Question about General Electric GSH22JFX Side by Side Refrigerator
Remove water line from ice maker to check for obstructions on GE Side by side
5 Suggested Answers
  • 219 Answers
SOURCE: I recently replaced an old water filter from my
u either have a bad valve or your line is frozen to your dispensor
Posted on Mar 19, 2009
Sea Breeze
  • 4654 Answers
SOURCE: ice maker problems
Not sure I understand your problem. If you would like a GE Ice Maker Service Manual I can email you one. Let me know, Sea Breeze
appliancepartsse@yahoo.com
Posted on May 24, 2009
heatman101
  • 43501 Answers
SOURCE: Model # GSS22WGPH WW
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 04, 2011
Testimonial: "Just want to say thank you. I just read the suggestions and will check them out tomorrow. "
imufo2
  • 3773 Answers
SOURCE: My ice maker isn't getting
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
This can cause slow ice making if its too high even tho its freezing everything else at 25 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
imufo2
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Jul 26, 2011
How to remove icemaker from whrilpool ultraease refridgerator
I had a simular problem with my Whirlpool frig--First of all I would check 1/4 inch plastic line coming from water valve up to ice maker,loosen this line & try to blow thru it -if there is an obstruction it probably is frozen inside plastic fitting at top where it goes thru cabinet & into ice maker if so you can melt by by running a very warm metal object up & inside fitting be patient, you need to both inside & outside--If this the problem,your water valve is probaly bad because of not shutting off properly causing the "drip effect" you can purchase valve on line for aprox $10.00--$25.00 Good Luck--John Morris--
Feb 08, 2013 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
GE refrigerator is not making ice
There are several types of ice makers with the same model number. Some of my questions may seem over - the - top, but I do not know your level of ability. Do not take offense.
Did this ice maker ever work before, or is it a newly installed maker or a factory installed maker in a new fridge? Have you moved the power switch to on? If yours has an LED power indicator, is it off, blinking or on? Off means there's no power to the maker - you'll need to get the maker powered up before going further (make sure the electrical power connector is mated fully). Blinking means cubes have become stuck in the maker. You'll have to shut the maker off, remove the cubes then power up again. On means it is powered and is working normally. Is the freezer compartment set to maintain a temperature lower than 15 degrees F (-9 C)? The ice maker will not make ice unless the temperature is below 15 F (-9 C). The space under the maker must remain clear of obstructions so that the sweeper arm is not blocked (when blocked indicates a full ice container and will halt ice production until the arm can move freely again). The maker may need as many as 3 cycles (approx 6 hours) before all the air in the ice maker's water lines have been purged completely.
Listen for the solenoid valve to operate. Every couple of hours, this valve should operate and an audible click on and click off heard after a several seconds (as long as set on the ice maker cube size adjustment knob). When this solenoid has clicked on, water should be flowing through the lines and filling the ice maker. If not, there is an obstruction that must be cleared. A dirty or improperly installed filter, pinched line, and even ice can interrupt flow to the ice maker. You might need to remove the ice maker from the freezer to check the water supply line that feeds it for the presence of ice. Melt / clear as needed.
Jan 23, 2012 | GE GSS25LGM Side by Side Refrigerator
We have had the refrigerator for about two years and we just now hooked the ice maker up. The light on the door for the filter is red. Do we need to change it?
Check for a pinched line between filter and icemaker first, then purge some water through the ice maker to make sure it flushes anything in the line out, and discard the water and the first couple pounds of cubes. If it remains red, replace the filter as it may be obstructed.
Dec 10, 2011 | GE GSL25JFPBS Side by Side Refrigerator
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
GE TFX22ZR side by side. ice maker not making ice
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
A strainer before the inlet valve can also get stopped up restricting flow.
Oct 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
No Water to Ice Dispenser
Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker. Also make sure the coils are clean of dust , lint , etc...
Aug 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frigidaire water stopped working...ice maker.dispenser fine
You probably have an obstruction in filter compartment. you should remove filter and inspect o rings etc. or anything that could have clogged it up. The only other thing that could be the cause is a bad water valve. Side by sides have a double water valve. one for water ,one for ice maker. You can check this by having someone flip ice maker arm down so it calls for water and feel water valve as it runs and possibly hear it too. Hope this helps.
Jul 24, 2009 | Frigidaire FRS23KF7AB Side by Side...
GE model GSH25JFTACC ice maker not working
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
GE Monogram ZISS480DMCS Ice Maker Problem
i would first check water supply to ref. measure the resistance of coil either open or resistance. if all this is ok then exit side of line needs to be checked for water.
Sep 22, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Ice Maker No Longer Works - Water Works fine
Not sure if this will work for you - I had a similar problem with a Kenmore fridge. I removed the ice tray and found a piece of ice stuck where the ice is made and dropped into the tray. Once I clear this obstruction, the ice maker worked again. Also, check for the mechanism that indicates that the ice tray is full. This may be jammed or malfunctionin.
May 09, 2007 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
General Electric GSH22JFX Side by Side Refrigerator Logo
20 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Shehu Pro
Shehu Pro
Are you a General Refrigerator Expert? Answer questions, earn points and help others
