Question about Akai PT5598HD 55" Rear Projection HDTV-Ready Television
My colors are not lining up correct - Akai PT5598HD 55" Rear Projection HDTV-Ready Television
  • Akai Master
  • 8,617 Answers
Replace the convergence amp board and that should solve the issue.
Posted on Nov 08, 2012
I dont detect dial tone for the fax
Hi Chris, Is the fax line correctly connected to a good phone line? You might also want to check the settings for the fax and make sure they are correct.
Mar 18, 2014 | HP Officejet Pro 8600 Plus e-All-in-One -...
Color lines and dark parts
I had a Toshiba Satellite and it developed the same colored lines problem. It will continue to deteriorate until you cant see any thing behind the lines. I found it to be a bad video card.
Problem is....the video card (in most if not all Toshiba's of those days) is integrated into the mother board and can not be replaced separately. You must replace the mother board to correct the video card problem. Due to the expense, I'd rather buy a new PC and have the data trans'd to the new PC.
------------------------bp
Feb 04, 2014 | Toshiba Satellite P105-S6207 Laptop
Colored ink not printing correctly, lots of lines
You can try to use an other cartridge. if that won't fix your problem, you should send the printer back for repair
Apr 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Toshiba TP50G50 Theaterview picture is double with red color only
Your alignment is off. Go to the set up menu then convergence. hit right and you will be in the convergence menu. select the color that is not in alignment. The green line does not move. if blue and green are lined up the line will be cyan. if red and green are lined up the line will be yellow. when all three are lined up the color will be light. Best of luck!
Nov 16, 2008 | Toshiba TP50G50 50" Rear Projection...
Skewed printing
Most probably you have to do the Color Registration Settings and the Color Calibration.
The Color Registration will fix the fuzzy printing and the Color Calibration the way how the colors looks. The Color Calibration it is done automatically after each batch of 40 or 80 pages and if you need you can do a manual Color Calibration BUT THE COLOR REGISTRATION must be done manually.
Go to Menu->Others->Service->Color Registration and print a test chart. Will print a page and you have to read the alignment of some lines Cyan Magenta Yellow Black with some numbers. Check the Advanced user guide for details. Basically you have to read the number / letters of each color where 2 lines are matching. Then you can enter those numbers into the printer for each color.
If the Cyan only is off then will be easy ...
Nov 03, 2008 | Kyocera FS-C5030N Led Printer
Horizontal lines in pictures
If you are using original cartridges then there should not be a problem. The horizontal lines come from the cartridge. Can you pinpoint if it is a color or black line that is missing? My guess is that during the alignment procedure, you are asked to choose a number or letter that corresponds to picture of a the lines that show the best alignment. If you did this correctly, may I ask how many pictures you printed before seeing that line. Is it on the first print or 10th printing? Cuz if it is on the 5th or more full color picture, then the problem is that you you really have the wrong printer. The F380 capacity for printing full color pictures is miniscule. 1 ml per color. So usually after the 3rd color picture, the ink starts to run out. Let me know if this helps.
Apr 23, 2008 | HP DeskJet F380 All-In-One Printer
Laptop screen flickers and color is distorted
Sounds like the CCFL is failing.. (Backlight)... Pink hue is common when these start to go out..
Dec 14, 2007 | Computers & Internet
Photos are monochromatic with a puple color and horizondal lines in it.
Contact Canon - this is a CCD problem that they know about - possibly a replacement will come your way
Sep 16, 2006 | Canon PowerShot A95 Digital Camera
Akai PT5598HD 55" Rear Projection HDTV-Ready Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
