Question about Irons
Rowenta P2 (DE 635E) iron: Auto shut off
I agree that all appliances are worth fixing, been doing so for years. I easily diagnosed the auto shutoff module problem, but can't access it in the handle of the iron. I would bypass the module, or replace it if I could get the part, but there must be some trick/ latch or hidden screws that I can't find. Removing the obvious ones on the rear and removing the back was simple. I cannot seem to find any take apart blowup anywhere.
Can you suggest?
geokohler
  • 304 Answers
SOURCE: Rowenta iron manual needed
If you dropped it it will probably be an easy fix. Just openup the unit and look for a crack in the cicuit board. This is the case 99 percent of the time in apliance drops. If you find a crack in a board simply epoxy it and on the cicuit side of the board solder jumper wires from point a to point b when you follow the boken trace(s). If more than one trace is broken repeat the process until all the circuits can be repaired. Make sure you use wire of a high enough rating to handle the current the trace handles, and also use wire with heat resistant insulation in this application.
First things first though. Just open it up and have a look. The plug to the heating element may have just been knocked off. With a little trouble shooting skills and a good look you should be able to see your problem. If you get it open and see something I did not tell you how to fix just post any question you have and I will answer them for you.
George
Posted on Jul 24, 2008
SOURCE: Rowenta Steam Iron Leak
Yes, my rowenta model DX6700 is also leaking from the heal. I bought this iron after having a GE for ten years because I thought it would iron my clothes better. I've had it less than two years. How frustrating!!!!!!
Posted on Aug 01, 2008
wizzard8955
  • 18 Answers
SOURCE: Rowenta DM880 Auto shutoff - Shuts off too frequently
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Posted on Mar 06, 2009
  • 109 Answers
SOURCE: need to know how to clean a rowenta iron plate
As long as it's not a coated surface - plain steel - get 0000 steelwool to rub it with. It will take some elbow grease but it will work to clean and (almost) polish the surface.
Posted on Mar 26, 2009
SOURCE: Rowenta P2 Iron how to open?special Screw driver
I went to the ACE Hardware and bought a T-20 Torx security nutdriver attachment and it worked perfectly.
Posted on Jan 03, 2010
Iron keeps shutting down while ironing
My rowenta iron keeps shutting down while I'm ironing. What ...
www.faqqq.com/.../my-rowenta-iron-keeps-shutting-down-while-im-iro...
Question Product: Rowenta Effective DX1900 Iron with Auto Shut-off Question Details: My rowenta iron keeps shutting down while I'm ironing. What can I do.
Top 229 Complaints and Reviews about Rowenta Steam Irons
www.consumeraffairs.com > Shopping > Appliances
Rating: 1.6 - ‎36 votes From the first day, iron shuts itself off while ironing. ... The last 3 have either leaked everywhere or the cord where it joins the iron keeps switching the iron off. ..... from the stainless steal down the right side of the iron and was leaking water all ...
Oct 31, 2015 | Irons
Red light keeps blinking and iron shuts off
Sounds as if the cable may be damaged or a loose connection. May be cheaper to buy a new one from wallmart or similar store.
Jul 31, 2009 | Rowenta Effective DX1900 Iron with Auto...
I have a Rowenta Pro. Iron, model DE-86.1A with auto shut-off. It sticks on auto shut-off. I have to move it around for it to heat up, as indicated by the sensor light on the top.
I believe that is how the safety feature works.
Once the iron detects no movement for a certain period of time (the iron assumes you have finished ironing) the iron will shut of the heating element.
One you have moved it around, the timer should prevent it from auto shutting down for a period of time.
Jul 22, 2009 | Rowenta Irons
Jul 07, 2009 | Rowenta Powerglide DE011 Iron with Auto...
Iron won't heat up!!!
A lot of rowenta irons have a safety or auto shutoff built in them that fails. The only way I have found to fix them is to disassemble it and permanently connect the switch then it works fine, just does not auto shut off.
Jan 14, 2009 | Rowenta Power Duo Iron
Jan 06, 2009 | Rowenta Professional Luxe DM880 Iron
My rowenta effective will not heat up.
Dec 15, 2008 | Rowenta DG5030 Iron
George
Jul 24, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Doesn't heat up...
Authorized Appliance And Repair in St. Louis Mo, works on all model Rowenta Irons.
Nov 01, 2007 | Rowenta Professional DX8800 Iron
Irons Logo
88 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
