Question about Lands Phones
Lg nortel phone have lost line 2. says CO LINE NO 02 BUSY QUEUING
HAVE LOST USE OF MEMORY NUMBERS FOR DEPARTMENTS THAT DONT HAVE A OUTSIDE LINE
NASAIT
  • 4 Answers
SOURCE: Ringer
You may need to change your Ring Volume. Here are some instructions on how to do so.
To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
To Change the Ring Volume:
1. Press the Feature button, then * 80
2. Press the volume key up or down
3. Press the release key1 to exit and save the volume level
Let me know if this works for you.
Posted on Oct 29, 2008
  • 10 Answers
SOURCE: Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Posted on Aug 20, 2009
  • 18 Answers
SOURCE: Want to pick up phone and get an outside line
Yes, put your lines in a line pool, then have your phone automaticly go to Line Pool: <Whatever Pool # you picked, 1 thru 3>
Posted on Oct 01, 2009
consultel1
  • 860 Answers
SOURCE: Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Posted on Dec 08, 2009
flst rider
SOURCE: nortel phone m3904 won't forward to an outside line
The DN may not be configured to allow forwarding to an outside line for security reasons. I think the default is 4 digits. You will need to talk to whomever programs your switch and ask them to allow this feature.
Posted on Jan 20, 2010
Landline phone constant busy signal
should you dial 9 or another access code for outside calls?
If if you dial an "outside" number on an intercom line it will look at the first 2-3 digits as another extension. You need to dial the Central Office access code, or use a line key assigned to an outside line.
Jan 17, 2014 | NorStar Lands Phones
HAVE LOST LINE 1 AND LINE 2 ON THE PHONE LINE 3&4 OK LINE 1 & 2 COMES UP NOT VALID
When you press PROGRAM 99 and the buttons where line 1 & 2 appear, it should say CO-01 and CO 02. If it doesn't dial 0 01 STORE and 0 02 STORE in those buttons. In a TD system, the lines have to appear in order for you to use them. They don't have to be 1:1, but it's the easiest.
(there's a Group CO button command to save buttons)
Carl
Mar 02, 2011 | Panasonic KX-T7431 Corded Phone
How do I program the line redirection feature
If you switched phone companies and the feature stopped working you probably had Call Forward Busy/No Answer from AT&T. If you use the call forwarding in the phone it will use two phone lines for the entire length of the call. Call Comcast and have them add Call Forward Busy/No Answer and tell them the number you would like your calls forwarded to and the ring cycle (the number of rings on no answer).
Mar 05, 2010 | Nortel T7316E 2-Line Corded Phone
Nortel phone m3904 won't forward to an outside line
Nov 10, 2009 | Nortel Norstar 16-Line PBX Speakerphone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Unable to see if an internal extension is engaged
It doesn't exactly work that way, but you can program the extensions back under the buttons. Pick a button that you want to save an extension under and press FEAT *2 the button and dial the 2 or 3 digit extension number. Now the button monitors the status of the extension. It will light whether it's in DND, or busy on an outside or internal call.
Carl
May 21, 2009 | Nortel T7316E 2-Line Corded Phone
Dec 17, 2008 | Nortel T7316E 2-Line Corded Phone
Call forwarding to outside line
To send a call to another telephone within your system, or to an external
telephone. You may not be able to transfer a call on an external line
to an external telephone, depending on the capabilities of the lines.
1. Make or answer a call.
2. Press the feature button then press 70.
3. Call the person you want to transfer the call to.
4. Stay on the line if you wish to speak to the person first.
5. Press the Release button to complete the transfer.
If an external call is transferred to a busy internal or network
extension, or is not answered after a few rings, the call automatically
rings you back.
Sep 24, 2008 | Nortel T7316E 2-Line Corded Phone
Lands Phones Logo
102 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
