Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Glass top is cracked,ineed to remove it, where are screws holding the frame
  • Official Brand Answer
  • 4,342 Answers
Hello - Usually this type of information is not release to someone who is not a technician (or to a consumer) and it is very rare to find enough information to do it yourself. Typically this is something that you want a certified professional to install for you due to safety and liability reasons. They also usually warranty their labor just in case something else may turn out to be the root cause of your initial problem and it does work out better to your advantage. Consider contacting your manufacturer for more details on who in your area can properly repair/install this part. (part usually have a 30 day warranty with tech). I would suggest contacting your manufacturer to provide you a listing of authorized technicians in your area whom may guide you through this process.
Posted on Nov 09, 2012
We have a whirlpool built in oven MODEL # RBS305PRS00 There are drippings on the inner glass window that I want to get to so I can clean the glass. How do we get to the glass?
Typically, as in ours, there are screws holding the inner door cover on. Look on the back, bottom or sides. These will hold the inner door on, then once removed, observe screws, typically Philips, holding the glass frames together. Careful not to over tighten the frames when reinstalling or you may crack the glass. Do not use a power screw gun either.
Apr 02, 2017 | Whirlpool Ovens
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
Replece glass oven door kitchenaid kebs278dss8
Oven doors have at least two panes of glass (air gap between so little ones touching outer glass do not get burned). You remove the screws around edges of door (top, sides, & bottom) and lift frame up and forward to get outer face off. The glass in ovens is tempered to take heat so you can not just use regular glass. You will find outer piece is sometimes the entire size of door but is painted black with the "dot" pattern that lines up with inner piece. Once you get face / frame off you will usually find the handle screws and mounts for inner glass. Sometimes inner glass sealed with high temp sealant. But make sure you use correct glass or someone could get hurt.
Jan 21, 2015 | KitchenAid Ovens
How to remove oven door. whirlpool
Usually the door dont come off just the front glass comes off for cleaning...there should be two or more screws on the top of the frame of the door when these are removed the glass panel should clip off...you will need to apply some pressure to remove the glass but enough that it starts to bend the door frame...be careful..
Nov 05, 2012 | Ovens
Neff B6774.0GB replace inner glass panel
open the door, loosen the two large screws (t20x or large flat head) near the top of the inner door, this will loosen the main outer door and you can slide it up and off. Look to the hinges and you will see retaining brackets held with two t20x screws, remove these and you then slide the rest of the door off enabling you to work on it on a flat surface. Lie it down with the broken glass as the lowest part. Remove two t20x screws from the two plastic holders near the top of middle frame, slide them out and remove the middle angled frame. Pay attention to which groove in the bottom of the door they are positioned for reassembly. You are now faced with a frame with absolutely mountains of t20x screws which will all have to be removed. when this is done, lift off the frame and you are left with the inner frame, broken glass and mesh panel. carefully take off the mesh screen and discard the broken glass ensuring that you do not inadvertently throw away the black thin seal (looks like a large rubber band). Use a toothbrush to ensure all glass is removed from the inner frame and that the inner edge of the frame is free from food debris etc (This is probably what caused the glass to shatter as the microwaves are attracted to food debris and would have cooked the glass causing a hotspot, this is usually evident if you look at the starting point of where the glass broke). Give the seal a clean also and reposition in the groove around the inner edge of the first frame. position the new glass panel, position the mesh screen and the middle frame. When putting all the screws back in, alternate them. left right top bottom until they are all back in (do not over tighten). Then reassembled the rest of the door by reversing the dismantling info. Let me know how you get on, please leave some feedback.
Nov 22, 2011 | Neff Ovens
The glass top cracked, can I replace it?
Hello. Yes you can replace it. You need to remove the control assy. Open the oven door, at the bottom of the control assy there are 5 screws, remove those. Now pull off the knobs and unscrew the retaining rings around the switch shafts, should be 3 plastic and one brass. Remove the panel and set aside. Remove the screws holding the metal plate on, should be 4 black 1/4 inch screws. Once those screws are removed, pull the whole panel out and let hang down. This will have all your switches and erc control on it. Now there are 4 more screws that hold the front of the cooktop, unscrew those, disconnect the 2 wire harnesses at the connectors, pull the cooktop twards you and up and it will come right off. FYI some models have 2 screws in the back to hold the cooktop to the rear, but some don't. Now just reverse directions and your ready to go. Joe
Aug 18, 2010 | GE Profile JTP18 Electric Single Oven
I have a cracked glass on my maytag built-in stove top. where do I find the serial and model numbers? How do I remove top? Thank you.
The model tag is on the frame in the front behind the access panel. To change the glass is no easy task. there are screws along the sides(unit must be pulled out and in the front. The burners are attached to it and there is many a opportunity to cause more damage or injure yourself. Good luck
Jul 30, 2010 | Maytag Ovens
How to clean the inside of the glass door of Electrolux Wall Oven
I scoured the internet trying to find how to clean inside the glass of my Electolux Icon double wall ovens. Short of "The Big Q-tip" method (which only made a smeared mess) I didn't find anything. So I went ahead and started taking the doors apart. I'm happy to report I just finished with fantastic results. So I'm going to do a step by step, I know I would have appreciated reading instructions for it. It's very easy but time consuming. You'll need a large work area because there are actually 4 sheets of glass, a Philips screwdriver, and a straight razor with handle.
Refer to your manual on how to take the doors off - but it's very easy. Simply open the door, flip the locks toward you and pull up and out at the same time. Be careful...the door is very heavy.
Lay door on blanket or towel, especially if it's stainless steel. There are 4 screws along each side of the door. The 2 screws that hold the hinge at the bottom are smaller than the 2 closer to the top.
On the very bottom there are two more screws to hold the bottom outer frame. Under that piece are 2 more screws that hold the inner bottom frame. That's it. Slide out the hinges and you're ready to go.
Remove those 2 frame pieces and keep in mind how they fit back together. Remove the top piece of glass and put on another towel. Now I'm not sure if it matters but I was mindful of the side of each piece of glass as I remove and cleaned them to make sure they went back exactly as they came out.
The first piece is going to be the most time consuming to clean. One took me over an hour. The grease is hard to get off because it just spreads around. I found a straight razor really sped this along, just make sure you always use the razor on wet glass or you'll scratch the glass. It's fiddly...just keep at it. I also used mineral spirits to help degrease. When done I laid this on the dining table.
The next 2 pieces of glass are in a frame that comes out together. The frame is only on the sides so be careful it doesn't come apart on you when carrying it. Inside the frame piece is a rubber gasket to separate the 2 pieces of glass. Watch how the frame comes off, there is a wide and a narrow side. It's easier to take off the frame piece and simply lift of the first piece of glass. The bottom piece of glass sits in a channel of the rubber gasket.
Pretty simple. Lots of elbow grease if you cook a lot. Reverse the order to reassemble. One thing to note - on the door sides near the top, you'll see a silver metal piece inside the black frame. Make sure the screw holes are visible thru the black frame. I have very small fingers so it was easy to do it with my fingers but I would imagine someone with large hands will have some difficulty. Also, when screwing the hinge in place I had to twist the hinge so the screw hold was up against the black frame. The screws are so short that they'll just spin without catching if you don't.
Happy cleaning!
Mar 21, 2009 | Electrolux EW30EW65SS Stainless Steel...
Remove Outer Glass Of Oven Door
On my Zanussi ZDF 866 it goes like this:-
Rest the door with its top edge on your work surface. Once the bottom two screws are removed, pull the outer glass away from the bottom edge of the door just enough so that the brackets fixed to the outer glass (into which those two screws went) clear the bottom edge of the door. Then pull the outer glass up towards you parallel to the door (there are now screws hoplding the top edge on this model).
It may need one side to be pulled and then the other to release it from the metal slot at the bottom.
I would recommend great care with this given that a) your door may be different, b) it could be held more tightly and c) you are dealing with glass. Recommend taking all precautions including eye protection and suitable gloves. Proceed slowly and carefully (this did not need much force on my door). If you're not sure at any stage, choose discretion and either give up or pay someone to do the job to avoid paying for a new glass or hurting yourself.
Hope this may help someone.
Jan 25, 2008 | Ovens
How to Repair the internal glass in the door
it can be fixed by removing the door. Open the door and try to lift upwards. When the door has come out, dismantle it by removing the screws and when you can reach the glass frame, measure the size of the glass reqd. The glass can be bought from any glass dealer by giving the correct size. Make sure if the glass has to be tapered at the corners. When it is received, you can reassemble it yourself
Jan 15, 2007 | Whirlpool RBS245PD Electric Single Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
21 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
