Question about Zenith Z52Z95D TV
My son purchased a rear projection Zenith Z52Z95D for next to nothing. It I would guess is an older television and I would like some input on whether or not it's worth it to repair. The picture is dark and blurred. I brought up the menu and you can barely read it. Can you help?
I HAVE A 48" REAR PROJECTION (SONY) THAT WAS PURCHASED IN 1997. IT FINALLY WENT OUT LAST WEEK. PARTS ARE NO LONGER AVAILABLE UNLESS YOU WANT TO PAY A HEFTY PRICE. I AM NOT GOING TO REPAIR MINE AS IT IS NOT AFFORDABLE TO DO SO.
Posted on Jan 05, 2009
Zenith R56W36 Screen rolls constantly with cable hooked to antenna input; works fine on all video inputs
Tuner or a sync problem----using the video inputs bypasses the tuner and front end of the set's signal circuits---consider using a box with audio and video outs to a rear input and bypass the problem.
Jun 10, 2012 | Zenith R56W36 56" Rear Projection...
Lamp has been replaced but TV wont power up?
If the lamp is a known good one, the next most likely suspects are the lamp ballast/power supply board or a mis-aligned lamp door. There's an interlock switch which opens when the lamp door is removed. Try removing and re-installing the lamp and the door.
Feb 15, 2009 | Zenith E44W46LCD 44" Rear Projection...
Blurred picture and it's also dark rear projection zenith Z52Z95D
I'd get the lamp replaced for sure. If it has a ballast - change that at the same time. However, a Zenith repair center should be able to tell you whether it's worth doing or not.
Jan 05, 2009 | Zenith Z52Z95D TV
Interested in an older model panasonic
You can not buy a extended plan. I would pay no more than 500.00 for a excellent condition and picture quality.
Nov 17, 2008 | Panasonic PT-56HX41 56" Rear Projection...
1999 zenith 52 inch rear projection screen t.v.
IS the screen white retrace lines ? Have you looked into the CRT lenses while they are on with a signal applied through the input to see if an image is displayed in the lens lens of the crt? Let me know what the answer is to these two questions and we will go to the next level.
Apr 10, 2008 | Zenith B50M88W 50" Rear Projection...
Zenith D60WLCD 60 in. Rear Projection
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Oct 03, 2007 | Zenith D60WLCD 60" Rear Projection...
Hooking up a dvd player
as you say that it is old tv so there is a possibility that there may not be audio video socket where dcd player can be connected. OR You will have to purchase one video RF converter.RF converter contains one video input in yellow color & two audio input in red & white colour & one cable connector as output. Connect the dvd output to this converter & tune tv program in which place you receive dvd signal.
Sep 17, 2007 | Zenith Z25X22S 25" TV
50" rear projection zenith television
does it look like this:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jul 31, 2007 | Zenith IQC50H95W 50" Rear Projection...
R57w46 zenith
Hello Was wondering if you ever found anything out how to reset the IC Screen Numbers or what the factory numbers all are on the Zenith Rear Projection TV Model # R57W46? I have the same problem ! My 2 year old son, not knowing how he did it cuze only a technecian is suppose to get into this screen, but he did change numbers in the too. I called zenith themselves and no luck ! My screen is bowed , etc.. Any Help ?
Jan 16, 2007 | Zenith R57W46 57" Rear Projection...
Televison & Video Logo
62 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
