connect(lose)
Here is an example wiring diagram
Posted on Mar 17, 2009
  • 582 Answers
SOURCE: I have a Hunter ceiling fan with light kit. The
with out seeing the switch and how it's wired . i'll try
do you have power to the light switch it self. you have power to the fan but does the switch for the lights have power, you may have to run a jumper or sepperate wire fir the lights
Posted on Aug 23, 2009
  • 34 Answers
SOURCE: HUNTER ceiling fan remote works with fan but not light
Unfortunately, you either have a faulty reciever or remote. A replacement will cost $30-$40 at homedepot2.gif. And it doesn't matter which is faulty because you can't purchase them seperately anyhow.
Posted on Sep 10, 2009
  • 5 Answers
SOURCE: Fan with remote won't work with wall switch. I
kjob, if you haven't figured you fan problem out yet, the must be set to the highest setting through the pull chain for it work correctly with the remote.
Posted on Nov 10, 2009
Remote will not operate fan or light. Replaced battery. Remote light glows red when pressed
Check dip switches in remote and dip switches on receiver in the canopy of the fan, make sure the settings match exactly. Make sure there is power to the fan. Make sure the fan and light are not manually set to off by pullchains that may be on the fan. If the fan does have pullchains, wire it directly in (bypass the remote in the canopy) and test the functions to make sure the fan and light are working. If it works without the remote, but not with the remote, and the dip switches are set the same and you have new batteries, then the remote and receiver should be replaced.
Feb 28, 2011 | Hunter 52" Ceiling Fan With Light And...
We had an electrician install a Hunter ceiling fan in our daughter's bedroom along with a Hunter remote control. The light will randomly turn on in the middle of the night. It seems to occur only when...
Before I did anything else I would try changing the code on the problem fan. Change the dip switches in the fan and in the remote controller unit to a different code. It is not impossible that a neighbor has the same code in their unit or a device in the area is operating off the same code. Probably the cheapest thing to try next.
Sep 06, 2010 | Hunter Dryers
We installed a 27185 remote kit in a hunter fan, and factory settings. The fan light goes on and off by itself. I changed the dip switches( matched them to the remote to the controller), and the fan and...
I have had the same problem with the light coming on intermittently by itself. At first I also could not change the settings and have the remote work with the new settings. But I found out that when you change the dip switch of the receiver you must turn off the power using the wall switch or the circuit breaker and turn it back on before the receiver will use the new dip setting. I am still waiting to see if the light will come back on after changing the dip switches from 1-on, 2-on, 3-on, 4-off to 1-off, 2-on, 3-on, 4-on and the remote's jumpers from 1-jumpered, 2-jumpered, 3-jumpered, 4- no jumper to 1-no jumper, 2-jumpered, 3-jumpered, 4- jumpered.
Jul 09, 2010 | Hunter 27185 Remote Control
Light won't work on hunter fan with wireless remote
probably your lights are blown replace them.good luck.
Feb 28, 2010 | Hunter 27187 Remote Control
Have a hunter ceiling fan with light kit and remote. Lights have started turning on and off by themselves ?
This is likely caused by stray frequencies in the neighborhood. Change the frequency on your system and see if the lights go off less frequently.
See the manual for the remote system. You'll need to go into the top of the fan and change some little switches (dip switches) and set the same frequency on the transmitter (what most call "the remote").
Charlie
Aug 20, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter Fan - fan turns on and light goes off
you need to check the wiring and make sure factory dip switch settings are set
Jul 12, 2009 | Hunter Fan Co. 60 In.Brushed Nickel...
No dip switch in Hunter 27157 remote control.
Those aren't transistors in the transmitter they are jumpers. Match the jumper settings with your dip switch settings in the receiver. You can move the jumpers in the transmitter using a small needle nose pliers. An open jumper in the transmitter equals an OFF setting on the dip switch in the receiver.
Jun 24, 2009 | Hunter 27185 Remote Control
Fan does not work, light does
Your remote uses a slightly different band of IR for one and the other functions; lamp or on/off. This IR lamp or the circuit that controls the IR lamp has failed. You will need a new remote.
Hunter is good about making replacement parts available but as you said this is five years old. You may have to look for an after market seller on Ebay and chances are very good you can find a new one there.
Try Hunter first:
From Hunter Customer Care
Email:
Use Our Contact Form
Phone:
1-888-830-1326.
Monday-Friday 7am-6pm CST
Regards,
Worldvet
Jun 03, 2008 | Hunter 27177 Remote Control
Dip switch settings
I've had the same problem w/ light turning on/off. Called customer support and 3x waited 6 minutes to leave message and get no call back. Finally got a human and she told me to change code in receiver and transmitter. This was no easy task as the fan is very high up and the stupid thing needs to come down to adjust the receiver. Changed the setting and it worked for two days until it started back with the lights turning on at all hours. I noticed there's a toggle switch in the remote that is not explained in the manual. It says CFL on one side and INC on the other. The light will NOT dim if it's in CFL and tonight is the first time I've switched it to that setting. I'm hoping this is some kind of lockout for random signals going out of the remote...It would be nice to have a proper explanation in the manual. I should have gone with another Casablanca fan--Hunter products are lame.
Feb 03, 2008 | Hunter 27185 Remote Control
Dryers Logo
44 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
