Compaq sr 1620 nx would not start. power button light in the front flashes. power light in the back is green and does not flashes. Upon starting computer, fan in side computer spins for a few seconds and then stops.
    Master:
  • 545 Answers
Reseat the RAM. That should fix it.
If the problem persists, then your power supply is likely dying. My guess would be the RAM.
Posted on Nov 10, 2012
s4u311
  • 813 Answers
SOURCE: hp wont turn on flashing green light in back an flashing blue light in front.
open your cpu remove the ram clean it put it back your problem will be sloves
Posted on Jul 16, 2008
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
mellomania
  • 121 Answers
SOURCE: Compaq Evo D5 power light flashes red.
try to get to the jumper next to the cmos battery in the mainboard. by changing its position for some seconds while power is off and putting it back , cmos is cleard. start the board hit delete to enter setup and exit saving chages.
Posted on Nov 13, 2007
IB4G2008
  • 3587 Answers
SOURCE: pover up trouble
sounds like something is drawing down on your 12 volt supply drives or on board regulators. Try it without the drives connectged, and see if you can get the system to boot up(you'll just get a notice that your drives are unavailable, but you'll already know that, right?
got backup for your Dell?
Posted on Feb 15, 2008
Pterocarpous
  • 202 Answers
SOURCE: I have a Compaq SR
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
BJ
Posted on Apr 05, 2008
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
We get a blinking green light response where the ''On'' button is on our Compac presario SR 1111 NX and cannot get the computer to turn on. Is this a battery problem of some sort? Can I fix it? The...
take out all the cables from the back of computer,press the power button for 1 min and then plug in only keyboard,mouse,monitor and power ,it will work
Feb 09, 2010 | Computers & Internet
Problem HP Compaq nx 7300 Yelllow light 8x
Have you had previous problems with your laptop power supply and battery? I have this same laptop and use it very regularly. I do have problems with battery life, but never actually powering on. I suspect the battery is not accepting a charge. My suggestion is to replace the battery and see how things go.
Oct 18, 2009 | HP Compaq nx7300 Notebook
C500 Laptop won't come on power button just flashes
Have you tried attaching an external monitor when the LCD screen is disconnected from the motherboard? this connector is located under the keyboard strip – a piece of plastic just above the keyboard.
If it works, this way, then the video cable isn’t seated properly in the connector on the back of the screen. Plugging the video cable back in should fix the problem.
I don’t know how comfortable you are with taking apart laptops but I think that this information could be useful for you.
Source: http://www.asklaptopfreak.com/laptop-notebook-help/2006/08/08/laptop-powers-on-and-shuts-off-immediately/
Sep 28, 2009 | Compaq Computers & Internet
Flashing Green Light on Power Supply
get yourself a themaltake ps
make sure you remove the old one and take it with you to the shop or get the shop to do it for you if you dont have the expertise yourself.
hope this helps
Dec 31, 2008 | Compaq 300Wt Presario ATX Power Supply...
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
Thank you
BJ
Apr 05, 2008 | Computers & Internet
Nov 13, 2007 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Computers & Internet Logo
118 people viewed this question
David Payne
David Payne
