Question about Toshiba Satellite M45-S3591: M45-S3591 Centrino 750 2.0GHz, 1GB RAM, 100GB hard drive, DVD-RW/CD-RW, 56K Mod... (SATELLITEM45S3591M45S35) PC Notebook
Cable having power surges blowing speakers - Toshiba Satellite M45-S3591: M45-S3591 Centrino 750 2.0GHz, 1GB RAM, 100GB hard drive, DVD-RW/CD-RW, 56K Mod... (SATELLITEM45S3591M45S35) PC Notebook
  • nutsacto
    nutsacto Feb 01, 2013
    Good advice, and : I always have used ! ): My apartment shares walls on all sides, I think this may be related to my problem...also: I was told this is related to the sound chip configuring within the computer software and that can cause bad communications which cause the volume to 'blow out' especially if it's that I need a new sound chip (I may be using incorrect terms in this explanation)
  • Toshiba Master
  • 2,878 Answers
Always use a power surge protector.
Posted on Nov 08, 2012
Why did my micro stop working?
I guess the main plug fuse does not blow for the same reason it does not blow and you can wreck a PC, although not certain why that is. I have a feeling from past work on a Panasonic that there is an internal fuse as well. This may have blown with the power surge.
Jul 07, 2014 | Panasonic Nn-sn797s Countertop Microwave...
My 250q surges speed control doesnt work
Fein 30762198013 but first before replace try to clean the variable resistor with a contact cleaner or wd40. and blow it out of dirt little chance sometimes it can help.
Mar 30, 2014 | Fein Multimaster Rs - Msxe 636 - 2 Rs
HDMI inputs quit working
recently there has been a huge problem with hdmi imputs blowing the mainboard even without a power spike the only way to fix the imputs is with a new mainboard chck ebay with your model number one should pull up
Oct 29, 2013 | LG 60PC1D 60 in. Plasma Television
JVC LT-47X579 blows fuse WHEN CABLE IS HOOKED UP
Most likely a surge in the cable line! I would call your Cable Provider for assistance.
Apr 22, 2012 | JVC LT-42X579 42 in. LCD TV
Electric went off then it came back on but cable box want come on
sounds to me like the box may have blew a fuse if not the circuit board try replacing the fuse if that doesn't work then I would advise just getting another box. maybe think of getting an adapter with surge protection on it cause when something like that happens you get a surge of electricity when the power comes back on and it will just blow every thing or even just turn things off when you have a power cut so when the electricity comes back on it won't create a surge
Feb 02, 2011 | Televison & Video
Tv does not turn on after a thunderstorm and several attempts at power returning to the home. The power went on briefly then shut off several times, now the television will not turn on. We had the tv...
Check the main fuse in the power supply, the TV also has small surge protection devices (MOVs) installed after the fuse, any surges the come along and big enough will cause the main AC fuse to blow. When you surge protector, EVERY connections must go through the surge protector, for example, the AC cord of the TV is connected to the surge protector, the cable connection did not go through the surge protection, the surge then can get to the TV through the cables.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
1991 Honda Civic SI will not start. #14 fuse which is marked alternator/solenoid keeps blowing when trying to start. I am trying to find out what feeds into this fuse to make it keep blowing. My other...
ok first there could be a direct short in the ecu causing the fuse to blow OR the alternator/starter solenoid could be shorting out and blowing the fuse unhook the alternator and see if it blows the fuse then repeat with the starter and the ecu and let me know what happens
Nov 25, 2009 | Honda Civic Cars & Trucks
I have a Aprilia rs 125 2008,done 4000ks. It blows too much smoke
maybe rings are you losing coolant check the spark plug if it comes out with oil or too wet this means your oil pump is pulling to much in get back to me budd
Sep 10, 2009 | 2000 Aprilia RS 125
No power at the power panel( Aqualink RS8)
if unit comes on write down all auxs then remove plugs replace fuse turn on then plug one in at a time till it blows then you know which auw then see if wires are burnt
Apr 25, 2009 | Jandy AQUALINK RS TELELINK KIT
My Cornea CT1702T flatscreen monitor does not turn on; and, I noticed there is no light on the power adapter. Is there a fuse in the power adapter? Do I need to buy a new power adapter; or, can it be...
it's a repairable. and there is no power adapter in monotor u just chek out monitor with bcabinet power cable if yr monitor light show on then just change yr power code it's cost just Rs. 40 to 50.... first do this way otherwise take yr monitor to repair or call yr system wander to chek powwer cable.
thanks for using fixya.
jo_chinmay
Apr 03, 2008 | Computers & Internet
Computers & Internet Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
