Question about Karcher Garden
Repair instructions for Karcher 620M on/off switch
I want to replace the on/off switch on Karcher 620M
4 Suggested Answers
  • 62 Answers
SOURCE: karcher 620m runs but will not pump water
The pump that connects to the motor could be bad/and or loose
Posted on May 10, 2009
SOURCE: what oil grade is correct for Karcher 620m pump?
I don't know either. Anyone got an answer?
Posted on Mar 06, 2011
SOURCE: I have a karcher 620m, power going to switch and
The little white thing is most likely a capacitor, and only AC current affects this it blocks DC. These don't often fail, and if but if suspect, then replacement is the only way to tell?
You need to check at the actual terminals on the Motor to see if the power is getting there, it should be present at one side of the motor, the "Hot"side, and the other side or "Cold"side will contact to the Neutral wire, to complete the circuit. It is a very basic circuit.
You also need to check the motor is OK, While motor is disconnected, use a meter set to OHMS, and measure across the the motor's terminals, you should get a lowish Ohmic reading, if it is Open circuit, high Megohms, then either the Motor has "Blown" or the embedded protection fuses inside the motor have, either way the effect is the same the motor must be replaced. This is often what it is.
Below is a exploded diagram manual that may help, it's not all in English, but gives one a good idea.
http://www.pressure-power-washer.com/pdf/karcher/5955-6440.pdf
Posted on Jul 06, 2011
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
I have a karcher 620m, power going to switch and coming out of switch but motor wont run, there is a white cylinderical item beside the switch with 2 wires and power isn't getting to it have you any...
Jul 06, 2011 | Karcher K2.26 Electric Power Washer
What oil grade is correct for Karcher 620m pump?
Jan 07, 2011 | Karcher Garden
Need manual for karcher 620m
Hi. Please click here to download the manual.
Let me know if you need further assistance. Thank you for using FixYa.
Jun 05, 2010 | Garden
Karcher 620m runs but will not pump water
May 10, 2009 | Karcher 2500 PSI Pressure Washer
Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Mar 25, 2009 | Karcher Garden
Karcher Pressure washer
Hi
don't know if this will help, but when I use mine, to start the pressure up I have to turn the nozzle to fine spray then turn it to the power spray and it works every time, shouldn't have to do this but I got it for nothing.
May 29, 2008 | Washing Machines
Karcher 620M not drawing water
my 620m has a problem when i press the switch on it has no pressure and the pump sounds like it is not kicking in .... plese help !!!
steve ..
Jan 08, 2008 | Washing Machines
Garden Logo
655 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
