Question about HP Deskjet 460c InkJet Printer
Red and green light blinking...
I have both my button closet to the power button and my power button blinking.. Any sugesstions? Printer is not working.
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 25, 2009
Resetting waste in absorber code for IP4900
You ink absorber is full
1. Download canon service mode tools v3400 from the net.
2. Set the printer in Service Mode: - power OFF the printer bu Power button. Dont disconnect power cable
- connect the printer by USB cable to the PC.
- press and hold Resume button (red triangle in the red circle) and press Power button
- hold both buttons until power on indicator will light then release resume button (dont release Power button) and press Resume button 5 times
- release all buttons - the printer will blink few times with green light and will then light green constantly. You have put the printer in Service Mode now and you can now run the Service Tool. (If the printer is still blinking by green - you have some other errors in printer and you have to fix them first, because the Service Tool will not work if the printer is not put in service mode - green light is constant)
3. Run the Servicetools V3400.exe program.
4. Select the connected USB port number from USB PORT
5. In the Ink Absorber Counter section of the Service Tool, select MAIN from the Absorber pull-down menu.
6. From the Counter Value(%) pull-down menu, select the value (in 10% increments) which is the closest to the actual counter value confirmed before replacement of the logic board, and click SET.
Print EEPROM information to confirm that the value is properly set to the EEPROM.
Jan 18, 2013 | Canon PIXMA Office Equipment & Supplies
Printer hp deskjet 840c blinking green and red light why
Depends which red blinking light. I assume the red light is the resume light. The green light is the power light. If the Power and the Resume light are blinking alternately, then you have a paper jam somewhere in the printer. remove the paper jam and you should be fine.
Mar 18, 2011 | HP DeskJet 840c InkJet Printer
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
On off light blinkinking from green to red and I
Canon IP3000 INK counter reset
Can gave it a go may work
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Dec 14, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Trouble turning on RCA D61W20
the green light blinks three times but does not come on
Aug 16, 2009 | RCA D61W20 61" Rear Projection Television
TLP2848Z blinking red, will not print
1: Is it a TLP2844 or a TLP2844Z.
Operationally they are completely different printers. TLP2844 uses ELP (Eltron Programming Language. but TLP2844Z uses ZPL (Zebra Programming Language). You need to calibrate the printer to the labels.
If its a TLP2844. Load media. Connect power.
Hold down feed key, power on, count one, two, release feed key. The printer will go through a calibtation routine and print config label. IMPORTANT - When it prints this label you must press the feed key and see the message OUT OF DUMP. Your printer will now be calibrated. Check this by hitting the feed key a few times and printer will feed one label each time feed is hit.
If its a TLP2844z.
Load media. Turn printer on and wait for green light (Approx 1 minute)
Press feed key and keep it pressed until green light blinks once, then twice, now release feed key.
Dec 22, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Canon printer ip1000 blinks red and green
Depress power button while plugging the canon pixma ip1000. When you depress the power button, the printer can be used even if the in waste absorber hasn't been replaced.
Nov 30, 2008 | Epson Stylus Photo® R2400 InkJet Printer
Red light
Logic Error in printer
Aug 12, 2008 | HP PhotoSmart 7660 InkJet Printer
Blinking red light
Red Light blinks when the ink cartridge is bad..
to check which one is bad..
take out all cartridges from the printer and clean the copper contact and the inner area of the cartridge slot with a lint-free cloth...
power off the printer and unplug the power cable from the printer..
press & hold the power button on the printer for 60 seconds..
connect the power cable and power on the printer..
insert any ONE cartridge and close the door..
similarly insert other cartridges one by one and close the door and check if the light blinks..
if it blinks means the respective cartridge is bad and replace it..
if u have replaced all the might be possible that the cartridge sensor inside the printer have gone bad..
if this is the case so ..u might service the printer..
but I will suggest to go for a new printer as 7660 is quite an lod printer which hp launched in 2004 or 2005..
even if u have juz bought it will be refurbished one..
HP Deskjet 460c InkJet Printer Logo
246 people viewed this question
Ben Johnson
