Question about Minn Kota Boating
How to change the steering cables on a Minnkota Maxxum pro 80
My shaft came apart. how do I reassemble by the collar in shaft. doesnt want to push back together
One almost hesitates to enquire, but shaft for what ? If you can tell us the make and model of the camera involved, we will do our best to assist.
May 06, 2017 | Photography
I have a minnkota maxxum 74lb thrust trolling motor. The pedal pin in the foot control keeps sliding out on one side and I have to push this back in to stabilize the pedal. Is there something...
Good day ,
The next time the pin comes out have a close look at it if it has little raised grooves in it that is what is supposed to hold it in.
if so put a little lock tight on the pin and push it back in it should hold again
good luck
Gordy
Nov 03, 2017 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Looking for parts brakesdown minnkota 101
Google the Make and model...dozens of web sites, including MinnKota,
Dec 16, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Minnkota maxxum 70 has half the thrust is had before
Sounds like a bad connection somewhere. I would take it to a authorized dealer for repair if it's still under warranty. Can get a bit tricky to repair yourself unless you're comfortable with soldering.
Aug 18, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Looking 4 a manual on a minnkota turbo pro 824 48 lbs thrust motor
This isn't my usual area of expertize, but is this what your looking for?
Minnkota 824 Motor Diagram
Mar 20, 2009 | Computers & Internet
Boating Logo
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
