Question about Acer Aspire T135 PC Desktop
How do i remove cover - Acer Aspire T135 PC Desktop
  • Acer Master
  • 5,660 Answers
Viewing FRONT of computer the LEFT Side panel removes.
Viewing REAR of computer there are two Thumbscrews to loosen.
One towards the Top, one towards the Bottom.
(Not supposed to come all the way out, but OK if they do)
There is a 'bulge', or 'bump' formed at the back of the Side Panel.
This is a fingerpull handle.
Pull back on the Side Panel towards the Rear of the computer.
The Side Panel will only slide so far. This is because there are metal L-shaped tabs formed out of the Side Panel, that go into slots in the metal framework, of the computer case.
The L-shaped tabs are like a hook. You may have to ease the Side Panel a little forward, then the L-shaped tabs will clear the slots, and the Side Panel can be brought out to the side, and removed.
Anti-Static Precautions:
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static BEFORE reaching inside your unplugged from power, computer.
Computer on a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface, if the metal frame of the open computer case.
This action will relieve your body of Static.
IF, you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
May I ask what the problem is, or is this for a simple upgrade?
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Nov 07, 2012
Trouble removing valve cover on the right side (passengers side) of the engine on a 1996 mark viii. Help
  1. Remove engine appearance cover retaining bolt and nuts.Remove engine appearance cover from vehicle.
  1. Disconnect engine control sensor wiring at intake air temperature sensor (IAT sensor) connector and crankcase ventilation tube from air cleaner outlet tube.
  2. Completely loosen air cleaner outlet tube to throttle body bolt (captured bolt).
  3. Loosen clamp on air cleaner outlet tube to engine air cleaner (ACL) and disconnect air cleaner outlet tube.
  4. Remove remaining bolt from support bracket clamp on RH valve cover to air cleaner outlet tube.
  5. Remove air cleaner outlet tube and engine intake air resonator.
  1. Remove two retaining nuts from engine air cleaner outlet tube bracket to valve cover and remove engine air cleaner outlet tube bracket.
  2. Remove four nuts retaining RH ignition wire cover and remove cover.
  3. Disconnect ignition wires from spark plugs with a gentle twist! pull motion on the spark plug boot. Remove spark plugs.
CAUTION: Do not pull on the ignition wire as it may separate from the connector in the boot.
  1. Remove bolts and studs retaining RH valve cover to cylinder head.
  2. Remove valve cover.
Sep 28, 2017 | Cars & Trucks
Tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
on Feb 11, 2015 | Life Fitness Crosstrainer, 9100, 9500 Rear...
Tip
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover...
Removing the Unit Compartment Cover
NOTE: Sharp edges may be present.
1. Unplug the refrigerator or disconnect the
power.
2. Lift the main decorative panel to unhook it
and remove the panel.
3. Lift and remove the louvered decorative
panel.
4. Remove the two hex-head screws from
the air diverter and remove the diverter.
5. Remove the nine hex-head screws from
the unit compartment front cover, and pull
the cover forward out of the way.
NOTE: If there is less than 3above the top of
the unit compartment cover, perform Method A
to remove the cover. If there is at least 3above
the top of the unit compartment cover, Method
B will allow you to remove the cover without
pulling out the refrigerator.
METHOD A
1. Pull the refrigerator out of its mounting
location so you can access the rear of the
unit.
2. Remove the left and right hex-head screws
(one on each side) from the front corners
of the unit compartment cover.
3. Remove the left and right hex-head screws
from the rear channels of the unit compartment
cover.
4. Lift the unit compartment cover up, and
pull it forward off the refrigerator.
KitchenAid, Whirlpool side by side refrigerator removing Unit compartment cover method B
http://www.fixya.com/support/r5760029-kitchenaid_whirlpool_side_side
KitchenAid, Whirlpool side by side refrigerator remove the main control board assembly
http://www.fixya.com/support/r5760103-kitchenaid_whirlpool_side_side
on Aug 27, 2010 | Refrigerators
Changhing valve cover gasket 03 mitz galant 3.0 v6
  1. Disconnect the negative battery cable.
  2. Remove the upper intake manifold.
  3. On the 3.0L DOHC engine, remove the ignition wire cover.
  4. Remove the ignition wires and spark plugs.
  5. Remove the crankcase ventilation tubes from both valve covers.
  6. Remove the retaining nuts and engine wiring from both valve covers and move aside.
  7. Remove the valve cover retaining bolts and studs.
  8. Remove both valve covers from the engine.
To install:
  1. Clean the valve cover gasket sealing surfaces.
  2. Install new valve cover gaskets onto the valve covers.
  3. Place the valve covers into position.
  4. Reinstall the valve cover retaining bolts and studs and tighten in sequence to:
    3.0L SOHC engine: 7 ft. lbs. (9 Nm)3.0L DOHC engine: 42-54 inch lbs. (4-5 Nm)3.5L engine: 30 inch lbs. (3 Nm)
  5. Install the engine wiring and tighten the retaining nuts.
  6. Install the crankcase ventilation tubes into both valve covers.
  7. Install the ignition wire separators, the ignition wires, and the spark plugs.
  8. On the 3.0L DOHC engine, install the ignition wire cover.
  9. Install the upper intake manifold as described in this section.
  10. Connect the negative battery cable.
  11. Run the engine and check for leaks and proper operation.
Jun 25, 2017 | Cars & Trucks
Removing steering column shroud on a 2006 sierra 3500, no screws where videos show to remove them there's a recess area but no screws in the locations indicated
Steering Column Trim Cover Replacement
Important: You must check for 2 pan head tapping screws (1,2) in the lower trim cover before removal.
If necessary, remove the 2 pan head tapping screws (1,2) from the lower trim cover (3). Remove the lower trim cover (3).
If screws are not present in the lower trim cover, proceed to the next step.
Gently unsnap the lower trim cover from the upper trim cover.
Important: You must check for 1 TORX® head screw (1) in the upper trim cover (2) before removal.
If necessary, remove 1 TORX® head screw (1) from the upper trim cover (2).
If a screw is not present, remove the upper trim cover (2).
Dec 01, 2016 | 2006 GMC Sierra 3500
Change timing belt
timing belt? on a Jeep? 05 wrangler
what engine is this>?
ah the 2.4L
front cover
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the crankshaft vibration damper.
  3. Remove the generator drive belt tensioner assembly.
  4. Remove the timing belt front cover bolts, and remove the covers.
rear cover
  2. Remove the front covers.
  3. Remove the timing belt.
  4. Hold the camshaft sprocket with Special Tool 6847, or equivalent, while removing the center bolt.
  5. Remove the timing belt idler pulley.
  6. Remove the rear cover fasteners and remove the cover from engine.
Apr 04, 2014 | 2005 Jeep Wrangler
Changing the fuser for a CM1415fnw
If your capable of searching google, you may want to grab the service manual for this, heres the procedure to change it out but as you can see there are even more procedures along the way...
Fuser 1. Remove the following components: ? Right cover. See Right cover on page 17. ? Right-front cover-1 and cover-2. See Right-front cover-1 and cover-2 on page 20. ? Control panel. See Control panel on page 22. ? Left cover. See Left cover on page 25. ? Document-feeder and scanner assembly. See Document-feeder and scanner assembly on page 28. ? Rear-center cover. See Rear-center cover on page 30. ? Rear-upper cover. See Rear-upper cover on page 31. ? Speaker. See Speaker on page 33. ? Top cover. See Top cover on page 34. ? Rear door and rear-lower cover. See Rear door and rear-lower cover on page 41. 2. Remove two screws (callout 1) and the black plastic cover (callout 2). Figure 1-117 Remove the fuser (1 of 4) 1 2 80 Chapter 1 Removal and replacement ENWW 3. Disconnect five wire-harness connectors (callout 1). Remove the wire harness from the guides (callout 2 and callout 3) and one retainer (callout 4). Figure 1-118 Remove the fuser (2 of 4) 2 1 3 4 4. Remove four screws (callout 1). Figure 1-119 Remove the fuser (3 of 4) 1 ENWW Removal and replacement procedures 81 5. Remove the fuser. CAUTION: Handle the fuser carefully. The sensors that are mounted to the output side of the fuser can be easily dislodged. When the fuser is reinstalled, make sure that the sensors are present, and correctly fastened to the fuser assembly. Figure 1-120 Remove the fuser Hope this helps...
Feb 16, 2014 | HEWLETT-PACKARD CM1415fnw AllInOne Laser...
A lower bolt on the primary cover broke,so i removed the shifter and foot peg bracket,then removed all of the bolts from primary cover after draining primary fluid. The primary cover still doesnt seem to...
You need to remove the derby cover from the primary that goes over the clutch adjuster. Remove the sping and the locking nut. Turn the adjuster screw clockwise while gently pulling the cover off. The cover should come off then.
Good Luck
Steve
Jun 28, 2011 | 2007 Harley Davidson XL 883 Sportster
Zx-9r 2000 how do you remove the clutch side cover to change the clutches
The clutch cover is removed in a two step process.
  • Remove the clutch cable by loosening the adjustment at top and bottom first. Then remove the cable end from the clutch lever. This should give enough slack to remove the cable at the bottom by the clutch cover. ** Take notice of the angle of the lever that the cable goes into the cover. You will want to re-assemble the clutch cover with that lever in the same angle.
  • Remove the clutch cover bolts around the outside of the cover.the cover should now be removed by pulling the cover straight out.
Thanks and I hope that this helps.
Steve
Jan 21, 2011 | kawasaki ZX-9R Motorcycles
Changing valve cover gasket
v6 or 4 cylinder?
SECTION 303-01A: Engine - 2.0L 1999 Cougar Workshop Manual
IN-VEHICLE REPAIR Valve Cover Removal
  1. Disconnect the oil feed sensor electrical connector.
  1. Disconnect the crankcase ventilation tube.
  1. Remove the appearance cover.
    1. Position the throttle cable out of the way, and the speed control cable (if equipped).
    1. Remove the eight bolts.
  1. Remove the spark plug wires.
  1. Detach the upper part of the engine front cover out of the way.
    1. Remove the four bolts.
    1. Position the front cover to one side.
  1. Remove the valve cover.
    1. Position the throttle cable to one side, and the speed control cable (if equipped).
    1. Remove the nine bolts.
Mar 23, 2009 | 1999 Mercury Cougar
Acer Aspire T135 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
