Question about Dell 3010cn Laser Printer
Dell 3010CN Color Laser Printer is leaving vertical smudge/bleeding. Is there a toner dump box to empty? It is just cyan streaking.
  • 32 Answers
Try a new Cyan toner cartridge. If nogo, will need a new transfer roller or transfer belt (I used to work on these printers but forgot if they use a belt or not... I will check on the DCSE site and post back)
Posted on Jan 05, 2009
How do I get rid of vertical streaks?
You may have a bad drum cartridge. Is it refilled? Try replacing it with brand new original.
If there are debris of "black film-like material" you may need to replace your fuser film.
Apr 29, 2014 | Dell 3010cn Laser Printer
I changed the black and all 3 color cartridges and now it leaves wide streaks of color. How can this be corrected?
If you used a compatible cartridges your problem is probably in the cartridges, replace them. If those are genuine dell cartridges get back to me. Good luck.
Dec 14, 2010 | Dell 3010cn Laser Printer
Have vertical cyan lines 1 inch wide on same side
Don't know about your "primed" toner, but go to Diagnostics and run the PQ test. See what that looks likes. Go to Disable Cartridge Check and swap the black and cyan toner. Run another PQ test. Are the lines still there and are they black or cyan? If they are cyan, the cartridge is bad. If they are black it's not the cartridge. It going to take a tech to look at it.
Feb 02, 2010 | HP LaserJet 4650 Color Printer
The cyan color only prints on 1/2 to 2/3 of the page then fades out to nothing
okay make sure your cartrage does not have a scatch on it and if it is full or empty
Aug 07, 2009 | Dell 3010cn Laser Printer
Vertical streaks when printing pictures
vertical lines on prints usually means either the drum's cleaning blade is not cleaning the drum (or the drum is damaged) or the fuser is scored. scored means that the protective coating on the fuser rollers is damaged. I would check the rollers on the fuser (the hot part of the printer right near the paper exit) for any lines on it, if you look at your prints, you should see them in the same location on the fuser. if you do not see any lines on the fuser rollers, then replace the drum.
May 24, 2009 | Dell Office Equipment & Supplies
Vertical line on copies
A vertical line on laser copiers which are the same lenght apart on each indicates a dirty or defective toner cartridge or dirty or defective rollers. Take the cartridge out and wipe the rollers with a soft cloth. If the streaks continue then the rollers inside the cartridge or damaged. You will need to replace the toner cartridge. Let me know if you have any questions. Please rate this solution with 4 diamonds.
Mar 29, 2009 | Dell 3010cn Laser Printer
Dell 3100cn Smudges on all color except black
Sounds like the fuser. Try heavier paper settings (you have to change them in all 3: driver, printer itself and program you are printing from). If that doesn't work replace the fuser.
Feb 24, 2009 | Dell 3100cn Laser Printer
Cyan toner does not rotate to front to be change
um... Cyan is blue isn't it?
Magenta Pink,
Yellow = Yellow and
Black = black.
Oct 02, 2008 | Dell 3010cn Laser Printer
Streaking
Replace toner cartridge . Must be originals
Jun 17, 2008 | Dell 3010cn Laser Printer
Dell 3010cn Laser Printer Logo
543 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
