Question about HP 2000-410us 15.6" Inch 2.2gPentium B960 4gb Ddr3 500gb Notebook Pc Charcoal
HAVE A HP 2000 NOTEBOOK PC THAT WON`T CHARGE THE BATTERY.WHEN I USE THE PC WITH THE AC POWER LINE IT WORKS FINE WITH A NOTE SAYING THE BATTERY IS NOT CHARGING. BOUGHT A NEW BATTERY THINKING THE BATTERY MIGHT BE THE PROBLEM,BUT IT WASN`T. PLEASE HELP.
  • ARTHUR Nov 09, 2012
    COULD IT POSSIBLY BE A BROKEN WIRE OR A BREAK IN A CIRCUIT BOARD INSIDE THE PC ?
    Master:
  • 551 Answers
Your battery must be damaged or your charging pin must be losed which connect to device you check this point.
Posted on Mar 24, 2013
Hp 8440p battery won't hold a charge
Since you have replaced the battery and the ac adapter then there's a problem with your computer's motherboard. Get it serviced by a technician if he says that you need to replace the motherboard then you better buy a new laptop. Motherboards are expensive.
Apr 04, 2013 | HEWLETT-PACKARD Hewlett Packard HP...
Tip
How to Help HP Pavilion Laptop Power Battery Using Problems
Hp laptop users might experience that the battery is overheated, or the laptop battery suddenly stop charging. Sometimes, the battery health "good" but the battery does not hold a charge, etc. So, how to fix these problems?
First of all, you know that the most common type of AC power adapter involves a small box, with one wire to go to the computer and another wire to go to the wall. There is usually an LED light on it, to tell you that it is on. When your laptop doesn't work, you need to troubleshoot the AC power supply, system board and the battery are functioning correctly. The battery is an important part. It supplys power to the input-side of the voltage regulators, just like the power from the AC adapter. Additionally, there is a charging circuit, which uses the power from the AC adapter prior to the voltage regulators, to charge the battery. (By the way, this is why the AC adapter voltage is always rated higher than the battery's rated volatge-- you need higher voltage for charging.)
Verify the Hp laptop battery like this:
1. Insert the battery into the battery compartment on the bottom of the notebook PC.
2. Connect the AC power supply and allow the battery to charge for 15 to 30 minutes.
NOTE: The power LED, located near the power icon (displayed as a lightening bolt on most PCs) , should glow while the battery is charging.
3. Unplug the AC power adapter cord from the notebook PC.
4. Press and release the Power button to start the computer using only the battery as the power source.
If the PC does not power on, then the battery needs to be replaced. Contact HP service and support for further assistance.
If the notebook PC does power on, the battery is functioning, however you should run the HP Battery Check utility to evaluate the battery's health.
NOTE: If you have purchased a second battery for your notebook PC or you have access to an identical battery, you can also check the battery by inserting the second battery into the PC and performing the Troubleshoot the battery steps again.
Your new HP laptop battery comes in a discharged condition and must be charged before use (refer to your computer manual for charging instructions). Upon initial use (or after a prolonged storage period) the battery may require two to three charge/discharge cycles before achieving maximum capacity. When charging HP laptop battery replacement for the first time your computer may indicate that charging is complete after just 10 or 15 minutes. This is a normal phenomenon with rechargeable batteries. Simply remove the battery from the computer and repeat the charging procedure.
It is important to condition (fully discharge and then fully charge) HP replacement laptop battery every two to three weeks. Failure to do so may significantly shorten the battery's life (this does not apply to Li-ion batteries, which do not require conditioning). To discharge, simply run your device under the battery's power until it shuts down or until you get a low battery warning. Then recharge the battery as instructed in your user's manual. If replacement HP laptop battery will not be in use for a month or longer, it is recommended that it be removed from the device and stored in a cool, dry, clean place. It is normal for HP laptop replacement battery to become warm during charging and discharging.
How to solve the batery can't be charged?
Possible Reasons:
a.The battery has no voltage.
b.There is problem with charger, as it has no output electric current.
c.Low charging efficiency due to external cause.
Best Solutions:
a.Test whether the charger has voltage and output electric current or not.
b.Check if the charger is well contacted with battery.
c.Activate the battery with voltage and current 1.5 time higher then the highest ones of battery. (Use this method only when the battery can't be charged.)
Original: http://www.papatek.com/Knowledge/Battery-knowledge/Knowledge_194.html
on Sep 02, 2010 | Computers & Internet
I have hp notebook compaq 1610p battery won't
The battery is dead, replace it. If the power cord works and the battery is not charging, then the battery is dead. The battery only has a useful life then it has to be replaced.
Apr 26, 2012 | HP Computers & Internet
AC adapter fine also battary fine but HP 4420s dont charging
If that is true the charging circuits on the motherboard will be the problem, "a rare situation" so long as the laptop powers up using the adapter and the charging voltages are missing in the computer terminal where the battery plugs in then this would apply.
Apr 04, 2012 | HEWLETT-PACKARD HP ProBook 4420s Notebook...
Hey, i have a HP Pavilion dv6000 and since yesterday if i unplug the power cord it shuts off. i know that means the battery is not working but im not sure as to why. the battery meter is telling me that it...
Hi, when using the (AC Power Adapter), it is important that once the (Battery) is fully charge; to do one or the other. Stop! using the AC power, shutdown the computer, and unplug the AC power; use the battery (only), or remove the battery, and use (only) the AC power. Note: Using both power sources this can cause damage to the battery, by over charging, and possibly over heating the computer. Thanks paul7of9
Jan 05, 2010 | HP Pavilion dv6000z Notebook
I have a compaq presario 700 laptop that is no longer charging.
The notebook battery may have a defect if it will not power on the notebook and if it will not hold a charge. The battery indicator light on the notebook either does not light or always blinks orange. The notebook operates correctly when connected to the AC adapter.
A battery that will not charge may be the result of an AC adapter failure, a system board failure, or a battery failure. Perform the steps below to diagnose the failure.
Troubleshoot the power supply
To verify that the AC power supply is functioning properly, follow the steps below.
1.
Plug the AC adapter directly into a functioning wall outlet, and plug connector into the computer. Do not plug into a power strip, surge protector or secondary power source.
2.
Verify the following operation and take the appropriate action:
That all power cord connections are secure.
If the AC adapter connection to the notebook is loose, the connector may be damaged and require repair. Contact HP service and support for further assistance.
That the power button or power LED is lit when the computer is on.
That an LED on the AC power supply adapter is lit when plugged into an AC wall outlet (not available on all AC power supply adapters).
That the AC power supply adapter is the correct type.
Different notebook models require different AC power supply adapters. You will need to know the Product Number of your notebook to determine the Part Number of the replacement part. Click Start > HP Help & Support to view the product name, product number, and serial number that you'll need to have to speak with HP Customer Service.
View the See Also section for information about locating HP Help & Support in your operating system.
Troubleshoot the System Board
If you've verified that the AC power functions properly, troubleshoot the PC's system board by following the steps below.
1.
Remove the battery, and keep the notebook connected to AC power.
2.
Press and release the Power button to start the computer.
If the notebook PC powers on , then the AC adapter and system board are functioning properly. Go to Troubleshoot the battery .
If the Power LED is off , then the AC power adapter needs to be replaced. Contact HP Service and Support for further assistance.
If the power LED is on , but the notebook PC does not power on, then the notebook PC needs to be repaired. Contact HP Service and Support for further assistance.
3.
Shut down Windows by selecting Shut Down from the Start Menu.
If you have verified the AC power supply and system board are functioning correctly, troubleshoot the battery by following the steps below.
1.
2.
NOTE: The Battery Charging light should be on while the battery is charging. If it is not on, check the AC power adapter connection to the notebook PC.
3.
4.
If the notebook PC does power on, the battery is functioning properly.
Apr 14, 2009 | Compaq Presario 700 470024-192 Notebook
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
HP 2000-410us 15.6" Inch 2.2gPentium B960 4gb Ddr3 500gb Notebook Pc Charcoal Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
