Question about JBL EON 518S Subwoofer Speaker
My jbl eon518s clipped off when turned on and won't turn back on
How long do I charge the jbl clip and can I over charge the jbl clip?
Battery is charged when the light turns blue. Red shows it needs charging.
Unlikely you can over charge, but 4 to 8 hours would be about right. Manual is a picture only affair.
http://ca.jbl.com/tl_files/catalog//jbl/multimedia/Quick%20Start%20Guide/Clip+/Quick%20Start%20Guide%20-%20Clip+%20(Multilingual).pdf
Dec 30, 2015 | JBL Audio Players & Recorders
My iPad won't find my Bluetooth speaker
Go to settings, General, blue tooth and remove any "other" previous paired BT devices & Turn off BT, then go to Sett. General, scroll down to reset and reset network settings, this will not delete anything. Power off BT speaker. after iPad re-boots turn on BT Speaker First, make sure BT is off on iPad as well as WIFI-wait like 10-15 seconds and then turn BT on in iPad it should see your speaker now and let you pair it up.
Jan 14, 2013 | Harman Kardon JBL Flip black
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
1999 Audi A4 trunk keeyhoke turned clockwise 90 degrees & will not turn back& also won't unlock. what can I do?
Remove the back seat and crawl through and manually release latch from inside the trunk. the replace the lock cylinder or the lock cylinder retainer clip.
Nov 01, 2012 | Audi Cars & Trucks
Describe your Venue SUB10 Subwoofer Problem: The subwoofer won't turn on at all. The red light doesn't even come on. Could it be the fuse in the subwoofer? If so, where is the fuse located?
You can remove the screw near the volume knob and the screw near the on/off switch - then slide out the amp remove the black and white wire - then check the fuse - if its blown look for we repair amps - ebay - if its good then it probably still needs work - it should turn red when plugged in and no signal and green when signal is present - which means amp is on.
Sep 11, 2011 | JBL Venue SUB10 Subwoofer
We have the jbl eon system. Our subwoofer (518s) is having issues. It will turn on, recognize a signal -even limit a signal, but No sound comes out
First thing is to use an ohmmeter to check the voice coil of the speaker to make sure it is not blown open. After that it is into the shop for amplifier repair.
Jul 14, 2011 | JBL EON518S Speaker PA Sub
My JBL PRX 635 Speakers at all event shuts off during high volume ( No Red Light ) Very Embarrassing during the dance is packed. Volume is always set at one single yellow peak from the mixer and just...
Sounds like you're over driving them. First check to make sure they're on "line level" not mic. Shutting off is amp(s) in speakers going into "thermal shutdown" IE: overheating. According to your description level settings look good - check to make sure speakers are on LINE LEVEL
Apr 12, 2011 | JBL PRX635 Speaker PA Active
JBL Radial Remote stopped working.New battery replaced no avail.
Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
Jan 12, 2009 | JBL (JBLRADIALWHT) Speaker System, Docking...
JRX 125 DJ SPEKER
The JRX series have weak HF drivers, only rated for some 25 watts or so. Are you running in Bi-Amp or straight? Could be bad capacitors in the crossovers. Could also be clipping of your amp, a common cause of failure is using too small an amp and pushing it past it's clean operation limits. Speakers don't like square waves. Was the "Clipping" light flashing on the amp?
Jan 06, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Open Questions:
See all JBL EON 518S Subwoofer Speaker Questions
JBL EON 518S Subwoofer Speaker Logo
90 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
