Question about Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Buzzing/humming noise won't stop. Lamp was replaced a year ago. This just started and the noise is near the lamp. The noise won't stop while the TV is on and lasts for a minute when the TV is turned off.
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
If its a DLP with a high pitched or even fan like sound it is the color wheel--Mitsubishi does not sell them as a part---you would have to replace the entire light engine (expensive and may not be available any more on a older set) .
Posted on Nov 08, 2012
3 Suggested Answers
SOURCE: mitsubishi DLP WD 65731 TV
power supply is sending less than 135v to the ballast
Posted on Feb 04, 2009
  • 668 Answers
SOURCE: mitsubishi wd-73736 bulbs buzzing noise
The Ballast that ignites the Lamp could cause the Lamp to fail and/or cause a buzzing noise. That being said, the Color Wheel in the Optical Block assembly could also cause a similar symptom. If Mitsubishi would be willing to help with the Lamp cost, I would call a local Mitsubishi repair facility to install it and see if the noise is still there and find out exactly what is causing it. Mitsubishi Customer Service Phone number is 1800-332-2119.
I hope this helps,
Skyassoc
Posted on Oct 26, 2009
Why won't the fuel pump shut off
Fuel pump won't be the cause. Most likely the relay.
Apr 06, 2017 | 2005 Mazda 6
I have a samsung hln437n and I have a loud, high pitch buzzing noise which stays on all the time. It sounds like it is coming from the lamp. Any idea what the problem is?
Could be a slightly loose lamp connection and/or slightly loose lamp module - especially if you
have big trucks or railway tracks near your place (like me). Try powering down the TV set, use the
instructions that came with your TV to remove the lamp module, then simply re-install the lamp
module (also known as "reseating the lamp module").
If the buzzing noise persists, then
its coming from a component near the lamp (such as the power supply).
If there's a transformer in the power supply that's buzzing, then its about to fail.
Apr 17, 2011 | Samsung HLN437W 43" Rear Projection HDTV
1999 Altima has a buzzing noise that starts when I
you have a short in the headlight wire trace it back and look for cracked or worn wire
Oct 06, 2009 | 1999 Nissan Altima
HD50LPW42 making noise near lamp
colour wheel doesnot have bearing.but if its faulty it makes some gearing noise or click click noise.check out.
Jul 13, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
Loud humming or buzzing when set is in operation
Does the picture gets distorted in any way when you hear the buzzing noise?
I would suggest to check all the cooling fans for proper operation.
Jul 16, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Buzzing noise from lamp area.
buzzing from the lamp area could be either the fan or color wheel Whats the model number of your set, and I can better answer your question
Jun 26, 2008 | Televison & Video
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Buzzing noise, sound but no picture
It sounds as if the lamp needs to be replaced. The buzzing sound you hear is the ballast attemting to fire the lamp.
Oct 20, 2007 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Mitsubishi WD-65731 65-Inch 1080p DLP HDTV Logo
195 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
