Question about Whirlpool Washing Machines
I have a whirlpool washing machine no awm323 the water is not heating
Where would i find the thermostat
  • 3 Answers
Ask your dealer about technical service of that brand and call them. If this fault, you can also look for the thermostat (if you are sure that it is the problem) in the internet. You need to know the number part or maybe enough with brand and model of machine.
Good luck.
Posted on Nov 07, 2012
  • 40 Answers
SOURCE: washing machine not heating water
yes it will work but unless you have hot water going into the machine there will never be hot water there but you can just use it with cold water will not hurt anything just no hot water
Posted on Mar 10, 2009
SOURCE: whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Posted on Sep 12, 2009
  • 691 Answers
the drive belt may have gone or the brushes on the motor if it's old could be something to do with the controller but look to motor and blt first
Posted on Jan 10, 2010
Testimonial: "hreat help"
SOURCE: Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Posted on Apr 16, 2010
  • 1619 Answers
SOURCE: washing machine too hot
Turn down temp on your home water heater.
Posted on Apr 22, 2010
My whirlpool awo3761/s keeps tripping my electricity when water is inside the drum
I would turn off the machine and unplug from the wall. Water is conductive and if it is throwing your switch you need a professional to look at it. Ring your local washing machine mechanic. Electricity and water are just too dangerous. If you keep resetting your switch and trying to run it, just to have it reset again, you can burn out the switch in the board. My husband did that when the kettle kept tripping it. New switch in the board was about $300.00.
Feb 06, 2015 | Whirlpool Washing Machines
Whirlpool awm323 drum not going round
JT where do you get these Ideas! OK, who have you been talking too!? I'm Jealous. LOL. Someone has been feeding you a load of CR#P! OK? The "brushes" are Inside the motor which would be Completely replaced (the Motor). You called some idiot and he told you that? What a Dork! That is like me telling you need New Fillings for your teeth cause they are crooked! If your machine doesn't spin and it is older than 7 yrs or close. Get a New One. Other than that get someone from Sears to come out and look at what is Exactly going on!
Jan 16, 2014 | Whirlpool Washing Machines
Fills with water correctly, will not go to next cycle
Hi ,, ok lets try some fault finding,,, try putting the washing machine on a no or low temp programme like wool,, or even the fill empty spin , see if it moves then,, if the programmer moves through then spins, i would assume the thermostat is broken,, if it moves through but does not spin , it may be the heating element,, if it does not move at all in any programme i would assume the programmer has a problem
Nov 14, 2013 | Whirlpool Washing Machines
Hi i have a whirlpool washing machine that keps coming up with a F05 on display with all lights flashing what does this mean please?????
The F5 error code means that during the wash cycle that the computer didnt see a rise in the water tempature...that means that their is a problem with the heating circuit in the washer,it could be a problem with the heat element,thermostat,or control board that wont let the water heat in the wash cycle.
GENE
Sep 08, 2011 | Whirlpool Washing Machines
We have no hot water boiler kaput - will washing machine heat water (hot wash) if only cold water is going into inlets.
Yes. The washing machine contains heating element and a thermostat. It will try to get water from both hot and cold sources and will heat the water to the required temp.
Mar 07, 2011 | Hotpoint Washing Machines
I have a WHIRLPOOL LE7000XSW0 dryer. I recently replaced the thermal cutoff because it quit heating. Now it heats but is taking 3 cycles to dry a load. I tested all the elect. components , the heating coil...
If the heater is heating, probably the thermostat is ok. What does the ohmmeter read when you just short the two test leads together? Suspect low air flow through the machine--clean all passages including the outside vent of lint. Remove the lint screen and clean it of fabric softener deposits by washing it in hot water and detergent. Hope this helps!
Dec 28, 2010 | Whirlpool Dryers
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
No hot water
Hi Jon, is this a new machine that you have just got? if so it sounds like the hot and cold water pipes are on the wrong way round. If not sounds like a thermostat problem
May 29, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Does the machine heat up the water
If you have only a cold water feed then all of the washing will be in cold water. Dishwashers heat up the water, but clothes washers do not.
Feb 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
