Question about Pioneer DEH-16 CD Player
Change the time on the clock
I can not figure out how to change the time on my stereo? I can't seem to figure it out. I tried holding the clock botton down to change it but that didn't work.
  • Anonymous Mar 13, 2009
    I have the same problem no manual its a older pioneer cd/radio player in a 1996 blazer everything else works except I CAN'T FIGURE OUT HOW TO CHANGE THE CLOCK
Okay you off turn off the stereo with the off button and push clock, and then hold down the audio button on the top right side and then the numbers will start flashing.
Posted on Jun 02, 2007
I am now the proud owner of a used Pioneer DEH-1650 unit that I got at an auction for $5. At my workbench, when I applied 12VDC between the black and red wires, I found it draws 2.4 mA approx. (the red wire needs a constant 12V to hold up the memory?). However, when 12V is applied to the thicker yellow wire as well (which I think would normally be supplied with 12V via the vehicle's ignition switch), there is nothing - no clock, no display etc, and no current measured through the yellow wire. Is this wire connected to a fuse inside the unit? If so, how do I get at it?
Posted on Jul 19, 2010
HOW DO I CHANGE THE TIME
    • 1
      Refer to the section of your owner's manual that addresses the car radio. Each car radio is different in the way you set the clock. If you've installed a car radio other than the one that was manufactured with the car, consult the manual for that radio.
    • 2
      Know that if this is the first time you're setting the clock or are setting the clock after installing a new battery in your car, you have to set the hour and the minute of time. Often, you set the clock with either the radio station up or down arrows. On some car stereos, you use the CD track selector buttons for setting the clock.
    • 3
      Using either the CD or radio selector buttons, set the hour first. Push the button labeled "Set" or "Clock" and then set the minute with the same procedure. When setting the minute, some manufacturers allow you to move through in increments of five by pressing and holding the button. If the time of day were 2:49 p.m., for example, you would push the button 13 times, including nine times to display :45, then four additional times incremented by one to display :49. Push the "Set" button or the "Clock" button.
    • 4
      Determine whether your car stereo is equipped to automatically change when Daylight Saving Time begins and ends. If it hasn't changed at 2 a.m. of the time-changing date, you know it isn't equipped for this. In that case, set the hour either forward or backward and the appropriate time of the year.
    • 5
      If you can't figure out how to set the clock on your car stereo, wait until noon on any given day, disconnect your car battery and reconnect it.
Read more: How to Set the Time on a Car Stereo ' eHow.com http://www.ehow.com/how_5003245_set-time-car-stereo.html#ixzz1MlfuX6eT
May 19, 2011 | Car Audio & Video
How do u change the time on the jvc kd-s15?
Press and hold SEL to get to the menu
Using the SCAN (FWD/REV) buttons, select Clock H
Using the volume knob, set its value
Using the SCAN (FWD/REV) buttons, select Clock M
Press SEL to end.
Nov 24, 2009 | JVC AM FM CD DET FACE CAR STEREO
Setting the clock of JVC KD-G125 does anyone know what and how?
to adjust the PSM (preferred setting mode) items, press and hold the select button (SEL) for 5 seconds..you should see one of the items DEMO (default item) displayed on the display window..press the Up/Down or Forward/Reverse buttons (^ or >>| or |<< ie.. it is the one you use to change the radio stations) to scroll to the PSM items DEMO-->CLOCK H-->CLOCK M-->L/O MODE-->AMP GAIN...when the PSM item you want to adjust displays on the window, CLOCK H for hours or CLOCK M for minutes for this case, use the control dial (volume knob) to change the setting...after adjusting the correct setting..press the SEL button again to end the procedure
Sep 06, 2009 | JVC AM FM CD DET FACE CAR STEREO
HOW DO YOU CHANGE THE TIME ON A DEH-P59001B PIONEER STEREO
Its not the select button, you must have the power off and hold the function button down for about 5 seconds, display will change and you will be able to navigate your way to the clock from there. Hope this helps.
May 02, 2009 | Pioneer DEH-P5900IB CD Player
Cannot set clock on my JVC KD-G335
You need to hold the sel button down for a little while then it will change displays thats when you use youe right seek button until you hit the Clock H to change the clock hour or Clock M to change the minutes when you hit it you use your volume control button to change the time.
Jan 04, 2009 | JVC AM FM CD DET FACE CAR STEREO
Setting clock
Try the following:
1. Turn the AudioStation OFF
2. Press and hold both ‘source’ and ‘select’ until the F/W rev appears. The F/W info will display for about 2 seconds
3. Select Menu language
4. Use Up/Down buttons display the language, then press ‘select’ to accept.
5. Press the Up/Down arrows to select 12 or 24 hours format, press 'Select' to accept.
6. Press the Up/Down arrows to change the Hour, press 'Select' to accept.
7. Press the Up/Down arrows to change the Minute, press 'Select' to accept.
Nov 02, 2008 | Logitech AudioStation High-PerDocking...
Rca clock radio with stero cd playera
Hold the center button on the back and then while holding push the button to the left to go backwards and the botton to the right to go forward
Oct 31, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Pioneer Supertuner IIID
To change the clock on this Pioneer stereo try this.
1. Press and HOLD the source button till the radio shuts off. Release the button.
2. Press and HOLD the source button again for about 5 seconds until the hour indicator on the clock begins flashing.
3. Press the UP and DOWN buttons to adjust the hours.
4. Press the LEFT or RIGHT arrows to MOVE TO THE MINUTES.
5. Press the UP and DOWN buttons to move the minutes.
6. When complete, press the source button to exit.
Oct 01, 2008 | Pioneer DEH-P690UB CD Player
Setting the time on my clock on radio Model # RP3755B
Well, I have an RCA clock radio/CD player and just figured it out. Press the "Time" button and hold it down while pressing the CD "Forward" button. Hope it works for you! Ron
Jul 03, 2008 | RCA Alarm Clock w/CD Player, AM/FM Stereo...
Setting the TIME
to set the clock you press and hold the MEM/CLKADJ until it blinks the 12Hr and then press the MEM/CLKADJ again, then it should get allow you to set the clock, use the arrows to change the time.
I do not know how to set the alarm time. i know the "timer" button turns it on and off, but i cannot figure out how to set a time. please help.
Dec 17, 2007 | Apple iLive IBCD3816DT Portable 2.1...
Pioneer DEH-16 CD Player Logo
251 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
