Question about Brother MFC J220 - multifunction fax / copier / printer / scanner color
How to close ink cover of brother printer? - Brother MFC J220 - multifunction fax / copier / printer / scanner color
SOURCE: Hello can you please help us our printer
hp 2420dn printer showed 50.6 fuser error how to solve this problem
Posted on Jun 19, 2009
xptareq2000
  • 1447 Answers
SOURCE: The Brother DCP 7020 printer displays error
back cover door switch is displace so it called back cover open.
Posted on Nov 22, 2009
sys_admin
  • 829 Answers
SOURCE: Message
This error is due to tray problem check if the back tray latch is not broken .also check the Fuser unit at the back if its not been fixed or loose contact.
Regards.
Posted on Feb 08, 2010
nicarta
  • 506 Answers
SOURCE: " please close ink cover" what is this mean? i'm
This could be that;
The Ink cartridge door is open
The Ink cartridge door sensor is faulty/bad
Something is block the ink cartridge door sensor or the notch that deactives the sensor is broken.
Checkout the door and locate the sensor and manually deactivate the sensor ti confirm the sensor is still working ok. Replace faulty unit approprately.
Posted on Oct 27, 2010
  • 254 Answers
SOURCE: Brother MFC 7420 printer says
hello there
try this remove the toner of the printer and put it back again and closed properly make sure door close and turn off the printer remove the power plug from the outlet and ppower cord from the printer and wait for some time and turn it back on.
thank
Posted on Mar 09, 2011
Why my printer always said cover is open and close ink cover but the ink cover is close and the ink is full?
Hi, Try taking out all cartridges, unplug the printer a few minutes.
re plug , turn on. with ink cover open. then close cover and wait to follow the install prompts, This should reset the printer.
be sure to gently push the cartridges till each one clicks.Close cover.
Please let me know if this helps!
Feb 19, 2015 | Brother MFC 420CN All-In-One InkJet...
Close ink cover
Sir/Madam
If Brother Printer covers may not be completely closed. Then Check Link To Fix Your Brother Printer Error Or
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002400/000011/faq002411_006.html?reg=us&c=us_ot&lang=en&prod=dcpj125_all
Or
www.youtube.com/watch?v=7PfPrt9upb8
In Case You Face Brother Printer Problem Then Folloe Us On
Brother Printer Support
Feb 01, 2013 | Brother Ink for Dcp145c Lc-980
Its showing "close ink cover"
Hi there!
The message "Close Ink Cover" means that the cartridge door is not closed securely.
-please open the ink cartridge cover and make sure all cartridges are installed correctly and then close the cartridge cover. That should clear the message on the screen.
Hope this helps!
May 08, 2011 | Brother DCP 165C Compact Color Inkjet...
My printer is dcp-165c... and have continuous ink ..there is an error that says please close ink cover....what will i do????
Remove the ink cartridge and replace. Make sure it is seated correctly. Make sure the ink cover can close all the way. Restart the printer.
Jan 01, 2011 | Brother DCP 165C Compact Color Inkjet...
The cover for the Ink cartirdges has a switch on it. Try opening the cover, then close it again, the switch may be jammed. Try repeating several times if it does not do anything. If it is still the same case, then someting from the inside of the printer has caused the failure.
Dec 28, 2010 | Brother DCP 165C Compact Color Inkjet...
Error message is causing me fits - won't print
Make sure the top cover is closed as well, Brother has a one year warranty, so it can be repaired at no charge
Jun 30, 2009 | Brother MFC 490cw Color Inkjet...
Brother MFC J220 - multifunction  fax / copier / printer / scanner   color Logo
558 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
