Question about Samsung RF26XAEBP
How do I fix the flap where the ice comes out. My stays open and water drips down the front.
    Top Expert:
  • Samsung Master
  • 9,472 Answers
What is the model number of the unit? The model number you posted under is for a range.
Posted on Nov 08, 2012
2 Suggested Answers
thecritter
  • 29 Answers
SOURCE: FLAP IN DOOR FOR ICE WILL NOT STAY CLOSE
The ice maker may need to be reset or the ice dispenser lever pulled. You posted on the samsung unit page, so I'm giving you the site to purchase anything from: samsungparts .com. The troubleshooting for pulling the lever is basically to watch the flap to see if it moves when lever is pulled. If it doesn't move, write here for more troubleshooting or call samsung.
Posted on Mar 01, 2008
6ED2FHGXVA ice maker making too much ice, why?
That is the dual water control valve that is leaking water to the ice maker. The ice maker will only fill for 7.5 seconds and then the water is turned off but if the valve is bad it will continue to leak water drips until it overflows the ice maker and forms an ice wonderland inside your freezer. There is no picture of the valve but here is a link to the valve part=> http://click.linksynergy.com/fs-bin/click?id=q2qDfOBHgas&subid=&offerid=92089.1&type=10&tmpid=2111&RD_PARM1=http&RD_PARM2=%253A%252F%252Fwww.appliancepartspros&RD_PARM3=.com%252Fwhirlpool-valve-inlt-w10158157-ap4371188.html
APPLIANCE 911
Dec 05, 2015 | Whirlpool Refrigerators
Ice dispenser
The solenoid that opens the flap is not working. You'll need a repairman to get to it .
Jul 21, 2014 | Frigidaire Freezers
How can i fix the outer ice depensper. The ice trap door doesn't close.
remve the drip tray , remoe screws , and take panel off. there you will have a solenoid that opens flap . the solenoid may be sticking , if so replace solenoid
May 12, 2011 | Maytag 25.6 Cu. Ft. Side-by-Side...
Icemaker dispenses crushed ice when you select cubed ice
GE has a problem with the flap on the door which lets the ice out , not closing due to a rusted solenoid behind the panel . If this flap does not close , frost will get inside the ice bin , not letting the bin flap open to let cubed use come thru, only crushed . You can defrost the ice bin front and replace the door flap solenoid easily . If this is the problem , repost about replaceing the flap solenoid for further instructions if needed .
Jul 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ice on bottom of freezer and small leak on right coner
There have to be a hole to drain the water down .You might need to take the cover off tof get to drain
May 17, 2017 | GE Profile PDS22SCRL Stainless Steel...
Kitchenaid ice maker dripping and freezing down freezer shelfs
Tube sometimes freezes because of minerals in it hold one droplet at a time until buildup freezes solid. Replace tube first. Water valve allowing some droplets through can also cause this. Tube first-less expensive.
Aug 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice dispensor flap does not stay shut
This is how most dispensers are accessed.
Check for screws around or on the under side of the dispenser trim that can be removed to get the trim off. Sometimes the drip tray in the base of the dispenser needs to be removed to access the screws. Sometimes the top panel (touchpad) of the dispenser is removed to access the dispenser components.
If there are no screws, use a putty knife with the end wrapped with tape so the paint on the door panel is not scratched.
Start at the bottom of the trim and CAREFULLY pry the trim away from the door panel.
There may be small slots in the panel on the under side that the putty knife can be inserted into.
With the trim off, the dispenser components can be serviced.
https://www.repairclinic.com/KitchenAid-Refrigerator-Parts
appliance parts, help & more
Apr 28, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
GE Refrigerator
first, let us explore the problem with dispenser flap. open the freezer and look into the ice discharge chute. there may be an accumilation of ice impeding the proper operation of the flap. next, you have indicated the light socket is broken. is it just the bulb or the socket itself? if you wish to remove the ice/water panel, first unplug the unit,. then you may be able to unsnap the drip tray where one would sit their water glass. if you are successful in doing this then the panel can be removed with a star driver but it depends upon the fasteners used. Always keep in mind to disconnect power before working on unit. I hope this was helpful.
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung RF26XAEBP Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
