Question about Dayton 1RKU2 Electric Utility Heater
MY DAYTON 1RKU2A RUNS THEN SHUTS OFF - Dayton 1RKU2 Electric Utility Heater
What run capacitor will work on dayton fan motor model # 2LY97A
Over heating and like most new product these days throwaway planned obsolescence and made to fail
Feb 10, 2015 | Dayton Dryers
I am having trouble getting my Dayton Portable Oil fired Heater Model # 2E218E to keep running.
May be the primary control if you already replaced the photocell. Make sure the photocell is in direct line of sight with the flame.
Jan 04, 2014 | Dayton Heating & Cooling
Dayton oil fired heater
Most likely the flame sensor is dirty and needs to be cleaned. The sensor is a small rod that sits in front of the burner. Try using steel wool to clean it.
Dec 01, 2013 | Heating & Cooling
I've replaced igniter/sensor on my dayton 3E132 infrared heater,will light but runs for a while and shuts down,also do you need it hooked up to a thermostat
Yes, it should be hooked to a millivolt wall thermostat. Doing that should solve your problem (overheating). However, the millivolt wiring can be no longer than 10 ft.
Feb 06, 2011 | Dayton (3E132) InfraRed Heater
Runs for short period and shuts off
bruce how658,
You have a classic reddy heater problem. Actually reddy heat and dayton are the same. They have a fuel pump which is dependent upon the pressure of the air filter to maintain exactly 4.5 psi or your unit will do what you describe. This is an easy fix and I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem, where to get the parts and how to do the repair.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 07, 2010 | Dayton (3VE49) Oil Filled Liquid Fuel...
Furnace fires up and heats to desired heat setting and burner shuts down , but the main blower continues to run on.
its the fan control AFC not shutting off , it comes on at temp rise say 150f drops back to 130f with fan on , burner shuts off fan runs untill temp falls to 100f the fan shuts off in this case it keeps running
Nov 13, 2010 | Dayton Gas Furnace Heater
Dayton torpedo heater 150 btu starts and runs about 15 seconds then shuts off. Lots of fuel
All these types of heaters use mostly the same parts and dealer for one brand carry parts for most brands. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains the problem and where to get the parts to fix your unit. Let me know if you need more help.
hardrocko
Thanks for using FixYa and for the generous rating.
Mar 12, 2010 | Dayton Heating & Cooling
150,000btu Dayton htr (torpedo) lights, runs10 min fine, then shuts off
check for proper pump pressure. Restricted fuel flow. Proper venting of fuel cap.
Feb 19, 2008 | Dayton E52 Utility Heater
Dayton 1RKU2 Electric Utility Heater Logo
115 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
