Question about Pitney Bowes 460-4 Toner for Imagistics DL200
Where is waste toner located in copier
Need to replace waste toner bottle but can not find in machine
In the past i have found the waste toner bottle is usually the same place as either the toner or the drum (mostly the drum) and will be a clear bottle. Possibly wide at the bottom and thinner at the top.
Hope this helps
Posted on Nov 07, 2012
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
Where is the waste toner bottle on the xerox workcentre 5030 located at?
  1. Open the Waste Toner Bottle Access Door. The door is located on the left hand side of the machine, behind the Bypass Tray.
  2. Pull the colored cap from the top of the bottle and screw the cap onto the opening of the bottle.
  3. Remove the used Waste Toner Bottle and dispose of it according to the instructions contained in the new Waste Toner Bottle box.
  4. Unpack the new bottle from its box.
  5. Install the new bottle in the machine. Make sure that the bottle is placed correctly in the machine cover.
  6. Close the Waste Toner Bottle Access Door.
Mar 30, 2011 | Xerox WorkCentre M-24 Color Copier
How do I replace the waste toner?
The waste toner bottle is just a bottle that the old unused toner falls into. It is located on the right side of your printer. Open the right side door, and the waste toner bottle (which is wide and flat) is in plain view taking up the bottom half of view. It has a sliding lock on top. Slide the lock to 'unlock' and remove it. Replacing it is easy - just reverse and make sure to lock.
Jul 30, 2009 | Ricoh Aficio CL2000N Laser Printer
Where is the waste toner bottle located?
Remove the small cover on the lower left hand side( one screw only) and remove the waste toner bottle and emptied it ensure that bottle neck is not clouded with toner otherwise even the bottle is empty still it will detect waste toner is full .hope this will help
Jul 09, 2009 | Canon imageRUNNER 2000 Copier
Lanier LW324 waste toner bottle full
Open the machine and to the right under the drum you should see the the black powder (toner) going down into container the right lower side  cover must come off. probably a service call will be needed
Apr 20, 2009 | Lanier Office Equipment & Supplies
A message is poping out saying replace the waste toner container.
I'm taking it that you have a IR-2270, not a IR-5570 correct??? The waste toner bottle is behind the front cover... It is in front of the drum unit. It is measured by the weight of the bottle, you just need to empty the bottle and you should be all set.... There is one screw in next to the toner bottle.... The other one is on the top left front corner of where the paper comes out. You have to push the front pannel to the left to remove the cover... Good Luck
Apr 14, 2009 | Canon imageRUNNER 5570 Copier
How to reset waster toner bottle full Xerox 3535
Here's what I did.
Emptied the waste toner cartridge. Left it out of the machine. Held the microswitch (located to the right of the optical sensors) in the "cartridge in" position with a paperclip. Printed one document. Inserted the waste toner cartridge. Error now gone!
GCC.
Aug 27, 2008 | Xerox DocuColor 3535 Copier
Copier
good day, it wont print, coz you must pul the waste toner out. and replace a new waste box.
Jul 21, 2008 | Ricoh FT5832 Copier
Cannon Image Runner 5570
If the copier is indicating to empty waste toner bottle do as previously described. Until you reset the copy counter for the waste toner you will still get the message. Go into service mode by depressing the additional function key, then 2 & 8 at the same time, then aditionall function key. Select copier, then at the top far left side select counter. I blieve the counter is under MISC as waste toner. Select waste toner, depress the " C " buton on the keypad and it should reset to all 0's.
Nov 16, 2007 | Canon imageRUNNER 5570 Copier
IMagerunner 2200 - error E000019-0000
For the people who need clearer information as I did. The toner waste compartment is on the bottom left of the left hand side of the machine. It is to the left of the middle bottom panel which has two small ventholes in it.
Once you open the panel you will see a large plastic bottle which simply pulls out. Empty this and make sure the neck and all areas around the neck are clean. Then place the bottle back in and close up the machine. Done
Oct 18, 2007 | Canon imageRUNNER 2200
Pitney Bowes 460-4 Toner for Imagistics DL200 Logo
119 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
