Question about Whirlpool Refrigerators
CAN'T FIND THE WATER FILTER
    Top Expert:
  • Whirlpool Master
  • 9,472 Answers
What is the model number of the unit?
Posted on Nov 08, 2012
Hurlcon ctx 2hp pump troubleshoot
motor overheating replace pump
May 21, 2017 | Pool & Spa
Chev Impala Air ducting leaks water to the passinger side floor compartment when it rains
Open the hood, remove 2 plastic pins & cover just below the windshield on passenger side. There should be a preformed long rubber gasket that diverts any water away from the cabin filter (regularly replaced) found underneath in the compartment & sometimes the rubber becomes dislodged when changing the cabin filter.
May 22, 2013 | 2005 Chevrolet Impala
I can't depend on it working, sometimes it is great other times it doesn't light.
Intermittent operation is usually a "Flow" problem. Water needs to circulate at a certain amount of water per minute. Most problems are due to restriction of water flow.
Most common problem = Dirty Filter
Backwash on a regular basis for starters.
If a sand filter, sand needs to be replaced on average every 7 years.If a DE filter, then you may need to completely break down your filter and manually remove & clean the grids. Then at reassembly, add the proper amount of DE back into filter by introducing via the skimmer.If a Cartridge filter, then complete break down and manually cleansing the elements. Possibly replacing them if they are older than 4 years old.
Dec 17, 2012 | Pentair Minimax NT Heater
Won't fully spin and alarms nd as a code
You may want to check your drain to be sure there's not a clog/partial clog when draining out the water. Also, you may want to check the filter and possibly clean it. A partially clogged filter may cause this problem. And, you might try...turning off the unit for 10 seconds and turn back on...select Spin Cycle...press Start/Pause to drain the water. Good luck and hope this helps.
Walt
Apr 26, 2012 | Samsung WF218ANB 4.0 Cu. Ft. Front-Load...
Washing machine not filling
really sounds like the inlet servos arent working there and might need of replacement
May 06, 2017 | Washing Machines
How do I access the filter on my LG (LHD659EBL) dehumidifier, how do I clean the filter, and how often should it be cleaned?
To find and remove the filer. First, turn the unit OFF & unplug it. Then remove the water bucket. The filter frame & handle will be located at the top of the bucket holder just behind the front louvers. If you have never removed and cleaned the filter, it may have a piece of plastic tape on it, which was used for shipping. Remove the tape & discard it. Pull the filter frame's tab handle straight down and remove the filter. It can either be vacuumed or if it's really dirty, washed in warm water and a mild dish washing liquid. Rinse thoroughly and shake off any access water. Allow it to dry completely, before reinstalling it. Never operate the unit without the filter in place. Doing so could cause damage to the unit.
Clean the filter at least once every two weeks.
Hope this helped you and thanks for choosing FixYa.
Sep 16, 2011 | LG LHD659EBL Dehumidifier
Hi i am looking for a water filter for an aprox 18 year old ge profile tfx22pr model fridge, not too sure what i need. Any help would be appreciated. Thanks, Stan
i believe what your looking for is a water filter you could add to a 18 y.o. refrig?
Check out this link to see what ya need,it could be purchased from any of the places in that link,OR locally from Sear's Lowe's HomeDepot Ace Hardware...just tellthem you dont have a built in filter on your refrig. and that ya need a kit to add one externally. A tip when installing it is to be sure to install it somewhere where you can easily access it when time to replace filter.
Heres that link for the ones available online
http://www.google.com/search?q=refrigerator+water+filter+kits&sourceid=ie7&rls=com.microsoft:en-us:IE-SearchBox&ie=&oe=&rlz=1I7ACAW_enUS360US360#q=refrigerator+water+filter+kits&rls=com.microsoft:en-us:IE-SearchBox&oe=&rlz=1I7ACAW_enUS360US360&um=1&ie=UTF-8&tbo=u&tbm=shop&source=og&sa=N&hl=en&tab=wf&bav=on.2,or.r_gc.r_pw.&fp=41117172812221dd&biw=1093&bih=538
Aug 22, 2011 | Refrigerators
Hi my F &P dishdrawer unit (DD603) won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Fisher and Paykel Dishwashers
I have a side by side refrigerator & the water filter light is red & the filter needs to be changed. The refrigerator was manufactured 11/04 model # ED26HEXNQ00. I don't know what kind of...
The light will just come on based on time not on if the filter is really need to be changed, you can push and hold the button to reset it, and another six months or so it will light up again. I do not have the same model as you, but mine is in side the ref. top right side, others are on the water line in back.
I have two filters before the refrigerator on mine still go's off I just reset it. If the filter is really needing to be replaced your water would slow to a trickle.
Jun 30, 2011 | Whirlpool Refrigerators
I just ordered and received a 2500 filter, set it up, turned it on, and nothing....motor noise, but no water movement. What am I doing wrong? AS far as I know, I did what I was supposed to. ??? Pools...
1 - Double-check that your water level is above the hose that sends water from your pool to your filter. If the hose has even the tiniest crack, air could be getting sucked in & causing your filter to lose its prime.
2 - If you have not already done so, slowly twist the top of your filter house to loosen it (do this while your unit is on but keep a tight grip on it...once the water pressure hits it, it can push it off completely). You should hear air escaping from the unit. Once water begins coming out, tighten the top back down. Removing the air should 'prime' your filter.
3 - If you've tried this & it didn't work, try putting your filter on a level raised surface (possibly a chair or a sturdy box) at a level about equal to the hose that brings the water from your pool to your filter. Also, try putting it it as far away from your pool as your hoses will allow.
4 - If none of this works, it could be that you have a defective unit. Or, perhaps some other readers will have additional suggestions.
5 - Start saving up. As soon as you are able, purchase a Sand Filter & a Saltwater Chlorine Generator/Saltwater System. I don't know how big your pool is, but mine is 18' x 4' and holds approximately 6000 gallons. The first 3 years I had it, my children & I spent more time cleaning it than swimming in it - literally. (Once we'd shock it, we had to wait 24 hours to swim. By then, it needed a clarifier or ph + or - :-( ) My mom kept telling me that people she worked with had converted to saltwater & were just loving it. I thought that sounded like some sort of lengthy & expensive process & was leary. In the meantime, my sister-in-law was given a sand filter & she raved about what a great difference it made. I began checking online & ebay had the best prices (by far) on the sand filters, but they were still going for about $300 so I waited. My local Wal-Mart had the saltwater chlorinator for $199. It was hard for me to justify paying $500 to convert the pool (especially since I'd gotten the pool at Sam's for only $300 to begin with! Finally, though, I got so sick of having a pool we couldn't enjoy, I did it. I won an auction on a sand filter on ebay for right under $300 and a chlorinator fro $115. I got them in within a couple of days of one another & hooked them up. I got the sand at Lowe's for about $7 & the salt (also at Lowe's) for about $5. I put in the salt & stirred it around with the skimmer-pole. The directions said to wait about 24 hours for the salt to dissolve, but my pool was green & I was tired of waiting so after about 3 hours, I turned on the filter. I let it run for about 5 minutes then turned on & programmed the saltwater chlorinator to operate for 12 hours. That was about 5pm. By the next morning, the water was as clear as when I'd first filled it up. WooHoo!!! That was over 1 year ago & I've just now added my second 40lb bag of salt. Water is still clear - well worth the investment! The only thing I would recommend doing differently is the way I got the saltwater chlorinator. I recommend paying the little extra to get a new one. The one I got off ebay was great - but it only worked for one season. For no apparant reason, about a week ago, I found the power off & could not get it to power on. Wal-Mart has them for $169 this year. Don't know if you have Atwoods where you live, but I just got my new one there for $159. I didn't even hesitate this time...I knew it was more than worth it. No more filter cartriges, no more shock, no more clarifier, no more ph -, no more ph+, no more green water...just a lot more fun in the pool!
Just so you know, in case you do save up & go to sand & saltwater...the filter I got is a 2hp 22" tank. It either pumps 4000 or 5000 gallons per hour - I don't remember for sure which. I do remember, though, that whatever it is, it's 1000 gallons more per hour than the chlorinator specifies but they work GREAT together. I searched ebay for "2hp 22" sand filter" (not in quotes) to narrow down the search results. There are a couple different brands that mostly come up - Hayward & Clearwater, if I remember right. I got a Clearwater, but they probably work the same.
I know you're asking for advice about the filter you already have, so I apologize if the information I've offered is unwelcomed. I just wish I'd switched my pool years earlier than I did. I would have saved a ton of headache, hassle and, in the long run...money.
Jun 20, 2011 | Intex 2010 Easy Set 2500 Gph Swimming Pool...
Refrigerators Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
