Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Changed the batters in my remote it worked one time then stopped and not does not work at all except the button on the wall does work .........Help !
  • jarrett08270 Jan 12, 2009
    same issue, the wall opener inside the garage works fine but the remotes stop working when the weather gets cold. We just changed the batteries so I know that isn't the issue plus the remotes work fine on warmer days.
    Champion:
  • 244 Answers
You can keep changing batteries! Seriously, do you have other remotes. do they work? do you have a LOCK or VACATION switch on wall control . turn it off.
Posted on Jan 15, 2009
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Lift Master remote does not work. The wall mounted unit will open and close the door, but the remote control does not. I've changed the battery with a 1a battery from Radio Shack- but it still won't...
Check the wall console. If it has a lock button and the LED is flashing, the GDO is locked. None of the remotes will work, only the wall button. If it is locked, press the lock button and hold for a couple seconds and release. The LED should stop flashing, and the remotes should start to work.
If the door will open but not close, and the lights flash 5 times, check the door sensors. Make sure the sensors are aligned with each other, and the LEDs are both on.
Jan 11, 2011 | liftmaster 373lm Liftmaster Craftsman...
My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/3 HP. Remote and wireless keypad stopped working.
Sounds like the reciever for you wireless devices is not working?
Vizio remote control not working
Wow, I feel stupid! Solution #2 did it! There are 2 Tv buttons, one on the top right and one on bottom right. You have to press the bottom one!! THANK YOU PPL!!!
Apr 04, 2009 | Vizio VO47L 47 in. LCD TV
My remote stopped working
Removing The Batteries Should Reset The Remote Try Removing The Battering And Holding The Power Button For 30 Seconds And Then Retry It.
Jan 07, 2009 | Akai LCT3201TD 32 in. LCD Television
Remote only closes the garage door, will not open it
Anytime a door opens and/or closes randomly or doesn’t work consistently I look for a smashed wire between the motor unit and the wall button.
If the wire is smashed the insulation becomes so thin that power will leak thru the insulation and activate the door or interfere with the remote signal.
Loosen the staples with a small screwdriver and slide the wire about ½ inch to move any areas of thin insulation away from the staples.
The second thing would be a bad wall button or a remote with a sticking button.
Or a remote in someone’s purse that gets the button pushed by other stuff in the purse.
The test is to disconnect the push button wires at the power unit. If the self operation / interference stops you have located the problem. If you reconnect the wires and disconnect the wire at the wall button this will tell you if the problem is the wire or the button.
In your case the expansion of the wall in the afternoon may be enough to cause pressure on the wire to increase the problem – works in the morning but not the afternoon.
Also after you change the batteries you need to reprogram the remotes.
HOPE THIS HELPS
Aug 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Wii remote controller not fully funtional
in baseball you have to hold it beside your head and in bowling you have to raise your WII control up and realese th B button(hold B button than do instruction)(not for the Baseball game)
Jan 02, 2008 | Nintendo Wii Console
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
70 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
