Not find volume level of imation 8gb usb
Alwayes not readable
  • 27,725 Answers
Click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
you might have to alternate doing this repeatedly until the problem is resolved
click start control panel scroll to folder options view place a tick in show hidden files folders and drives
this may vary depending on your operating system
if you need more help with this post a reply
hope this helps
Posted on Nov 08, 2012
Format imation defender F150
Connect it to your computer.
Open "My Computer".
Right-click on the icon for the device.
Click "Properties".
Click "Tools".
Click to 'format' it.
Jan 23, 2014 | Imation Defender F150 8GB USB 2.0 Flash...
I forget my password of imation defender 8go F150
The short answer is without the password, all info on the drive will stay encrypted and locked forever. It looks like you may still format it and at least get to reuse the drive. Formatting will erase EVERYTHING on the drive permanently. Here is some more specific information
http://www.secure-usb.co.uk/imation-faq
Dec 01, 2013 | Imation Defender F150 8GB USB 2.0 Flash...
What is the password for the new kingston USB DT109?
It is true that locking mobile storage devices, such as USB drives, with Imation Lock is an excellent way to protect your data.
However, using Imation Lock with a Kingston USB drive can create problems.
Learn how to unlock your Kingston USB drive so you can use it once again.
Ensure that your Kingston USB drive has been removed from your computer's USB port.
Start the Imation Lock software by double clicking the Imation Lock.
Plug in the Kingston USB into a USB port immediately after the "Please Insert the Device or Run This Utility as Privileged User" message appears.
Access your Kingston USB drive by clicking Start > Computer.
Double click on the device.
Start the Imation Lock software again by double clicking the Imation Lock.
Disable the password protection by clicking the open lock icon.
or
If you have password protected a USB drive or partition on your computer and have since forgotten the password, you will need to completely erase the drive.
Erasing and reformatting the drive will remove any password protection, software and data on the drive preventing you from accessing the drive.
The process is simple using Window's Disk Management utility.
Log into the computer as the administrator.
Open the Windows Start menu, select "Run," type "Compmgmt.msc" and click "OK." In Windows Vista and Windows 7, simply type the command into the "Search" field.
Select "Disk Management."
Locate the password-protected drive.
Right-click it and select "Delete." Confirm the action.
The drive will be erased and become unallocated free space.
Hope this helps.
Nov 28, 2012 | Kingston Ultra Thin DataTraveler DT 109...
I have an 8gb imation that become 4mb free space why it happen?
click start control panel administration tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in one box then select check now start or you might tick one box then return after its finished the first
click start click on computer then right click on your usb drive select format
(note formatting will remove all data on your drive)
then right click on your imation drive select properties you will seea mmount of space used and ammount of free space
hope this helps you
Nov 11, 2011 | Imation Products - imation - Clip Flash...
Imation 8GB pen drive problem. When I type in my
Check this: Right click - EXPLORE
Check if your USB drive has somekind of a button (sometimes looks like a tiny bar) it's a hardware lock
Jul 22, 2010 | Computers & Internet
My 8GB imation was fine yester day, but it's
Yes first you need to recover your data so yo must use a tool to do that, maybe the "Pen Drive Data Recovery" can help you, I think it free you must search for it at google, and then when you stract your information you might use a Low Level format tool to get you're USB flash drive working again such as the hdd-low-level-format-tool, you can find these two tools at google
Mar 01, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I had run imation lock on kingston 4 gb and now its says "Please insert the device or run this"
its a little tricky, just try it
  1. unplug ur usb drive
  2. double click the imation lock
  3. when the message appear "Please insert the device or run this utility as privileged user" plug the flash/usb drive quickly
  4. USB will start working
  5. run the imation lock again and disable the password protection
  6. delete the ugly imation lock from ur system
i hope u find it use full, plz give ur feed back at: masood@inbox.com
Jul 28, 2008 | Computers & Internet
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
