Question about Amana Refrigerators
Replying to Richaed Roth - Amana ARB2557CSR Defrost timer. diagram from online source shows timer on the inside of the frig box near the lights. I've not done anything yet to verify te location a
    Top Expert:
  • Amana Master
  • 9,472 Answers
OK, you can open the cover. Here is the part if you need it.
Here is a diagram if you should also need it. It is number 12 on the diagram. Let me know if you need anything further. I forgot what the original question was.
Posted on Nov 08, 2012
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: is there a video showing how to replace the defrost timer in an Amana model ARB2557CSR
Does your unit have the defrost timer inside or is it under the kickplate?
Posted on Nov 07, 2012
richroth
  • 9472 Answers
SOURCE: amana model ARB2557CSR, defrost timer replacement instruction and video
See other post.
Our Amana has a reocurring defrost problem where the back of the freezer clogs with ice every three weeks. Is there anything we can do?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 10, 2010 | Amana ARB2557CSR / ARB2557CSL Bottom...
Defrost timer went bad. How do I manually bypass the timer?
IF ITS A DEFROST TIMER AND NOT A BORD THE WIRES ARE HEATER POWER COMPRESSOR THEN NEUTRAL IS ALONE.
I I I I
HPC N
GOOD LUCK!
ERIC
Jan 17, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Auto defrost is broken
Find the defrost timer and turn it with a screw driver (will only go clockwise) until it clicks.n wait 10-15 min. If the defrost starts to work (Freezer will get warmer heaters kick on) the timer is bad. If not you will need to check the deforst heater (behind back panel of freezer) and thermostat (silver cylinder with 2 wires on the evap coil) The timer is eithr under the box behind the kick plate (clean the coil while you are there) inside the refrigerator (look in the top for a small hole with a funny knob) or back behind the frig near the compressor( clean here as well).
If it goes into defrost and defrosts, rotate the timer until it clicks again and the compressor should start again.
Most GE's have a diagram on the back that shows componet locations
Sep 22, 2009 | GE Refrigerators
Just stopped working: plugged in,light on,fan blows in freezer-
defrost timer probably failed in defrost mode go online search for defrost timer location and manually advancing or initiating a defrost cycle , it may pop into run mode and tell you thats what it is , 90% of the time thats it and they are cheap !
Aug 23, 2009 | Amana ABB1927DE Bottom Freezer...
I've a Amana ARB1917 and I want to know where is timer defrost ??
The defrost timer for the unit is located under the fridge in front or back. Depends on model. A few put them inside the fridge. Russ
Jul 18, 2009 | Amana ARB1917CSR Bottom Freezer...
Fan is not working and fridge is not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
ARHGADF
Jun 03, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
MATAG FRIG PTB2153GR FREEZER DOES NOT GET COLDER THAN 38 DEGREES F
Try turning the defrost timer clockwise until you hear it click. If defrost element and defrost thermostat are working properly, the refrigerator should begin to defrost. The timer is located inside the fresh food compartment behind plastic controls cover and also near the thermistat control.beb686d.jpg .I will be around if you need, just let me know,Sea Breeze
Mar 23, 2009 | Maytag Refrigerators
Amana refrigerator warm
Chances are if they are getting cool but not cold-
1) the evaporator fan in the freezer is not running
2) Defrost heater has failed
3) Defrost sensor has failed
4) Defrost timer/refrigerator control has failed.
Check for ice build-up on the back wall of the freezer. If there is ice, unplug or turn the unit off for 6-8 hours with the doors open (put any food in a cooler with ice to maintain). Note water may come out of the refrigerator.
Plug the unit back in or turn it back on, close the doors, and check temperature after a couple of hours of operation. If all OK, you will need to have the above tested, or, if you know how to use a multimeter and can read a schematic/wiring diagram, I can instruct you on how to check the above.
Jan 20, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
91 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
