Question about Epson Aculaser Mx20dn Laser Print Copy Scan 1200 X 1200 Dpi 2000
Please help, multipurpose EPSON AcuLaser MX20DN , only problem is the E-mail Scan ..... all scans send in BLACK/WHITE not COLOR, how can be configured to send e-mail color ? Now send only B/W
  • dariri Nov 09, 2012
    can be configured? or it does not function model that
  • 5 Answers
SOURCE: Epson Aculaser C1100 E537
Hi there
This suggests a fuser error. This is the hot unit at the rear top of the machine.
Steps are as follows:-
1. Open COVER FUSER.
2. Draw out the COVER RH boss from the hole on COVER FUSER while pushing
COVER RH outward, and remove COVER FUSER.
After removal check coninuity across heater lamp amd thermistor terminals. If either shows anyhing more than 13 Ohms then you need to replace your fuser unit.
Anything more than that requires hands on technical expertise.
Good luck
ivorpits
Posted on Dec 20, 2008
tigertail
  • 163 Answers
SOURCE: error e520
E520 is a 2nd BTR sensor error. It is usually caused by waste toner getting on the sensor. Turn off the printer and open the top panel. Lift up the orange handle to unlock the PCU and remove the PCU by lifting it up using the carry handle. Be careful with the PCU drum as it is easily scratched and avoid bright light. Inside the printer on the rear "wall" is a spring loaded cover which can be pushed down to uncover the sensor. It will stick in the down position, do NOT try to force it up again (it will spring back into the right position when the PCU is refitted). Give the sensor a wipe with a soft cloth and refit the PCU. Close the lid and turn back on, with luck all will now be well. If you still have the same error it is time to get proffessional help unless you are experienced at testing voltages and taking printers apart.
Hope this helps, please take a moment to rate this solution.
Posted on Apr 09, 2009
SOURCE: epson aculaser c1100 not printing right hand edge
The problem may well be that the drum needs cleaning. There is a plastic flap on the rhs of the machine. Open that and you can pull a long lever out. You also need to let down the front cover and pull out the lever on the right hand edge that faces you. Then extend the long lever at the side as far as it can go and push it in and out a few times. This should solve the problem. Put the front lever back and close the cover. It took me ages to find this - Epson are not good at highlighting it,.
Posted on May 08, 2010
  • 394 Answers
SOURCE: I have an Epson sx515w,
first step (assuming you have not done this) is to un-install the printer then re-install the drivers.
Posted on Dec 16, 2010
SOURCE: Scanning with no ink in an EPSON RX510
Simply Open EPSON SCAN Software from your computer and scan from there. It WILL WORK even if the Printer is blocked due to Low Ink Issue.
Posted on Mar 26, 2011
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
My Epson Stylus NX515 prints beautifully. I love it. But I can't seem to get it to scan. And I really. Need it to scan :(
There should be a scanning option from Epson's Control Application, that you should have installed on your PC. If you're trying to scan from say Photoshop or similar program go through the File-Import-From TWAIN scanning process. Also, you may want to check if there's a break that blocks the scanning head from moving. This should either be on the bottom or back side of the scanning assembly. Look for a plastic bezel that has two sliding positions, it should also have an icon of a locked and unlocked keychain or something similar.
If this post was helpful and informative please reward it with a Thumb Up. Thank you.
Jan 19, 2011 | Epson ACULASER CX11NF All-In-One Printer
Please help... when i scan more than 10 docs and then try to attach it to an email, it states that the file is too large ... please help me with my Lexmark X4270
You should setup the scan resolution to a lot less.
Scanned images can take a lot of space it scanned at high resolution and with many colors.
If it is a document, you can set it to scan black and white or gray and instead of the default resolution (300dpi) you should try scanning at 75dpi or 100dpi.
Those settings can reduce a scanned image to few ks instead of 10s of megs.
The average mail systems can't handle mail messages larger than 10Mb.
I would also suggest playing with the scanner to get the best results before trying to mail the scanned documents.
Nov 10, 2010 | Lexmark All-in-One Printer with PictBridge
Document Recognition
Hi!
Here is an OCR software which you can download for free.
Please click on the link to access free OCR (scan to text) software.
Thanks.
Jan 06, 2009 | Epson 2580 Perfection Photo Scanner
EPSON ACULASER CX11NF Scanning problem
Your epson scan software is most likely corrupted or there is another application consuming the memory on your pc. Try uninstalling the software and reinstalling. If this does not fix the issue, then you have another application on your pc causing you issues.
The epson scanner will not appear in your scanners and cameras in the control panel, this is one of the known funnies with windows and most manufacturers know about it. the create their own interface which you can find through you program files under epson scan.
Gremlin 11
Nov 26, 2008 | Epson ACULASER CX11NF All-In-One Printer
Can not get scanning to work over a wireless/network
The ip address for you scanner is already set. If you are able to print to it over the network than you will be able to scan from it over the network. The trick is that you will need to initiate the scan from your pc and not from the scanner. Look in your program files and find epson scan. there you will find epson scan setings. open this up and select a scanner, the cx11nf. Tell it that it is a network scanner and allow the program to find the scanner. Once found, you will need to test it. If you get full communication back from the scanner than you are connected and can then use epson scan to scan your documents and pictures to file.
If you cant find epson scan than you have not loaded the program and will need to reload the program.
Gremlin11
Nov 13, 2008 | Epson ACULASER CX11NF All-In-One Printer
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Epson CX4200 scanner
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan.
Jul 10, 2008 | Epson Stylus CX4200 All-In-One InkJet...
35mm Color Slides
Here they are for Mac and PC
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you receive a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Mar 15, 2007 | Epson Perfection 3170 Flatbed Scanner
Epson Aculaser Mx20dn Laser Print Copy Scan 1200 X 1200 Dpi 2000 Logo
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
