This problem should be removed because:
Problem with Dell Latitude D600 PC Notebook
Biometric fingerprint reader not recognising me
My Medion akoya P6612 Notebook will not recognise my fingerprint upon start-up. I think the problem relates to me de-installing the application "VitKey" which is responsible for making the fingerprint reader work. After De-installing this and rebooting my laptap, it would not recognise my fingerprint and after three unsucessful attempts it gives the option to type in a password. This does not work also. I know the password is correct, but it still says its the wrong password. Any help on how I can solve this problem would be greatly appreciated.
Solutions (2)
Best Solution
Restart you computer and tap the F8 key until the startup option screen appears,then start in safe mode.
you will need to start in safemode and use the administrator account to create a new account then restart in normal mode then reinstall the software and reset your passwords from the new account (administrator user) that you created
so you are locked out of your bios what i would do is remove the battery and hold the power button for 10 seconds then plug it in and turn it on see what it does.. if that doesn't work then there should be a code or series of keys to press to bypass .. if you cant find any information on that then you will need to pull the laptop apart and remove the cmos battery (THIS IS A LAST RESORT DONT PULL YOUR LAPTOP APART IF YOU DONT KNOW 100% WHAT YOU ARE DOING)
At system start button and then press F11 at the prompt "Press [Esc] to continue" as a password to enter am8888egh
check this site for more information
Medion Akoya P6612 Notebook Cyberlink YouCam
When i try to open the Cyberlink YouCam program, it tells me that there is no device + that if i have an integrated webcam i must ensure...
TV Tuner express card 54 DVB-T Medion
I have new Laptop 97110 and whyen I try to connect Media Centre to TV channels I get message"No tuner found" or something to that...
i would like to restore my medion akoya to the
i would like to restore my medion akoya to the factory settings but i cant seem to figure out how. how would i do this?
I have a Medion Akoya
I have a Medion Akoya P6612 and I haven't a clue how to activate the wireless switch? I don't know where it is! Help would be much...
Add Your Solution
Lock with a key with A symbol
system Lock
its locked up
The wifi is disabled and I cant access any programs
Fix-O-Meter
4,244
4,244 people viewed this problem
- 3 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Dell PC Laptop Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
There is some info that you can reach (some of) the hidden BIOS settings of the Medion by pressing F11 key during boot up.
When you'll be asked for the password, try
am8888egh
am8888egc
or
am8888eg
Afterwards you'll enter an extented CMOS setup screen where you can make the settings of your choice
if this don't do it,let me know
