Question about Nespresso Aeroccino Automatic Milk Frother
Whisk won't spin
I believe the magnet is affected. It will spin for a bit then stop but restart if I give it a nudge.
What are the parts of the central ''spinner'' of a milk frother?
There are no moving parts in the frother other than the whisk assembly. The whisk assembly is spun magnetically. I am not sure if it is possible to have the magnet in the whisk assembly in the wrong orientation, but if so, be sure that it is reassembled with the magnet side down. Additionally, if I haven't removed the whisk in a while (I normally just immediately rinse and wipe the interior with a cloth) then the metal stem can build up with milk solids... and cause the whish to "stick"... the magnetic force is not exceptionally strong and it could be that the plastic assembly is "sticking" on the metal post... pull off the whisk and give the post a good wiping with a wet cloth to remove any possible residue.
Jul 24, 2014 | Nespresso Aeroccino Automatic Milk Frother
Technics sl 1210
you might try lifting the platter off and putting a drop or two of light machine oil on the spindle. cleaning the motor might help also.
Jun 27, 2013 | Audio Players & Recorders
The CD door or drawer won't close properly with out giving it a nudge just before it suppose to close, other wise its ajar just slightly!
I have had a couple of drives with that symptom. Tried cleaning the guide rails and applying a drop of silicone lube to the rails. No change. Concluded the little motor was becoming too weak to close the tray, so back to the nudge and hope routine
Apr 20, 2013 | Crosley CR78 CD Shelf System
My whirlpool amw8121 front loader won't spin. It
There should be a door-actuated limit switch which detects that the door is closed, which is probably defective. Look for the plunger, listen for the click. It is the most likely component to fail, and is inexpensive to replace if you're handy. Be sure to have your machine unplugged during repairs.
Sep 04, 2012 | Washing Machines
I just inherited (literally) a virtually new eMachine 786N monitor. I say, "new" because the previous owner probably logged no more that 100-200 hours on the thing. Hooked it uop to my HP...
Sounds like symptoms that the monitor needed to be degaussed (pronounced "Dee' Gowsed"),
and, since most modern (conventional CRT) monitors will degauss themselves upon power-up,
it looks like your restart addressed the problem.
Usually, a CRT that need to be degaussed will develop blurring at the edges first, but its possible
that the monitor was affected by stray magnetic field(s) over time, and failed to successfully
degauss at initial startup (the degaussing circuit won't necessarily succeed the first time if a large magnetic field has built up).
Here's your wikipedia entry on the concept:
http://en.wikipedia.org/wiki/Degaussing
Here's a how-to, in case you want to (or end up needing to) do it manually:
pcsupport.about.com/od/fixtheproblem/ht/degauss.htm
It looks like a .PDF service manual may be available free here:
http://fileshare.eshop.bg/downloadsm/30014/PROVIEW_PROVIEW%20786N.html
Sep 14, 2011 | Mag Innovision InnoVision 786 PF 17" CRT...
Washer pumps but half the time it won't spin unless you give the basket a little push. I use a small magnet to keep the lid relay closed. Once I give the basket a little push, the washer starts to...
Quite likely the spin motor is a capacitor start type motor and has a capacitor to start it (by placing a winding slightly out of phase with the rest of the motor in turn encouraging the movement of the motor). When it reaches about 200 RPM the capacitor is disconnected and runs without it.
Maybe the start capacitor is faulty or the internal switch/electronic control is faulty?
Aug 30, 2011 | GE WPRB8050D Top Load Washer
My elna sewing machine bobbin won't spin on top to wind thread around. The fly wheel spins though...I've been putting thread on the bobbins by hand.
If the fly wheel is going around then the clutch isn't disengaged to wind the bobbin, you need to pull out the flywheel on your model to disengage the clutch for bobbin winding.
Take thread from thread spool across to bobbin winder thread guide, then back to bobbin and thread the tail through the hole on top of the bobbin. Place bobbin onto spindle on top of machine and then push it against the stop to engage the bobbin winding motor. HOld the thread tail up and start winding slowly until the bobbin core has been covered including the starting point. Stop and trim off the thread tail with scissors. COntinue winding bobbin and give the thread a nudge if needed to wind evening top middle and bottom of the bobbin. A good smooth wind is important. Also don't wind at full speed and keep an eye on the thread reel that the thread is coming off, you don't want it bouncing around as this will **** the thread and stretch then relax it affecting your bobbin wind.
Obviously if you know this and the bobbin winding mechanisim is just not working, then it will need a service/replacement by an Elna repair person.
Aug 01, 2011 | Elna 2007 Mechanical Sewing Machine
The marbles go up the tower just fine, but most of the time they all get backed up at the first magnet. sometimes the 2nd or 3rd marble will hit hard enough to push to first one out, but most of the time...
What I did was spread the first magnet block apart from the track part underneath it slightly. I used my thumbs to bend them a apart a little more. Now each ball gets slowed down but not stopped by the top magnet, I didn't do anything to the down side magnet and the balls pass right through.
Of course just don't use too much strength. It just takes a little more separation.
Dec 22, 2010 | Dmm Mega Brands Magnext iCoaster
Nespresso Aeroccino Automatic Milk Frother Logo
138 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
