Question about Konica Minolta bizhub 750
What side is the write seat located on and how do I reseat it to clear the code?
  • Konica Minolta Expert
  • 1,326 Answers
All the PCB's doing with logic are behind the rear panel of the copier. Good Luck
Posted on Nov 10, 2012
Seat ibiza (02-09) code 17961 how to fix
Manifold Pressure sensor (MAP sensor, probably located on the intake manifold somewhere) has an Implausible signal i.e. going out of a plausible range. you could try removing the connector and reseating it. I've seen this a few times where just reseating the connector fixes the problem, if not it'll probably need replacing.
May 08, 2014 | 2006 Seat Ibiza 1.4
Air bag code B1378 2008 chevy aveo
You could clear the code with a scanner, but its possible the sensor for the driver side bag is faulty.
Jun 29, 2013 | Cars & Trucks
Water wont drain from tub error code nd
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 07, 2012 | Washing Machines
Air bag code 33 for a 2005 lincoln town car
2005 Towncar SRS Code 33 (3 flash + 3 flash, repeat this set for twice. then Beep 5 times pause x 5 = 25 beeps every 30min).
This means you have problem with left (Driver) side pretentioner (Seat belt retract system).
It doesn't mean physical belt or retract mechanism.It is just bomb wiring which is part of airbag system.
When airbag deploy, passenger must stay tight in seat otherwise body lean to front then slam back to seat by airbag.
if belt is loose or delay to lock, passenger's body rocks back and forth.So, system use small bomb (Fire power) to lock and retract seat belt when airbag deploy.There is small bomb and igniter in part of Seat belt retractor.
Code 33 is warning for this part on 2005 Towncar.(older model is different meaning in Ford/Lincoln, it's possibly passenger side airbag system for earlier model)
Before you work for any part of Airbag system and touch any "Yellow connector", * *Disconnect battery (negative side is good enough) and wait at least 5 min to clear all power in system**.(Airbag store back up power for few minutes to be able to deploy even in case if power disconnected)
by the way, you should move your driver seat most forwarded position before you disconnect battery to make it easy to work with seat belt.
locate driver side seat belt retractor (in center pillar between front and rear door, you may have to fight with weather strip)
Locate Yellow connector on bottom of Seat belt retractor (it's called "Pretensioner")it is located on very bottom of rear side of retractor.
only one yellow connector. (make sure your battery is disconnected)
Check its physical connection or looseness.if connection looks fine, you may have to replace whole seat belt ($180-$200 in Lincoln dealer)
You can check if pretensionor is good or bad by regular tester, but unless you know how, I won't tell (because I don't wan't you to blow out pretentionor).
Jul 19, 2012 | 2005 Lincoln Town Car
Canon ir 3080 error code E0000450000 give me complete answer gust in few minutes
The OHPSensor may be out of alignment with the reflector in the Paper Feeder FrameAssembly, there may be a loose connection, or it may be faulty.
Open the Right Door Assembly and the OHP Sensor (with a blue tintedlens) is located on the machine side in the center below theregistration roller and the ITB. Ensure that the sensor is correctly seated inthe mounting frame and reseat the harness to the sensor. If code will not clearreplace the sensor. (RH7-7129-020).
Jun 09, 2011 | Office Equipment & Supplies
How to locate the fuel filter of Kia sorentp lx 2003, and then how to replace it
the kia fuel filter is a long life filter it is located in the fuel tank in conjunction with the fuel pump , to locate it remove rear seat base and will b able to remove fuel pump nd then filter is on fuel pump . make sure orings are sealed nd seated correctlt to prevent fuel pressure loss . i think fuel filters r done round 90000km
Apr 04, 2010 | 2004 Kia Sorento
Airbag light 2000 beetle
could be loose connection or bad sensor,must be repaired then code cleared out
May 26, 2009 | 2000 Volkswagen Beetle
Problem abt lock code
Please give me your IMEI number. It is on the package of your phone or on the reverse side where the battery is inserted.
Be fast about it dear. Rate my solution when we are done.
May 23, 2009 | Nokia N70 Cellular Phone
Have error code 990 on ricoh gx 3000 printer how do i clear this?
you can try pulling out and reseating the Waste Ink tank which is located behind the machine behind a plastic door cover (left side of machine as you are looking at it from behind). Turn the machine off and on using the main power switch. If the code comes back then you will more than likely need a new Waste Ink Tank.
Mar 23, 2009 | Office Equipment & Supplies
Water bucket - proper seating
Try re-seating the bucket. I have found some LG models that if not seated all of the way will sometimes keep running and think the bucket is not full even when it is. On the models that I have seen do it the problem is usually the left side of the bucket not engaging all of the way. When you reseat the bucket, feel where the bucket meets the dehumidifier on each side and make sure they are even. If one feels like it is sticking out further than the other and you cannot push it in any more pull the bucket out and try and reseat it again until both sides are flush with the dehumidifier. If you found this solution helpful please rate it.
Thanks - Tech101
Jun 10, 2008 | LG DH404E Dehumidifier
Konica Minolta bizhub 750 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
