Question about Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range
How do I change the beeper sound on the timer
  • elspeth141
    elspeth141 Nov 09, 2012
    I know it is possible to change the volume level of the timers beeper as I have done it before. It involves pressing a combinatin of the buttons but I cannot remember which ones>
When buttons are pushed, no beeping. even when timer is set to go off, no signal that the time has expired
If all other functions are working and you just lost the beep sound then you have to make this choice. The beeper is actually mounted on the main control board. If it has gone bad--the only way to fix it is to replace the complete main control board which is an expensive part. One thing to check in your owners manual is if your control has a way to change the sound level of the beeper. If yes--it may have accidentally got shut off if it has that type settings.
Jun 16, 2015 | GE JTP75 Electric Double Oven
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
Fmp rimer 151-7500 how to change volume of beeper
There does not appear to be a way to adjust the volume of the timer.
Oct 06, 2013 | Franklin Machine Products FMP 151-7500 7...
My timer does not beep when time is up?
This sounds like either a defective piezo beeper or bad solder. Your range should beep as you set cooking time but not when you set the clock. If no beep is heard, then your timer and clock board have a defect, and should be covered under warranty if this is a new range. It is the same beeper device for the alarm, and is quite easy to hear.
Mar 24, 2010 | Whirlpool GR448LXPQ Electric Kitchen Range
Want to shoot a timed pictures ie, a pic of myself and my sister together and me setting the camera on a timer and getting into the pic...what do I do? Don't have manual with me. I have a Canon EOS 40D
Did you know there are two firmware updates available for your camera? For a timer picture, here are the instructions: 1Press the <o> button. (
9)
2Select either <j> or <l>.
Look at the LCD panel and turn the
<5> dial to select <j> or <l>.
j:10-sec. self-timer
l:2-sec. self-timerN
3Take the picture.
Focus the subject and press the
shutter button completely.
The picture will be taken after the
self-timer delay elapses.
You can check the self-timer
operation with the self-timer lamp,
beeper, and countdown display (in
seconds) on the LCD panel.
Two seconds before the picture is
taken, the self-timer lamp will stay on
and the beeper will sound faster.
Do not stand in front of the camera when you press the shutter button to
start the self-timer. Doing so will throw off the focus.
Feb 02, 2010 | Cameras
Timer beeper failure on Whirlpool Gold oven/range oven
Most of the beepers I am familiar with are built into the main control clock board assembly. The only way to repair this is to replace the whole main control board, not a cheap part.
Jan 10, 2010 | Whirlpool GY396 Electric Kitchen Range
Clock timer volume too low
The beeper sound level can be adjusted.
Press the "BEEPER VOLUME" pad on the keypad, then select 0–3 for mute to loud.
Your owner's manual is here.
Jan 17, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Casio SPF 40 beeper not working after battery change
There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
regards,
Pieter
Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
Resetting sound
Could the jeweler have inadvertently damaged the beeper in the watch when he changed the battery? I'd tell hime the problem, ask him to restore the sound and see what he says ("oops" is a bad sign).
Lenny
Feb 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Belling CookCenter 151 Dual Fuel (Electric and Gas) Kitchen Range Logo
87 people viewed this question
Top Belling Kitchen Ranges Experts
Paul Carew
John Tripp
John Tripp
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Belling Kitchen Range Expert? Answer questions, earn points and help others
