Question about HP Pavilion F1703 17" LCD Monitor
Monitor screen is black when hooked up to my laptop.
I've hooked up my F1703 to my Sony Viao laptop. When Windows first starts up I get the same picture on my laptop screen and my F1703. Once Windows is fully loaded my F1703 goes to sleep, the screen goes black. I've made sure the connection is correct, the drivers are loaded and updated and when I troubleshoot the monitor I get "device is working properly" and I've checked to make sure the device is enabled and showing up in my hardware list. Any suggestions.
    Genius:
  • 1,913 Answers
U have to set screen resolution of monitor to 1024 *768
Posted on Jan 05, 2009
Toshiba Satellite A505 - Most of the time when I turn it on the screen is grey, with no text.
This sounds like a bad display on the laptop. Hook up an external monitor to the vga port on the laptop. You may need to toggle the display to output to the external monitor. This is generally accomplished by pressing the "FN" key + one of the F# keys. Look for an icon that resembles a monitor or it may say LCD. If the graphics display correctly on the external monitor, then you will need to replace the computer screen.
Dec 29, 2012 | Toshiba Computers & Internet
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
Hp f1703 lcd monitor has no power at start up, bla...
guest, First thing to do will be to visit this web blog:
http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Do some reading to see if anything seems familiar to your problem of BLACK screen. If it helps you out a little then come back here and rate this response and tell us what action you will take to fix your unit. 12fixlouie
May 19, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a samsung lcd I just installed in my sony vaio laptop. It doesn't want to display windows only BIOS. I've been suggested to that this is a driver issue. where can I get a driver for this?
Very odd, I would hook an external monitor to the laptop and start eliminating the possible driver issue. If that doesn't work ironically I have a trashed viao laptop but the monitor is still good. Let me know-
Sep 22, 2009 | Samsung Computers & Internet
I hooked up my monitor to my Sony Viao laptop.
when upower up press F8 key also check there u set laptop as primary dispaly and second as monitor.
Jan 05, 2009 | HP Pavilion F1703 17" LCD Monitor
Error message
I have issues with the f1703 monitor as wel - the OSD will not turn off - though the more common failure of this model is that the screen is black after a very short usage time period. Apparently, this model monitor was defective, and was recalled by HP. However, they failed to give notice, so I would recommend following up with them to attempt to get it replaced. Good luck! (Further, it could be that the defective monitor may be affecting Windows in some form or fashion, but I wanted to inform you regarding the monitor.)
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Aug 28, 2008 | HP Pavilion F1703 17" LCD Monitor
Shaking Problem with LCD Screen - HP Pavilion F1703
It sounds like you need to use your "DeGausse" button to reset the magnetics in the screen.
Dec 25, 2007 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
164 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
