Question about Dock Edge Plus Boating
How to build a floating dock - Dock Edge Plus Boating
    Novelist:
  • 184 Answers
First you need to check and see if you need permits???? then find suitable floation (pontoons, styrofoam, 55 gallon drums) box them in with wood or metal, and plank over a walk way.
Posted on Dec 05, 2012
Reapair ships
Usually they go into dry-docks. There are two sorts: land-based dry-docks and floating dry-docks.
Jan 30, 2015 | Video Game Consoles & Games
WE HAVE A FLOATING DOCK WITH BARRELS UNDER IT AND ONE BARREL HAS A HOLE IN IT AND NOW THE DOCK IS SINKING ON ONE CORNER. HOW CAN WE FIX IT WITHOUT TAKING THE DOCK OUT OF THE WATER.
I would get another barrel and fill it with water, that will allow it to sink, and be more maneuverable under water. Then you can switch it for the barrel with the hole in it, and then drain the water from the good one with a hose. Good luck fixing your dock!
Jason.
http://www.falveycorpmccall.com/marine.htm
Apr 11, 2013 | Cars & Trucks
Hi i have left side leaking carb after sitting for a while. What would be the issue
I do a lot of small engine repairs, and commonly when the fuel is cut on and the carb starts to leak, your float is stuck open. you said that it has been sitting for a while., How long? Over a period of a couple months, condensation will start to build up in your tank and carb float bowl, with this happening it starts to build up corrosion and electrolysis. To fix this problem :: 1 drain your tanke completely. 2 remove the carb float bowl from one or both carbs ( however many your bike has) ((DON'T LOSE THE GASKET) 3 carefully remove the pin holding the float in, and when you remove it be careful, there is another little pin with a rubber tip attached to the float 4 clean them thoroughly, pins and float, 5 clean inside float housing 6 Reassemble, carefully in exact order you took it apart. 7 fill tank with fresh gas and add 2 ounces of STABIL water remover and fuel treatment. This should fix your problem.. Let me know how it goes
Jan 10, 2013 | Motorcycles
Malfunction bose dock
Diagnostic videos and spares for the Bose SoundDock. There are several builds of the Bose SoundDock Original that look identical from the outside. If you visit invebo.com and enter your dock serial number you get access to the resources that tell you which version the dock's internal hardware you have in your dock, diagnostic and self repair videos and what kits you should buy to fix or upgrade to charge or Bluetooth wireless streaming. All spares are supplied on a no-risk 'buy and try' basis.
Mar 30, 2012 | Bose SoundDock digital music system...
Ipod nano rebooting on the docking station
Hello, The problem is that some of the pins onteh docking connector are shorting to others. Shorting the supply on you ipod. Don't do it!
Feb 20, 2012 | Bose SoundDock Portable Digital Music...
HOW DO I UNSTICK FLOAT ON MODEL GSD500D
To clear that float,remove the cover over it by removing the 1/4 hexhead screw from the bracket in the left corner of the tub that spans between that cover and the heat element. Remove the cover and lift off the float and use the green scrubby side of a kitchen sponge and clean all build up from the float stem,also clean all build up from the actual float and the cover in the sink using a brush.
GENE
Oct 10, 2011 | GE Dishwashers
My docking station keeps making an intermittent noise sort of a blip blip noise whether it is plugged in or not
The problem could be your dock resetting if itis a type B build. I suggest you visit www.invebo.com and enter your dock serial number. (Several builds of Sounddock look identical butthe internal hardware is different) You get access to diagnostic and repair videos and it tells you what pods and phones your dock is compatible with. Also there is a diagnostic video that helps you decide what's wrong and kits and detailed instruction videos that lets you fix the problem yourself. If your dock connector is faulty than you can fit the charge upgrade or upgrade to Bluetooth on a Bose SoundDock Original for less that the cost of a repair. All kits you get a new docking connector of the later, tougher design included in the kit.
Oct 01, 2011 | Bose SoundDock Portable Digital Music...
Floating icons
some windows xp themes and other (third party software ) gives you such thing
try [circle Dock]
Nov 22, 2009 | Microsoft Windows XP Professional
Sub Woofer to Sound Dock
Well if you are talking about the iM600 sounddock from Altec Lansing, the short answer is no. If you want better bass from an IPOD docking system you'll need to buy an expensive component from say Scandyna Dock or you could build one yourself. You would need an integrated amp or a complete system like the NAD C71. This would allow you to plug in a self-powered sub.
Dec 01, 2008 | Apple iPod classic MP3 Player
Boating Logo
44 people viewed this question
Top Dock Edge Plus Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Dock Edge Plus Boating Expert? Answer questions, earn points and help others
