Question about Microwave Ovens
Microwave Bajaj 2300 ET-B circuit diagram
Circuit diagram
Where to get clear diagram of magnetron circuitry with capacitor and diode circuits shown ?
Below is a common diagram for LG Microwave "High Side" components.
The component below the Monitor Interlock Switch is the Transformer. So, on the High Side of the transformer, you can see all the components.
Can you give me the model number of the unit that you are wanting information?
Apr 10, 2015 | LG Microwave Ovens
Tip
How do I replace light bulb on my Jenn-Air microwave?
Hi.
You will need to partly disassemble the oven by removing the outer cover held by screws (the cover part 2 on the first diagram). once there you will see the bulb hand side, located on the right (the bulb is part 6 in second diagram).
Before disassemblying the appliance disconnect power, by tripping circuit breaker or unplugging the power cord.
Here the replacement part for the model JMC9158AAS, listed in title: PS391758 .
Diagrams below are also for Jenn-Air JMC9158AAS.
If you have a different model, use the links listed here: Where do I find parts and diagrams for my appliance?
Here the diagrams. Click on the pictures to enlarge.
Diagram 1:
Diagram 2:
Unless you are a technician or a trained DIYer, better ringing the number listed on the owners manual to call service support. A badly assembled microwave will be dangerous for your health. The capacitor inside the microwave can also release dangerous discharge, take care and observe safety prescriptions while disassembling.
Regards.
on Apr 08, 2010 | Jenn-Air JMC9158AAS Convection/Microwave...
Circuit breaker blows when you open the door
1. Pull out the plug before you hurt somebody
2. Google the make and model number and add wiring diagram to the search parameters. Something like this:
Magic Chef microwave mco160ub wiring diagram
Also Google using parts instead of wiring diagram and you will find lots of nice pictures to guide you to inspect it further like this
From your post you seem to be fairly handy with a screwdriver. Take it further apart and look for a burned spot; if it blows the circuit breaker for the outlet, it probably has a big black spot somewhere to give you a clue. You don't have much to lose at this point, it is already pretty worthless in its present condition.
There should be a fuse in the incoming electrical line inside the microwave cabinet; I'm surprised it has not blown before the breaker. Make sure nobody has bypassed the fuse.
There may be a large capacitor that could hold a charge and give you a shock. See upper diagram for an example. [you did unplug the microwave, didn't you?] if you see the capacitor you can short out the terminals on it with a screwdriver and it may make a fairly loud snap as it discharges; better the screwdriver than your finger.
The damage is probably on the control board. The control board may cost as much as a new microwave, but you'll have all the fun of taking it all apart to find out.
Feb 05, 2015 | Microwave Ovens
Circuit Diagram required for HYS60-12-KD V-O 130C
Not getting any clear idea about your product. Please mention the proper Make and Model Number as given in the product.
Sep 15, 2011 | Microwave Ovens
Bamix M122 circuit diagram required
Sorry, but Bamix M122 circuit diagram is not available right now. In that case if you have your manual, you can check that.
May 25, 2011 | Microwave Ovens
The digital display is very dim and hard to read even in the dark. Is there a way to adjust the brightness?
I have a Sharp Carousel 1.5kW microwave oven with model number R-310F(W)C. The LCD dispaly on my unit recently became very dim. After check the small circuit board on the front panel, I found that the problem is caused by the LCD backlight driver which drives three surface mount LEDs. As the LED driver is inside a chip built on a small daughter card, it requires a replacement daughter card, or the entire circuit board for display and keyboard. A simple alternative solution is to cut the link between the three LEDs and their driver, then build a small circuit to drive the LEDs. I can provide the circuit diagram if interested.
Apr 13, 2008 | Microwave Ovens
Microwave Sylvania type sm81001
Have you ever replaced the fuse with Higher Amps fuse. There is a circuit diagram inside the cover please refer to that and ensure that the rating is same.
Jan 04, 2008 | Sharp R-1480 Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
