Question about Sanyo CL0971 Outdoor Condenser Unit
Error code e08
Replaced of PCB and of cfm and ran good for a few months now it cycles on and off intermittingly and has e08 error code
Zamil air conditioner code E08.what problems
Reason:
Communication fault between indoor PCB and display board.
Solution:
May be there is bad connection between indoor PCB and display board, you may need to call professional for service.
May 09, 2017 | Heating & Cooling
My washer dryer is showing an error code.
Unplug for a few minutes and then turn it back on. It should reset.
Nov 17, 2014 | Washing Machines
Throwing code E08. How do I fix it
I Googled my washer to look up some stuff i couldn't find for my own washer other than here and i did not see E08 as an error code in my manual or on any of the other websites but i did see F08 followed by E01 which was a water supply error:: and you have to check for proper water supply:: check the hoses and the faucets to be sure that the screens are not clogged and the hoses are not kinked to clear the code touch the power button once then touch the power button again to restart the washer if the code appears again the manual says to call for service to send out a service tech.
Jan 09, 2014 | Maytag MHW3000BW Maxima X Front Load...
Hoover WMH168D error code E08
I posted this elsewhere by mistake, I have a Hoover Optima which had an E08 fault, the forums suggested a Tachometer issue. I fixed the fault it was just the motor brushes. i made a video including testing the tacho and changing the brushes that cost me a tenner. easy fix hi I had this fault google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on you tube http://www.youtube.com/watch?v=xYn-f78GB4U if its any use.
Oct 17, 2012 | Hoover Washing Machines
E2 intermitent
E2 error code means the evaporator sensor is fault.
This needs to be checked against a temp/resistance chart which may require the PCB to be replaced.Only service professional can test it.You need the device for testing it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Sep 18, 2010 | Gorenje K357 / 2 Bottom Freezer...
ELECTROLUX DRYER T4190, error code E08 flashing on panel. have tried turning power on and off, but still flashing. problem?
How to solve this problem
Aug 14, 2010 | Electrolux Dryers
Hoover error E08
hi I had this fault, google said it was tachometer fault. the e08 fault on my hoover optima was not the tachometer, i checked it, but the fix was very easy, the motor brushes were worn out and i changed them for 10 quid, I made a video of it its on youtube http://www.youtube.com/watch?v=xYn-f78GB4U and it shows you how to test the tacho and how to change the brushes, hope this helps someone
Oct 02, 2009 | Washing Machines
1995 chevy truck intermitent high idle and solution...
Is your air cleaner good ? Replace aircleaner. look for leaks of anyliquids or debris that may be keeping the valve dirty.
Dec 19, 2008 | 1995 Chevrolet C1500
Sanyo CL0971 Outdoor Condenser Unit Logo
27 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
