Question about HP OfficeJet 6110 All-In-One InkJet Printer
The problem with my printer is,it keeps saying that the cartridges are jammed.What should I do Please help me...
    Genius:
  • 1,913 Answers
Turn the power off.then open ink cartirdge then refix it again also check ther eis not any paper jam.
Posted on Jan 05, 2009
Hp psc 2175 all in one keep saying remove and check cartridge
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 19, 2010 | HP PSC 2175 All-In-One InkJet Printer
Screen says cartridge cradle is stuck but it moves freely
Ok there
Mar 05, 2010 | HP PhotoSmart 7760 InkJet Printer
My printer keep saying clear carriage jam but there isnt anything that is still jamed. How do i fix this problem . I can't get it to work now
The printer is telling you that something is jamming the printer carriage, or the rod, that the print cartridges ride on. Open your printer up to where you would install your print cartridges, either front load or top load. See if you can find anything in the path of its movement.
Remove it, and try printing again.
Look for paper that may have jammed recently in the printer.
If that doesn't fis it, try moving the printer cartridge holder manually and then try to clear the message again.
Hope this helps.....
Please rate my response!!
Jan 29, 2010 | HP Photosmart C7180 All-In-One InkJet...
Paper jam
Found this on the HP Web site.
Issue:
The product stops printing and the error message 'Paper Jam: Clear jam, and then press OK ' displays on the product.
HP Support
GOOD LUCK!
Oct 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
My 5610 all in one series keeps telling me that there is a paper jam. I have checked and there is no paper jammed in the printer. It won't reset. It keeps saying paper jam. Help!
Check to make sure both ink cartridges are installed properly. I don't know why it says "paper jam" when the cartridges aren't properly installed, but it does.
Aug 25, 2009 | HP Officejet 5610 All-In-One InkJet...
I have a canon pixma mp130 and it keeps saying cart. jammed
Press menu to maintenance.....go to cleaning roller....repeat cleaning 3 times....return to copying...hope this helps
Aug 04, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Paper jam
check paper jam error you need do:
1) between paper input tray and cartridge check any pieces paper
2) between cartridge and fuser area do same thing
3) check fuser and pressure roller(near fuser) any pieces of paper there
4) after fuser to output tray
all above step checking for avoid any pieces paper obstruct any sensor through all paper road, so that cause jam error
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Brother MFC 8500 All-In-One Laser Printer
Error keeps popping up saying : cartridge jam
Remove the toner cartridge(s) and check for proper installation. Also check that all shipping tape was removed from the cartridge. I've also seen a more technical issue with there where the gear that operates the cartridge is broken.
Apr 08, 2009 | HP Office Equipment & Supplies
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP OfficeJet 6110 All-In-One InkJet Printer Logo
20 people viewed this question
Ben Johnson
