Question about Fuji FinePix S7000 Digital Camera
Finepix S7000 problems
I have had this camera for at least 3 years and it gets a round while circle in the middle and sometimes a white outside frame. After about 20 pics it seems to go away. It happens every time I use the camera. When it isn't doing this it sometimes goes into a no reception mode like on TV with all sqiggly lines. These problems happen so often now I rarely use the camera and I used it almost every day. My husband wrote to a place that fixes cameras and they told him it sounded like the ccd whatever the hell that is. They also told him it would be cheaper to send it to Fuji to repair. Any input is appreciated.
  • Ronda Moniz May 23, 2007
    Wow when you pay almost $400 for a camera you expect it to last a long time. Well longer than 3 years. If this is the case then maybe I should invest in cameras under $100. It's definitely not worth all those $$'s for so little years.
    Genius:
  • 2,985 Answers
3 years is very old for a digi cam. Insofar the way they improve so rapidly Best bet would simply get the next one A repair would cost almost as much even if they offered to do it.
Posted on May 22, 2007
  • john ash
    john ash May 23, 2007
    This the sad fact of life these days
    service by replacement.
    Think of all the small electricals out there toasters/Kettles/sandwichmakers electronics like media players and computer parts- none of that is repaired any more.
    Because primarily stuff changes so quickly now there would be warehouses of spares no one wanted.
    So it had it -s time I feel
    But by all means check Fuji out -you never know your luck.
SOURCE:
Zoom error appears in viewfinder on FinePix S7000 and cannot take photos.. Please help
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Oct 02, 2009 | Fuji FinePix S7000 Digital Camera
Set s7000 white balance
Navigate through the settings menu's until you find the one that addresses the white balance. Either leave it set to automatic or experiment with different settings until you are pleased with the results. If this was helpful, please rate.
Sep 04, 2009 | Fuji FinePix S7000 Digital Camera
Problem in Fuji FinePix S7000 digital camera.
CCD failure image sensor failure
ur camera may be on service advisory list just mail the fuji film with serial number i am pretty sure they will repair free of charge it is a manufacturing fault in some units manufactured b4 2005 u have to email them they will repair it free of charge
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=616757
pls rate me FIXYA for this if u like
Dec 31, 2008 | Fuji FinePix S7000 Digital Camera
Fuji finepix s7000
Per the owner's manual:
  1. Insert a formatted media into the camera.
  2. Set "RENEW" as the FRAME NO. setting in the SET-UP menu.
  3. Start taking pictures. (the frame numbers start from "100-0001".)
  4. Set "CONT." as the FRAME NO. setting in the SET-UP menu.
Then you're done. We just did this on ours and now we're ready to go. God Bless.
Jun 05, 2008 | Fuji FinePix S7000 Digital Camera
Flat batteries
a well known problem , this camera eats batteries there are high power (2950MaH) accus , those should be used with this camera even with 2700 MaH it is empty real quick
Mar 04, 2008 | Fuji FinePix S7000 Digital Camera
Internal memory fuji finepixa820
the only way to prevent it is buy a XD card
Fuji Finepix S7000 Zoom Memory Cards (xD-Picture Card - M Type) & Accessories The following memory cards are compatible with your Fuji Finepix S7000 Zoom. Every memory card we offer is manufactured to the highest standard and carries a 2 year minimum warranty. Your Fuji Finepix S7000 Zoom accepts xD-Picture Card - M Type cards. The largest xD-Picture Card - M Type card you can use in your Fuji Finepix S7000 Zoom is 2048MB
View all Fuji Digital Cameras
Feb 18, 2008 | Fuji FinePix S7000 Digital Camera
Overexposure and vertical lines
My E550 started producing over exposed frames (everythings white except maybe across top) with lines.This just happens outside.On inside the pictures are great.
BGibbons
Sep 09, 2007 | Fuji FinePix E550 Digital Camera
I don't know if this is the same problem, but a few months ago, I was getting a small circle in the same spot, every time I took a photo and the colour in that area of the picture was light. You can see it in the photo I've posted here, on the left side midway between the top and bottom. __I took it into Fuji, and I think they cleaned the CCD. It only cost about $50, and the problem is gone! Hope this helps.
May 22, 2007 | Fuji FinePix S7000 Digital Camera
Problem: A big white simicircle halfmoon in the top 1/3 of my pics
Hello I have a similar problem... I have 3 years or 4 the camera and in this moment I go to realease a photo this morning and see a circle in the center. More or less the same. thanks for all if you know anything
Apr 18, 2007 | Fuji FinePix S7000 Digital Camera
White Square with brighter Oval in middle on LCD and Pictures
have you checked the lense assembly. One of the possible cause may be any of the lense element, inside the lense assembly may have dislocated from its fitting. Just swithc on the camera look inside the lense from the front and try to zoom the camera. if you happen to find any obsticle in the movement may be i am right.
Sep 07, 2006 | Fuji FinePix S7000 Digital Camera
Fuji FinePix S7000 Digital Camera Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
