Paper jam 2 on Samsung six-4825fn - Office Equipment & Supplies
Open the paper tray and or access panel to locate the jammed paper. if your unable find it, try turning the feed gear or roll by hand. you should be able to hear the paper wrinkling if it does not come out. also try restarting your computer after unplugging and replugging your printer.
Posted on Nov 07, 2012
Fix paper jam 2 on a Samsung CLX-3170 printer
paper jam 2 is a jam in the fuser/exit area.
did the paper jam come out in one piece? if not reassemble the torn paper to see how much is still inside.
sometimes there will be a small fingernail size piece of paper holding open the fuser/exit sensor flag.
sometimes the sensor flag itself is dislodged and needs reassembly.
attached is video in how to dissassemble the printer if required
Sep 24, 2014 | Samsung Office Equipment & Supplies
Our printer says paper jam open and close door. We have checked and no paper jam is evident as well we have readjusted the paper and opened and closed the front compartment and the top scanner/printer...
This can happen when there has been an actual paper jam, and in the process of clearing the jam and removing the paper one of the optical sensors inside the paper path has been damaged, thereby giving the alarm when there is no paper in the path.
Repairing this situation requires a skilled technician and dismantling the machine. This very problem happened with my own Canon Pixma MX860, a machine I dearly loved and had only owned for six months...but the cost to repair it was as much as I paid for the printer.
I know that isn't what you wanted or hoped to hear, but I also hope it was helpful.
Jan 08, 2011 | Samsung CLX-2160N All-In-One Printer
I have a paper jam with a samsung CLX 3175FN. Can't get the stuck paper out! Turning on and off didn't work.
If the paper is jammed inside the machine follow these steps:
1. Open the front cover and pull the toner cartridge out, lightly pushing it down.
2. Remove the jammed paper by gently pulling it straight out.
3. After removing the jammed paper, make sure there is no additional paper in the paper path.
4. Insert the toner cartridge and close the front cover.
If the paper is jammed in exit are follow these steps:
1. Open and close the front cover. The jammed paper is automatically ejected from the machine.
2. Gently pull the paper out of the output tray.
- If you do not see the jammed paper or if there is any resistance when you pull, stop and go to the next step.
3. Open the rear cover.
4. Carefully remove the paper by pulling in the direction.
- If the paper tears, make sure that all of the paper fragments are removed from the printer.
5. Close the rear cover. Printing automatically resumes.
Nov 17, 2010 | Samsung Office Equipment & Supplies
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
Good day, Check the table below about the problem of paper jams.
Display and Meaning
[Paper Jam 0] - Paper has Jammed in the feeding area of the paper input tray.
[Paper Jam 1] - Paper has jammed in the fuser area or in the manual feeder.
[Paper Jam 2] - Paper has jammed in the paper exit area.
hope it will help you.
Jun 04, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Paper jam-2
samsung scx-4521f paperjam2 check inside
Mar 22, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Epson Stylus CX8400 Paper Jam Error
I have the same exact problem of paper half torn removed but I can not see the other half anywhere. The printer has hardly worked for at the most six pages and now showing paper jam error. How do I fix it?
Dec 22, 2007 | Epson Stylus Photo R1800 InkJet Printer
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
jasbo
jasbo
