Question about Panasonic KX TG7321Cordless Phone
Call dirvert to mobile phone - Panasonic KX TG7321Cordless Phone
I want to dirvert some number how to do that
You should be able to hit option oh the number/person and click block call.
Dec 11, 2012 | Nokia C5 Cell Phone
I want to dirvert calls to another handset plerase help
go to the call settings then click on the call divert option then click divert all voice calls then on that select the option as divert to another number then feed the number inside the tab now click ok check the status now if it says activate then its ok. If not activated then contact your service provider to activate the call divert for your number . because they may block divert optoin for your number
Jun 15, 2011 | Cell Phones
How do I turn the shower on? I just moved into a place that has a Delta series 1400 Monitor shower handle, a smooth faucet, and NO mechanism whatsoever that I can see for switching from bath to shower. Is...
There should be a dirverter on the tub spout. It will be either a knob to pull up or a ring to pull down on and hold untill the water comes out the shower head.
If there is no dirverter go buy a new tub spout with one.. The prior owners may have installed the wrong spout.
Apr 01, 2011 | Delta & Single Handle Shower Faucet
Water comes out both spout and showe head when temperqture control is adjusted
Something is blocking the flow thru the tub spout. Make sure the dirverter moves properly. It mat be stuck partialy closed.
If that does not work take the tub spout off and see if you still have the problem. If that fixes it get a new tub spout.
Mar 31, 2011 | Delta & Lockwood& Tub & Shower Faucet
Water coming from faucet and showere head when the
the washer on back of the dirverter knob needs replacing or the seat behind the vavle stem
Aug 18, 2009 | Danze D302521 Antioch Roman Tub Faucet...
I seemed to have lost the "turbo" that gets me up the hils where I live. I recently had a timing belt change and get regular maitenance every 10,000K. Also I have had an undiagnosed "shuddering" for the...
If it's a TDI, then your intake is probably clogged. If it's a 1.8, then check your turbo hoses to make sure they are all connected. Check Dirverter Valve.
Jun 27, 2009 | 2003 Volkswagen Jetta TDI
Phone says Line in Use when alarm digital diverter is plugged in
I think you may have had a power surge to do serious damage to your system.
I think it came in through the phone line. Your diverter is what got damaged....
You need a phone line surge suppression device.
TelcoISO2WDTB/G200V ...screw terminals or
TelcoISO2WDTB/G200V RJ11 M/F
$96.60 each.
www.storminprotection.com
Apr 09, 2009 | Panasonic KX-TGA600B Cordless Expansion...
The telephone has no dial tone and I wish to have my calls dirverted to my mobile which is 0277556905 I have been waiting for 18 and a half minutes for assistance but am still on hold. The number in...
Which phone company are you using?
Is your call set for call al art by you phone company?
If your phone has no dial tone, have you check the phone line that is coming from the wall jack into your phone.
call your services provided to direct all calls to your cell.I believe they charge extra for this service.
Thanks
Good luck
Jul 30, 2008 | Lands Phones
Can not align color dirvertions on test screen
I think you need a remote to use the convergence features of this set. Does it have an auto convergence feature? And does it work?
Dec 31, 2007 | Toshiba 55H70 55" Rear Projection...
Panasonic KX TG7321Cordless Phone Logo
29 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
