Question about Emerson NR303TT CD Shelf System
Emerson NR 303TT Table only turns when the tone arm is in one spot
If I hold the tone arm about 1" outside or away from the turn table out to the side of it the table will turn if I move it at all either direction it stops turning? any help will be greatly appreciated, Thank You
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 22 Answers
There is a mechanical switch inside the unit. You will have to open her up and reposition the switch.
Posted on Dec 01, 2012
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
I need to block certain extensions from being able to dial long distance
Best way to do that is to sit down with the manual and look at programs 400-408. At a minimum, if you restrict 1 and 0 in a table and assign it to your extensons in 405, those phones can't dial long distance. That's fairly worthless in today's calling climate when some carriers let you dial just 10 digits or you have to dial 1 for any local call outside your area code. 404 lets you build 8 tables of 10 number sequences each for restriction and 407 lets you build 8 tables of 10 number sequences for allow. For example You could put 1 HOLD HOLD HOLD (hold is the wildcard) in one table and entry of 404 with traditional dialing and that would restrict all 1+ long distance. Then, in 407 5 of your entries in one table would be 1800, 1888, 1877, 1866 and 1855 to allow toll free calling. These tables get assigned to extensions in programs 405 and 408. A simple restriction (ie local calls only, internal calls only) get assigned in 401. There are some other tricks and, above all, remember that you have to keep 911 availabe for access and allowing 0 is never a good idea because 0 alone will get the operator and that defeats the purpose of toll restriction.
Other tricks involve custom CLASS codes. You need to account for the clever worker who dial *67. That gives them second dial tone and they can dial the world. It would be easy if you could block first digit *, but you ought to allow *57 for nuisance call trace. If you have the above where long distance is dialed with only 10 digits, then you can always start with HOLD HOLD HOLD in a table and allow 911 and the local area code in an allow table. The table digits can be up to 12 so you may have to go to 6 digit screening in allow tables for local exchanges. In my area, we have 10 digit dialing and 419352 419353 419354 (among others) along with 567213 are local calls. If I were programming a customer 6 miles to the North, there would be extensive programming in both area codes.
Outside of that, it's just a function of analyzing your local calls, area codes, how a call is dialed, and building your tables. We do this with billing by the hour :-)
Carl
Apr 07, 2011 | Lucent PARTNER18 Corded Phone
We have a emmerson micro and the turn table cluncks
Problem fixed. Called number on micro and they were great in fixing the problem.
Oct 28, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Hi. I'm have a problem with my Technics SL-BD20 turn table I've just purchased. When putting the arm onto the LP it just skips over the surface to the middle. Why does it do that? Cheers.
Try adjusting the tone arm weight so that the arm will be slightly heavier.
If this does not help, see if the tone arm manual lift handle is operational and fully released when the arm sits on the record.
Another possible cause are the tone arm position sensors inside the unit.
Hope you can fix it.
regards
Triarcuate
Oct 01, 2009 | Audio Players & Recorders
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Replacement table mount
Contact emerson, via web site or call.
Apr 12, 2009 | Emerson LC320EM8 32 in. LCD TV
Technics SL-5 Turntable will not turn.
try gently pushing the tone arm (actually the piece of plastic holding the tone arm) over to the right a little. works for me, but it still gets stuck often
Apr 06, 2009 | Audio Players & Recorders
Feedback coming from table at -40db. I think is linked to ground?
i would say its most probally an earth fault somewear but changingt the gnd leads an rca cables might be worth a try as its defenatly not your mixer.gd luck
Mar 20, 2009 | Numark Pro TT-2 Turntable
Technics turn table
under the tone arm next to the lever ther is a sort of plastic bar which lifts the tone arm when lever is up right, look along that bar and there is a screw which you turn as you would to tighten anything.you will see the bar move down,try again and if you still have the same problem repeat the process till done......
Jul 03, 2008 | Technics SL-1210 Turntable
Hoe do operate the turn table
Lift the arm off the stand and manually move it to the center of the player. You should hear a click and the turntable will begin spinning. To turn it off move the arm to the outside until you hear a click.
Nov 13, 2007 | Philco (R) 841.205 CD Shelf System
Emerson NR303TT CD Shelf System Logo
139 people viewed this question
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
