Question about E-Machines W3107 (RBW3107) PC Desktop
Fan runs fast and no bootup - E-Machines W3107 (RBW3107) PC Desktop
  • E-Machines Master
  • 27,725 Answers
An eMachines desktop or laptop computer fail to boot for a variety of reasons, but a fast, loud fan noise signifies that the system is suffering from overheating.
The problem, and the steps for troubleshooting it, is not unique to the eMachines brand.
When the internal temperature of the computer reaches too high a level, the system will shut down automatically to allow the heat to dissipate.
If you attempt to power up too soon, the machine will not boot properly.
To boot, you will need to correct the cause of the overheating, and keep the machine cool.
Blocked Vents
Although different in size, both desktop and laptop computers have air vents to help the fans keep air circulating around the hot internal components.
If these vents become blocked, by pushing a desktop too near a wall or using the laptop on a soft surface, the air supply your internal fans need to cool the system is cut off.
This blockage also traps the heat inside, allowing it to build to dangerous levels.
Keep the air vents on your computer free and clear to allow proper airflow.
Dirty Computer
Airborne particles, such as dust, lint and hair, can gather on the air vents and internal components over the course of time.
This accumulation of dirt not only provides a sort of "insulation" to the electronic components, preventing the heat they generate from dissipating normally, but it also clogs the fan and heat sink to prevent proper function.
Use canned air and damp, soft cloths to thoroughly remove any built-up debris from inside your computer.
Dried Thermal Paste
The heat sink sits atop the CPU chip to help dissipate the heat the component produces.
Thermal paste is layered between the CPU and the heat sink to help draw the heat away from the chip for cooling.
Over time, the cooling properties of this paste decreases, and the substance becomes dry and flaky.
You can replace this paste to renew its cooling assistance by removing the old paste remnants with rubbing alcohol and adding a new layer.
Thermal paste is also known as thermal compound or thermal grease, and is available at most electronics stores.
Hot Environment
When examining overheating causes, don't overlook the environment you use your computer in.
External heat sources, such as fireplaces or even rays of direct sunlight, can cause the internal temperatures of your computer to rise.
This causes your internal fan to run harder in an attempt to dissipate the combined heat before temperatures rise too high.
Move your computer away from external heat sources to encourage more effective cooling.
Posted on Nov 07, 2012
R15d notebook screen black, fans running
either your backlight has failed or you have hit one of the function keys which selects external monitor- can you connect it to an external monitor to see what happens?
May 21, 2014 | Microsoft Computers & Internet
On bootup the screen is lined, taskbar appears for 10 seconds then the computer shuts down?
type the command chckdsk/f fast on the run or try to repair the windows
Sep 06, 2010 | AcerPower 4300 PC Desktop
My dell latitude c510/c610 failing
Sounds like the fan may be failing and need replacement. On a system that age, it is debatable whether it is worth fixing.
You can boot to he resource cd and run fan diags is you want to try and confirm
Fans can be found on EBay
May 26, 2010 | Dell Latitude C640 Intel Pentium 4-M...
Compaq Presario S5300NX (DM174A#ABA) PC Desktop: Compaq Presario Dekstop: CPU Fan error on bootup. ...
The fan has a third wire, that is used to tell the uProcessor that it is spinning and in some cases how fast.
Replace the fan and that should fix it. Spares form many suppliers on ebay
May 18, 2010 | HP Compaq Presario S5300NX (DM174A#ABA) PC...
The CPU Fan stop after the pc boots
The fan will only run when needed to cool the computer. Fans normally run at full speed during bootup, but turn to low speed or off after bootup if not needed. Is your computer running hot enough that the fan SHOULD be running?
Sep 07, 2009 | Acer TravelMate 290 Notebook
I have a 2005 Jetta 2.5 and it seems like one fan runs to fast
One fan should run when engine is running. Other fan should run when AC is on.
Jun 28, 2009 | 2005 Volkswagen Jetta
I have to hit the f1 key to continue the bootup process. Then I get a defective fan error message, but the fan is running, becasue I can hear it.
there may be more than one fan-- there also is a setting in the BIOS to disable the fan warning if you are SURE that the fan it is monitoring is working correctly.
Jun 24, 2009 | Gateway M350 Notebook
My dell laptop wont do disk check and wont continue on windows what will i do to fix it
You should try to boot it into safe mode and then run a virus scanner you should also be able to run disk check in safe mode. Usually pressing the F12 key during bootup will bring you to the boot menu. You have to watch carefully because the option appears really fast at the beginning of bootup.
Mar 27, 2009 | Dell Latitude C600 Pentium III 750MHz,...
E-Machines W3107 (RBW3107) PC Desktop Logo
27 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
