Question about Acer Aspire 5100 Notebook
Video My vidieo delays when I attempt to look at utobe.
  • 4 more comments
  • vman1342 Jan 05, 2009
    I checked the video settings and they have not been changed and it does happen with other videos.
    yes it's a 5102wlmi and the vidio cards came already installed.
    I don't see task manager?
    In task manger were do you locate the amount of memory and what is taking up space?
    In task manager were do you locate the amount of memory that is availble?
    Scholar:
  • 100 Answers
Its either a
1. slow internet connection 256KBps or less
2. right click on the video choose settings then folder icon and increase the size of memory that Youtube can store on you PC, make it 10MB.
I hope it works :)
Posted on Jan 05, 2009
  • Anas Al-Mustafa
    Anas Al-Mustafa Jan 05, 2009
    to increase Virtual memory RAM:
    1. right click on my computer
    2. select properties
    3. select Advanced
    4. Performance ---> Settings
    5. on visual effects ----> select Adjust for best performance
    6. then select Advanced Tab go to Virtual Memory ----> click change
    7. select system managed size then apply
    good luck. if your PC is P4 and has 1GB RAM or more, you shouldnt have to do that. but anyway it will make your PC faster.
    i hope this helepd :)
  • 565 Answers
Try to restart your wifi router or connection and also install http://fpdownload.macromedia.com/get/flashplayer/current/install_flash_player.exe - new macromedia. its mostly because the internet connection is slow. sometimes its the problem of video drivers and flash, buut mostly connectuon is the bad apple.
    Brigadier General:
  • 5,158 Answers
Combination of not enough memory and spyware can cause that. can't help you with the memory other then having you reduce your startup programs... spyware is best handled by spybot s&d... download it install it and update it.. do a scan and remove any spyware it finds
  • Acer Master
  • 19,396 Answers
    Brigadier General:
  • 8,619 Answers
Hi! YOutube uses flash video files(flv) that require flash player. Sometimes due to older version of flash player the videos don't play good. try downloading latest flash player from the link-
http://www.adobe.com/products/flashplayer/
http://www.macromedia.com/software/flash/about/
    Sergeant:
    Scholar:
  • 199 Answers
Its the cause of internet getting slow speed at partcular time check out this same video at any other time.when there is a less usage of internet.
    Scholar:
  • 96 Answers
Nine times out of ten, delays in viewing streaming video on the internet is purelly down to lack of speed on your internet connection.
2mb/s is really the lowest you can go to expect to play Youtube videos correctly without "buffering".
Even if you are paying for a faster connection it's worht checking the actual speed. Try a speed test at :
http://www.speedtest.net
    President:
  • 2,110 Answers
You must have slow internet connection...You need to take a new highspeed connection...
    President:
  • 846 Answers
Can you be more specific about the delay.
Does it take a few moments before it starts playing a video ?
You might want to update your flash player GET HERE thats the newest version install that.
Also what webbrowser are you using Internet explorer ? Mozilla Firefox ?
  • Quickfx PC Repair Jan 05, 2009
    Try not running to many programs at once watch your system resources CPU, MEMORY
    ( Cntrl + Alt + Del ) then click Performance
    Make sure all your drivers are updated, try using mozilla firefox instead of Internet Explorer if that is what your using.
    I hope this will help you. Drop me a comment if you still have problems. I will help you.Your vote is highly be appreciated.
    Genius:
  • 1,913 Answers
Restart your router.
remove all tramprsary internet files and cookies.
also add utobe sites in trusted zone in internet explorer tools internet option then security trusted zone.add this sites in trusted zone then set low security to this zone then apply and ok.
  • kishor khatri
    kishor khatri Jan 05, 2009
    restar your router also reset al connectin of router clean dust from each cables.
    Genius:
  • 1,550 Answers
You need to see the usage of memory in your pc . If the cpu usage is more then there will be delay in the video . Remove the program consuming more cpu usage . In task manager you can see the cpu usage .
  • 679 Answers
you need a new high memory display card or install direct x new version
  • 2 more comments
  • rockfixya
    rockfixya Jan 05, 2009
    download direct x from:http://www.gamesforwindows.com/en-US/Abo...
    and after download install tham.
    Thanks for using FixYa
  • rockfixya
    did u tryed installing direct x
  • rockfixya
    try to upgrade ram memory to your system.
  • rockfixya
    rockfixya Jan 07, 2009
    go for the link to know --
    http://www.aumha.org/win5/a/xpvm.php
    Thanks for using FixYa.
  • Acer Master
  • 13,433 Answers
Are the video card drivers installed? is your laptop aspire 5100?
you can download and install the driver from this page
http://support.acer-euro.com/drivers/notebook/as_5100.html
    Sergeant:
    Novelist:
  • 326 Answers
Did you changed any video setting.also try checking any other video other then this which is delaying.
Will i be able to upload vidieos from my ps3 to youtube
That all depends if the paticualr game you are playing has that as a feature. Like Black ops 2 has a youtube exclusive channel for players to upload their videos.
Aug 01, 2014 | Sony Playstation 3 (PS3) Console
How do i delete my youtube
Log onto the account from which you uploaded the video.
Click the thumbnail near the Upload button on the top right corner of the page. > Creator studio > open Video Manager from the panel on the left. > find the video you want to delete > click on the drop down arrow next to Edit.> select Delete.
Jul 18, 2014 | YouTube Videos
My imac 2011 is buffering severely when watching vidieos
This is likely from your internet connection. You will want to find out what speed your internet connection is. Also try watching the videos in 480 definition. Not HD.
Apr 20, 2014 | Apple iMac Computers & Internet
While opening music player&vidieos it shows not enough memory
May be your songs and videos are in phone memory and it may be full,so move all the songs and videos from phone memory to memory card.Check memory status also.
This might solve your problem!
Mar 11, 2011 | Nokia 5310 Cellular Phone
I cannot open utobe popthatzit
YOU MAY NEED TO UPDATE YOUR FLASH.OR TRY AND INSTALL OR UPDATE ADOBE.MAKE SURE POP UPS ARE NOT BEING BLOCKED.
SHERRI
Feb 07, 2011 | YouTube Videos
It, takes forever to play a vidieo. Then the replay works normal.
You might want to get a faster internet connection to play the videos, alternatively you can reduce the quality of the video and make it load quicker, alternatively you can also download youtube downloader at http://www.downloads.com and download the whole video before you watch it.
Oct 27, 2010 | YouTube Videos
Downloading problem
Which Operating System are you using? Do you get any error messages when trying to save the videos, software, songs?
Dec 10, 2009 | Computers & Internet
Can you help me get my vidieo from my hitachi 3300A to my computer ?
Probably Your videos are storing in a DVD. So open the DVD from your camera and insert it to your computer's DVD ROM drive. Explore your my computer , select video files , copy and paste. Thanks. Pls vote.
Jan 18, 2009 | Computers & Internet
Gh world tour mic has terrible lag
Yes, unfortunately, USB ports just aren't fast enough for live vocals. Some stereo setups have longer lag times than others, as well. A couple of ms is very noticeable. Have you tried adjusting the settings on the game? Go to "Options" on the Home Screen and select "Calibrate Lag." Here you can delay either your Audio or your Video in 1 ms increments to try to adjust for lag times. You may find a happy medium after adjusting these settings.
Dec 28, 2008 | Activision Guitar Hero World Tour Guitar...
Cant get any picture through the moniter tryed agp vidieo card and pci vidieo card still nothing the motherboard is out of emachines c2280 L7VMM2
Sounds like you have a bad power supply or motherboard. The power supplies in eMachines are not known for reliability, so try testing the system with another one. If you still have no video, you should replace the motherboard.
Dec 13, 2008 | EliteGroup L7VMM2 Motherboard
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
