Question about LG Washing Machines
How do you fix fe error - LG Washing Machines
    Sergeant:
  • 389 Answers
LE means washing machine electronic controller has detected an overfill situation
* check for over foaming or over soaping
*check the air chamber and pressure switch hose for blockage
*check water level sensor
*check wiring to water pressure sensor
*check connections to water level sensor
*check main electronic controller
Posted on Nov 07, 2012
LG Dishwasher runs to about half of cycle than code comes up on screen with FE
"Water Overflow Error"?
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dishwasher/413-200-684362-/LG-FE-WATER-OVER-FLOW-ERROR-Water-continuing-to-enter-machine-LDS5811WW
Dec 01, 2017 | LG Dishwashers
Halfway into wash cycle fe code appears, we can select drain & spin cycle and it will finish. how do we fix
The FE error code indicates an Over Flow Error. The machine thinks that the water level is too high in the tub.
There could be three causes to this problem.
1. The water level sensor is bad.
2. One of the solenoids is bad, either hot or cold.
3. The main circuit board is bad.
Mar 07, 2015 | LG Washing Machines
On my LG tromm washer has an error code FE, what is the solution to this problem or how do i get it fix???
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced.
Feb 21, 2015 | LG Washing Machines
The check engine light just came on in my 2004 sante fe but its running fine
Yes, it's still running fine, but you have to check the error code and fix it
Mar 26, 2013 | 2007 Hyundai Santa Fe Limited
Error fe
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Oct 22, 2012 | LG WM-2277HW Front Load Washer
How to fix error 210 stuck key fe
Sounds like one of two things...
1. Somebody spilled somthing or got some sticky junk in there and one of the keys is semi gummy.
2. The machine got banged around once too many times and one of the connections is slightly ajar.
So basically it sounds like it's hardware and not software, so you'll probably have to pull it apart yourself, or else take it to someone
Ford Performance Chip
May 25, 2012 | IBM ThinkPad T43 Notebook
FE ERROR CODE
FE error is due to "Over flow" error. Water is overflowing (water level frequency is over (213) When FE is diplayed the drain will pump out automatically. Water level sensor needs to be replaced.
Apr 09, 2010 | LG WM0642H Front Load
My FE 340 Olympus Camera tries to turn on, but can't. Lens goes in and out several times then shuts off completely. Battery is fully charged.
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 19, 2010 | Olympus FE-340 Digital Camera
Washing Machines Logo
69 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
