Disc drawer will not open and keeps displaying "locked". Checked manual and there is nothing listed to fix this problem
  • 4 Answers
Hi ! Sounds like a bad drive belt
Good luck , Stefan from Sweden
Posted on Jan 05, 2009
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
Nov 24, 2013 | Sony BRAVIA DAV-HDX267W Theater System...
I have a Samsung SER 6500 II cash register is locked on the error code ERR PRT. I have checked the ribbon and receipt feed area. Nothing blocking it...I've done an intial clear to no avail.
Sounds like you have printer failure. Have you tried flicking the lever under the drawer between the back two feet to open it?
If anyone is having problems with Programming on the Samsung SER-6500II cash register, the manual is here:
http://the-checkout-tech.com/manuals/cashregisters/Samsung3.php
Sep 03, 2012 | Casio Parts Cash Register PC Desktop
Disc drawer will not open with either the button on the set or the remote control. Display shows "open" the changes to "no disc"
Jan 19, 2010 | Televison & Video
I cannot retrieve a DVD disc. Disc drawer is locked.
The best course of action, if the dvd drawer will not open, is to either remove the case and dis assemble the dvd drive to retrieve your dvd or otherwise u can take it to a authorised sharp agent and they can retrieve it for you, keeping in mind the problem reported you have caused, so u will pay for repairs in a normal cicumstance, as they do not cover mistakes like this.
Nov 07, 2009 | Sharp AQUOS Blu-ray Disc Player
After self cleaning,i noticed the lock light blinking,the door opens but when i try to use the oven dr is displayed on the screen and nothing functions. (Kenmore warm and ready drawer-self cleaning ov
This is a Door lock malfunction. you will need to replace the door lock mechanism. it is faulty.
Test the door lock mech for its operational value to be sure.if the door mech test is good, replace the control(ERC/Clock)
Jun 03, 2009 | Ovens
LG HT503PH Disc drawer will not open and displays "locked"
there should be a key synbol on the remote. press pwr off, then press the pwr on and the key button at the same time. The usual fault is the child lock has been activated.
Jan 05, 2009 | LG Televison & Video
I cannot open the DVD drawer on my Philips DVDR3480 DVD RECORDER – it just won’t open? The screen display just keeps saying ‘Error’. Any help is appreciated.
I have two of these dvd recorders and both have the exact same problem where the drive won't open. It opens fine when there is a disc in the tray. So I just unscrewed the cover, press the white part which would be over the center of the disc as it's trying to open, it should then open. Then just make sure there is always disc left in the tray.
Nov 26, 2008 | Philips Televison & Video
DMR-E50 won't eject disc.
Nope sorry no quicky fix here
Sep 19, 2006 | Panasonic DMR-E50 DVD Recorder
Akai DVD recorder tray will not open
I am pursuing the exact problem above. I have found a not so hi tech solution. I firmly rap on the top above the disc drawer. This is while Close is being displayed and the drawer is in. If you hear some spinning and load displays it should now work. It may be back to cycling again on the next ejection though.
Technically I figure it may be a sticky magnetic reed switch or what ever they use to detect the drawer position. Mine displays either open or close when it starts to cycle.
Aug 08, 2006 | Akai DVDRW120 DVD Recorder
26 people viewed this question
 Grubhead
Grubhead
