Question about RIM BlackBerry 7290
Signal my network signal keeps dropping
    Sergeant:
  • 367 Answers
Have you pulled the battery to refresh the phone on the towers.
Posted on Jan 07, 2009
Why does the Battery Drop so fast On Samsung tablets
mostly it depends on your usage, more the usage faster the battery drop.
In general, below are few ways you can reduce your battery drop.
1. keep screen brightness moderate or low
2. User power saver
3. dont keep your tab for charging for longer time, it reduces battery life (eg, you might keep it charging before sleep until morning)
4. Kill all background running apps when not needed
4. check your carrier signal strength, use airplane mode when there is not network
5. keep in sleep mode when you are not using (just hit lock button
Jun 23, 2017 | Samsung Tablets & eReaders
Why does it keep loosing Wi-Fi connection?
I
is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - The symptoms are a wireless connection that literally will drop out .... the 5th router is wireless CPE AP, wifi signal keep droppings all the time I ...
WiFi problems! Keep losing connection! - Tom's Hardware
www.tomshardware.com/.../wifi-problems-losing-...
Tom's Hardware Guide
Nov 15, 2015 - 9 posts - ‎5 authors
Ok so for some reason ever since we got a new modem and router my HP laptop willhave a full connection and all of a sudden ill lose it and my wifi says "No Networks available" and a red X appears by my bars at the bottom. ... I dont know if maybe my network adapter is going bad or ...
A fix for my Windows 8
Jan 04, 2016 | Tablets & eReaders
My samsung phone mega seem not to be getting network, but with full signal showing on it.no bbm, watsapp or mails dropping
If you can make calls and SMS , but not able to log onto the web then it's simple, what you need is to request for internet settings for your model from your SIM card provider. It will be able to access web and all other related apps as you mentioned. Good luck.
Mar 20, 2014 | Samsung Star GT-S5233 Cell Phone
Calls keep dropping
First Option:
Phone in the Other Sim and check the Phone Network Signal If Network Signal Problem not Solved So
Secend Option:
Your Phone Network IC Fault So Please change Network IC
And Network Signal Problem will Solved
if it is there isn't much you can do on this side of the network.
Contact your phone company.
Aug 07, 2012 | RIM BlackBerry Bold 9700 Smartphone
Asus pce-n13 802.11b/g/n adapter keeps dropping the link to the router. signal levels are ok. It is as if it keeps resynchronizing
Try to check if there are any other wireless networks in the same channel as yours. Your home wireless network should be in the less crowded channel from 1, 6 or 11.
May 03, 2011 | ASUS Computers & Internet
I have a D link router a outdoor antenna which isadvertised for a 3 mile range. I am about 2oo yards from the antenna. My computer indicates a the signal strenth as good but i keep dropping off the net....
please observe signal strength as when you are connected to network and till you drop off, there may be distraction in signal strength while you are connected and when you check it again, it comes to good again.
Jun 27, 2010 | D-Link RangeBooster G WBR-2310 Wireless...
Im trying to hook up to playstation network but it never works the wi-fi connection works on everything but the playstation network
Look in Network settings on the XMB there is a diagnostic tool in there, what is the signal of the network that the Playstation is receiving? Most people don't realise that if the PS3 is in a tv cabinet or unit or something that's going to block the signal and if it drops below say 50% you are going to keep dropping your connection, especially during an on-line gaming session where you ping is a priority. So... even if you are sat on a laptop next to the TV cabinet, the signal's probably not the same in the unit.
You could try running a network (ethernet) cable from your router to it to see if there is a software issue rather than a problem with the network.
The last thing to try is to login to your wireless router settings and go to the advanced settings and see if it is trying to block your playstation, on some routers you need to allow certain IP addresses etc. You could manually assign an IP address to your PS3 and then write it into the router settings...
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
Signal strength keeps varying
if you arent in a clear line of sight, many things can affect the signal strength of your network including the thickness of the walls, the composition of them and anything else that may be in the way. if you use a 2.4 ghz router and you have a 2.4ghz cordless house phone, they can interfere and cause issues. A microwave oven that is located between the router and a device can cause interference as well.
Jun 10, 2009 | D-Link Xtreme N DIR-655 Wireless Router
HTC Touch -- Drops Connection to cell tower
I find the HTC touch drops many more calls than other phones I've had. Just doesn't seem to be able to hold a weak signal very well. On my way home from work, I had 2 places where I dropped calls. When I got the HTC Touch, I now have about 4 or 5 places where I lose calls. One additional place is sitting at my desk at work. Very frustrating!
Nov 04, 2008 | HTC Touch P3450 Smartphone
My computer keeps dropping the signal i have already talked with a tech i need help the signal keeps on fading and i cant get on the internet with my laptop computer.
you should try checking the wireless security & channel.
make sure if your network requires a security you should check that your typing the right one cause this is case sensitive.
make sure also to check the wireless signal of your router or Access point be sure to set that on channel 11.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
RIM BlackBerry 7290 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
